Question about Whirlpool WTW5100SQ
PLEASE HELP!!! SINGLE MOM OF 3 STARTED A BLEACH LOAD OF LAUNDRY BEFORE TAKING KIDS TO THE PARK AND CAME HOME TO FIND THAT THE WASHER ONLY FILLED AND NOW IT IS NOT WORKING. WILL NOT DO ANYTHING!!! I CHECKED BREAKER AND OUTLET BOTH ARE FINE. I HAVE A WHIRLPOOL WTW5100SQ0 TYPE111 TOP LOAD WASHER. IS THERE ANYONE THAT CAN HELP ME???
  • laurahart May 11, 2009
    THANKS TIM!
    President:
  • 1,136 Answers
Hi, It could be the lid switch. Check and see that it didn't break. (Sometimes the lid hinge will losen up and not activate the switch.It is locate under the control panel. FIRST unplug the washer!! To remove the control panel, you need to locate the two phillips head screws at the rear of the panel n each end. Remove those screw and the consel will raise up and hinge is place. The lid switch is to the left side and is mounted to the top of the cabinet. It is a quick connect switch. You need to either check continuity on the switch (Should be closed when the switch is engadged). You could also use a jumper wire plugged into the connection for the switch =, plug the dryer in and see if it starts. I know I have given you a lot of info. Please let me know if i can help you further or clarify anything I have told you.
Thanks
Vic
Posted on May 11, 2009
  • 3 Answers
There is a screen on the hoses at the back of the machine, it may be clogged and needs to be cleaned out
Posted on Jan 01, 2010
  • 234 Answers
The problem is most likely a faulty lid switch.
Here is a link to the part
http://www.partselect.com/PartDetail.aspx?Inventory=886960&SourceCode=1
If you need more help, post a comment.
Thanks,
Tim
  • Tim Phipps May 11, 2009
    You are quite welcome. Let me know how your problem works out.
    Tim
I keep getting "Sud", "F 35" errors when trying to run washer... please help!
you are using too much soap-are you using he detergent-turn it off drain and rinse-after you do laundry-clean washer with bleach only
Oct 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water won't drain and washer does nothing
pump is stuck or bad located under washer most are not hard to change
Dec 06, 2009 | Dryers
Is there a filter that can be gotten at to clean? Reason -- very stale water smells are staying in the laundry now. Thanks for your help! ~~Canadian Query
I would try to run a cycle with a very strong clorox solution through your washer. It may be the easiest way to fix that.
Nov 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Over-filled bleach dispenser
hi ..well theres no electrical parts under bleach dispencer,,your problem lies somewhere else..the most 3 cups will do is bleach your floor...now first try and change outlet...if you need to you can remove three screws on top rear,,unplug first..and do a little blow drying ...also check for any burnt or grounded connection,,
Jan 04, 2009 | LG WM-2277HW Front Load Washer
Odor
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Dec 17, 2008 | Maytag Atlantis MAV6000 Top Load Washer
DARK CLOTHES END UP WITH BLEACH DOT STAINS
Hello sa-kap,
yYu said,
Hi, I have a top loading Kenmore Elite washer (don't know model #) from the year 2002. It has the automatic bleach dispenser. The problem is that if someone has washed clothes with bleach sometime during the day and someone else comes along and washes dark clothes, the clothes get ruined with dot bleach stains. It appears that the bleach remains in the washer. Any tips or do I need to buy a new washer? Any help would be greatly appreciated. Thank you
V.C.My problem is similar to that which VCasabona is having. Not just dots occur but often big splotches. It may not even be just a colored load following whites on the same day but, on occasion, it occurs on the next laundry day, a week later with the first load that is not the whites with bleach. Also, my wife adds the bleach to the filled washer (old school, I guess), rather than pouring into the dispenser. My water pressure, which is not at issue, is not what I need to address to remedy the situation. I have noted that the ledge that is part of the floating tub had some build-up of deposits, some of which may have been bleach. These I've reached in with damp cloths and removed as best I can. I've run full, empty loads through hoping this would flush out any lingering bleach. Because the occurrences run intermittently from infrequently to frequently I cannot be sure if any of my attempts to remedy the problem are having any effect. I've guessed at the model # of the Kenmore top load washer we own since Dec of 1999
Sounds like some water is remaining in the tub after the pump gets done emptying the washer.
So its the pump!
The Kenmore Elite is a good washer and I believe worth fixing!
Unless the cost is half the price of the cost of a replacement.
Bless You,
Please write me a good rating before you sign off.
Jun 20, 2008 | Kenmore 24032\24036 Top Load Washer
CLEANING OUT CAT DANDER ETC FROM WASHER
Quenie, vinegar will not harm your washer at all. Place it in the detergent side of your dispenser and run a Hot wash cycle. Don't mix chemicals, though... if you choose to clean your machine with bleach, for instance, don't use additional cleaners along with it. Vinegar only, bleach only... you get the point.
You may want to run a "water only" Hot wash cycle with bleach (no clothing/towels) after your Son has finished his laundry. This may help alleviate your allergy problem.
For regular maintenance on your washer, you ought to try something like this. It'll keep your washer smelling great.
Nov 22, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Liquid Bleach dispenser doesn't work correctly
This may not be relevant, but by design, bleach does NOT dispense in the Buly/Bedding, Kids Wear, and Silk/Ultra Delicate cycles. If you try to use it, it remains in the dispenser.
As for the yucky smell, leave the door open when not in use.
Nov 16, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Black spots on white laundry
is the washer noisey when spinning? If so its probable that the main bearings are worn, & losing the original grease into the wash tub. At 10-14 yrs old its probably not woth fixing (assuming parts are still available)
Oct 19, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool WTW5100SQ Logo
181 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
