Question about Mastercool 67471 Evaporative Cooler Air Conditioner
Water is not going into swamp cooler
I'm having to manually put water into the swamp cooler to get it circulation but when that is done hot air starts to come out so i think that there is no water coming in from the water line. What do i need to do?
    President:
  • 3,433 Answers
CK THE FLOAT THAT OPENS AND CLOSES THE water valve.. press down on float to see if water is available,if water flows float needs adjusting. If no water then check to seeit hasn't been turned off for the winter -good luck
Posted on May 11, 2009
Need parts, pump for a ED630J adobe swamp cooler in las vegas, nevada
A swamp cooler PUMP is not really model specific. They are basically small submersible pumps. Contact ANY swamp cooler dealer in LV, tell them you have a 4500 CFM unit and need a pump.
The pump part number for this size cooler is: PN 110436 (there are several alternates)
Contact these folks and tell them what you need:
National Cooler ' Swamp Cooler
3046 Vegas Dr.Suite 1
Las Vegas, NV 89106
(702) 638-8800
If they can not help you... just look under cooling and air-conditioning in the yellow pages and find a dealer near you. This pump is common to nearly every brand in LV. You can most likely buy one at the local home depot, menards, or lowes.
There is also a Little Giant CK-5 "UTILITY"pump that is used for swamp coolers.
Thanks for choosing FixYa,
Kelly
Jun 15, 2011 | AdobeAir Mobile Swamp Evaporative Air...
How do you calculate the cfm in a swamp cooler
You will need to figure the cubic feet of space you want to cool, and then divide that number by two. The quotient will give you the CFM rating for the proper-sized swamp cooler.
Jun 14, 2011 | Heating & Cooling
Is it possible in aircon to used it with no compressor??
Nothing in air conditioning is new. It has been done for many years.
There are three types of "compressorless" refrigeration that I can think of.
1. ) swamp coolers or evaporative coolers - these work on the process of adiabatic saturation in low humidity environments. Evaporating water removes energy from the air, makes it cooler and more humid. This is a win-win when the air is very dry, but the process doesn't work well in humid environments, were water evaporates less readily.
2.) Peltier junction solid state coolers. These are essentially a thermocouple driven in reverse. Conduction between the hot and cold plates is hard to control and at low voltages these devices need a lot of current. These units are not as efficient as mechanical refrigeration.
3.) Absorption refrigeration cycle. In these systems a solution of ammonia in water (or water in a lithium bromide brine) is used. Heating the water (or brine) drives out the ammonia (or water vapor) and takes the place of the compressor in the cycle. This cycle is useful if you have a source of waste heat. You essentially recover the energy in the waste heat to run a refrigeration unit. A few demo units have used solar energy as the heat source, but I don't think this is common
Sep 18, 2009 | Dehumidifiers
Evaporated cooler is not filling up with water
yes ur water pump is not working properly..
ur will have to check it
Jun 29, 2009 | AdobeAir Mobile Swamp Evaporative Air...
Breezair swamp cooler parts
Contact Convair cooler corporation.
Phone # 1- (602) 353-8066
Will send your parts out the same day.
Jun 28, 2009 | Heating & Cooling
Swamp cooler is not blowing cold air. Water is
is the pump youll have to take off a panel make sure the pump has water. what is the relative humidity if it is high swampers don't work very well .Tom
Jun 25, 2009 | Heating & Cooling
My portable air conditioner has stopped pumping water to the tank
this would be a swamp cooler.if you have water in it and its not pumping.its going tobe the pump but i would see if the pump is getting voltage first before i bought a new pump.where doyou live that your worried about a cooler?
Jan 01, 2009 | Heating & Cooling
Replacing pads
How do I replace a rigid pad on my Mastercool swamp cooler?
May 22, 2008 | Mastercool 67680 Evaporative Cooler Air...
Mastercool 67471 Evaporative Cooler Air Conditioner Logo
385 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
Boyet Soriano
Boyet Soriano
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
