Question about Intel Pentium M 740 1.73GHz 533MHz 2MB CPU, OEM (RH80536GE0302M)
Keyboard problem My keyboard will not let my computer go on stand-by. I have removed the keyboard, reinstalled it and restarted computer. Still will not work. What do I need to to?
  • fougzki May 11, 2010
    Is that having a sticking key, or you don't set the setting on standby in its hotkey.
2 Suggested Answers
SOURCE: I still can't get my Fn key to unlock. I've tried
Change your keybord layout in control panel->regional settings.
Then if still same thn your laptop keybord has issue because anothr usb keybord works fine.
There is not issue with operating system you need to repair your laptop key bord.
If it is warrenty you can use warrenty
Let me know if you need further assistance.Thanks for using fixya.
Posted on Nov 22, 2009
New keyboard does not work
To connect or to disconnect the keyboard to a PS/2 port, follow these steps:
Shut down the computer.
Plug your device into the correct port. Make sure that the plug is pushed securely into the connector on the computer.
Restart the computer. Microsoft Windows detects the change, and then installs the drivers on the new port automatically.
If the issue continues to occur, try connecting the keyboard to a different computer. If the keyboard functions correctly on a different computer, the port to which the keyboard was connected on the original computer may be damaged. If this is the case, contact your computer manufacturer to inquire about how to repair or replace the damaged port.
If the keyboard does not function correctly on another computer, the keyboard may be defective. If this is the case, and the warranty on the keyboard is still valid, you can exchange the defective keyboard for a new keyboard.
If the keyboard works on another computer, go to Step 2.
Step 2: Download and install the latest keyboard software
Step 3: Manually reinstall the drivers
To remove and then reinstall the drivers, follow these steps:
Disconnect the device from the computer.
Turn off the power for the device, if the device has a separate power supply.
Open Device Manager. To do this, use one of the following methods:
In Windows Vista or Windows 7, click Start, type device in the Start Search box, and then click Device Manager in the Programs list. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
In Windows XP, click Start, click Run, type devmgmt.msc, and then click OK.
Double-click Keyboard, right-click the keyboard that you use, and then click Uninstall.
If your device is not listed, this means that the device was removed automatically when you disconnected the device. Go to the next step.
First, turn on the device, if you have to, and then plug the device into the computer. Your computer detects the device and then reinstalls the drivers for the device.
Jun 04, 2012 | Acer Computers & Internet
Don't have power on PS2 keyboard port
Click start control panel keyboard hardware make sure you have the right keyboard selected
or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers
click start control panel administrive tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver
this will apply to your mouse as well
if your computer came with a motherboard disc the drivers could be on it
diconnect the keyboard then reconnect it then reinstall the driver
make sure the lead has a secure seating if applicable or the usb device
or restart you computer tap the f8 key repeatedly to enter safe mode where the only things working will be your keyboard and mouse allowing you an attempt to repair your computer
hope this helps you
Dec 26, 2011 | EliteGroup P4M800PRO-M Motherboard
How do you power on the keyboard
what sort of keyboard on a laptop or desktop computer ??
Click start control panel keyboard you can change your settings there
click start control panel keyboard hardware then properties you hould see driver details and have options to,update driver,roll back driver,uninstall
you might have to uninstall your keyboard restart your computer then reinstall it
click start control panel administrive tools computer management device manager scroll to keyboard you might see a yellow question mark ? right click update driver
hope this helps you
Sep 22, 2011 | Computers & Internet
I can't get my wireless keyboard to work even after trying everything can think go or told by Windows XP. Anything else i could try? Lee
First try changing the batteries, reconnect the dongle or the connection device of your wireless keyboard and mouse, then restart your computer. If the step wont work reinstall the Bluetooth/Infrared software driver the wireless keyboard and mouse then restart the computer. If this fails still look under Ad/Remove programs if you have a Setpoint installed then remove it and restart computer, both or at least one of the devices should work. If one or both wont work then you need to contact the manufacturer and have the defective device/s be replaced. Just a heads up, they may ask you to reinstall your operating system / do a reformat of your computer so you need to back up your data ahead of time using a wired keyboard and mouse. Have a nice day ahead!
Aug 13, 2010 | Logitech Wireless Access Duo Optical...
New netbook. Attempting set-up. Keyboard keys don't work. Nothing gets typed in. Just hear a click.
Disable the Numlock key and check if the same issue persists. You can reinstall the Keyboard Driver to resolve the issue. Uninstall the Keyboard Driver from the Device Manager and restart the Computer. The Computer will reinstall the Keyboard Driver when you restart the Computer automatically.
Jun 18, 2010 | Computers & Internet
Unresponsive keyboard
Please uninstall the Keyboard Driver from Device Manager and then restart the Computer. The Keyboard Driver will be reinstalled once you restart the Computer and check if the same issue persists.
Jun 30, 2010 | Computers & Internet
The keyboard is locked
Dear Sir,
plz folow this step to unlock keyboard
  1. Step 1 Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
  2. Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
  3. Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
  4. Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
    For desktops, disconnect the keyboard from the desktop. Reconnect after one or two minutes.
  5. Step 5 Reconnect the power adapter or AC cord. Start your computer.
  6. Step 6 If your keyboard is still locked on a Dell desktop, disconnect the keyboard. Restart your computer and reconnect the keyboard after the system boots. Allow your operating system to recognize and reinstall the keyboard.
Thanks For Your Time,
Apr 13, 2010 | Dell adamo PC Notebook
Dell keyboard locked up
Dear Sir,
PLzz folow this step to unlock your keyboard
  • Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
  • Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
  • Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
  • Step 5 Reconnect the power adapter or AC cord. Start your computer.
  • Step 6 If your keyboard is still locked on a Dell desktop, disconnect the keyboard. Restart your computer and reconnect the keyboard after the system boots. Allow your operating system to recognize and reinstall the keyboard
  • Thanks For Your Time.
    Apr 10, 2010 | Dell 0Y3740 Keyboard
    Keyboard is not responding it does sometimes then stop again
    Step 1
    1. Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
    Nov 15, 2009 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
    My keyboard on my laptop wont work at all!!
    1. Turn off the computer, disconnect all external mouse devices, keyboards, USB devices, and the port replicator or docking station, and then restart the computer.
    2. Ensure there is not any debris between the keys or liquid spilled on the keys.
    3. Verify that the NUM LOCK is turned off.
    4. Remove all the accessibility options for the keyboard in Control Panel.
    5. Remove and reinstall the keyboard driver.
    6. Using the System Restore utility, restore the computer to a time when the keyboard was working correctly.
    7. Reset the BIOS defaults.
    If the keyboard does not work in the BIOS Setup utility, the issue is likely a failed keyboard and service may be required.
    Oct 21, 2009 | Toshiba Satellite Pro L300D-EZ1006V...
    Intel Pentium M 740 1.73GHz 533MHz 2MB CPU, OEM (RH80536GE0302M) Logo
    22 people viewed this question
    Top Intel Computers & Internet Experts
    Tony
    Alun Cox
    David
    David
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
