Question about Philips Magnavox 27MS343S 27" TV
Philips Magnavox 20MS3442/17 Green Line
The picture is squished to the middle from the top and bottom and has a bright green horizontal line across screen.
  • 700 Answers
If this is a tube type or crt type. Your vertical circuit has a problem. Could be the vertical IC loose connection on its board. Or the vertical ic itself is faulty. If just resoldering or refluxing of its pins doesn't help check some minor cmponent within vertical circuit. Or the vertical ic is defective already.
If your not inclined on electronics never do the repair itself, nasty voltages might caught you.
Posted on May 11, 2009
Philips/Magnavox 27TS54 C101/chassis 27B800-7562. Originally would not turn on at all. Replaced C506 (totally scorched) as other posters recommended. Now turns on but only bright white horizontal...
check for power supply for normal dc voltage..try resoldering the vertical output ic or test the vertical output ic dc supply..if there is..try finding some loose connection to the deflection circuits
Jul 13, 2011 | Philips TS2768C 27" TV
I have sound but have a black screen with a horizontal line across it
your picture tube may be malfunctioning -- all of the information for the screen is being squished into that horizontal line. If this is the case, you can buy a new picture tube and install it, but that would be the only fix. the only other thing I can think of that might cause this issue would be if you have a large speaker next to your TX. The magnet from a large speaker can distort the television, but it usually gives you a funny green distortion near the magnet without killing your whole screen so it seems unlikely that this is your problem.
May 26, 2011 | Memorex MT2271 27" TV
Hi....i have a horizontal faded green line at the bottom of a 42 inch full hd philips lcd ....the line started showing through hdmi cable(tried to replace the cable but in vain)...now the green line is...
Hi, Lines across TV are caused by leaky condensers. Horizontal lines mean the faulty condenser causing the lines is located in the vertical section of the TV's PCB. You will most likely have to get a technician to repair it unless you are very good with electronics and soldering. Shouldnt be very expensive as the components are dirt cheap, Its just the labour cost that may be pricey. Best of luck.
Apr 14, 2011 | Philips Televison & Video
Green line in middle of tv when switched on
Is there a picture with the green line going through the centre. If it`s just a green line with no picture, it sounds like the Frame (Vertical scan) Output IC has failed and possibly the safety feed resistor near the LOPTX. The reason why it`s a green line is to protect the tube from phosphor damage. The older TV`s would produce a VERY bright white line across the screen which could burn the phosphors withing the tube if left turned on in that condition. It`s not an expensive repair, but is it worth it with the price of Modern TV`s nowadays. If there is a picture with a green line, it may be due to phosphor damage, in which case, it`s a new CRT (tube). Ian
Jul 15, 2009 | Panasonic Televison & Video
Yellow stripe across middle of the picture
yes rteh color of the wires(ends)red,blue,green,sounds like they may ahve gone bad or are interchanged, what does it do with a dvd picture
May 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Color lines in tv screen
it's an lcd filter fault it's betwine lamp and screen before mirror, seems like u will need to replace it but it hard to say without look at it.
Mar 22, 2009 | Philips 55PW9363 55" Rear Projection...
Vizio P2 42 in. HDTV-Ready Plasma
Search Google "Screen Burn-In."
Mainly Plasma screens are affected by it.
Sep 20, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Green lines
This is the convergence amps going bad. You would need some tech experience. But could do it if talked throu.
Sep 11, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 27MS343S 27" TV Logo
205 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
