Question about iLO DVDR04
Only view in black and white on my ilo DVD R04
I have an ilo DVD R04 recorder and I must of pressed something wrong and now I can only view in black and white...HELP
  • fougzki May 11, 2010
    Did you check your broadcasting setting something about PAL/NTSC?
I was having the same problem. My DVDR04 was working fine. And after about four months of not using it I desired to use it. Turned it on and everything was in black in white. After searching on line and e-mailing Ilo which I never got an answer. I finally tried using an RCA video (Yellow) cable on the line out video jacks, replacing the line out S-Video jack/cable and it worked fine back in color right away.
Posted on Jun 18, 2009
  • rpar Jan 04, 2016
    Do a factory reset! First check to see if you have your rca yellow jack in right plugin
Won't record on DVD+R discs.
These ilo R04 only record on 4x speed or slower, the new 8x or 16x won't work or will damage laser.The new variable speed discs work,these say 1x-16x.
Some brands of discs won't work in Ilo's.Try name brands disc like Sony, cheap brands often won't work.
Have you cleaned laser use commercial disc cleaner?Laser can be manually cleaned with a Qtip soaked in rubbing alcohol but this requires opening dvd burner.If you do this make sure electrical plug is pulled, laser will cause serious burns if you remove top while still plugged in.
Jul 27, 2009 | iLO DVDR04
Panasonic dvd recorder dmr-ex75
Change the AV settings on the DVD or TV to be the same format. Feeding AV into an AV-S gives B&W
Sep 16, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Ilo
I have the same problem when using the coax hookup. try using another input and see if that helps, I no longer use the tuner, just hook my tv up to the inputs and set the tv on what I want to record, same with vcr tapes etc.
Jun 07, 2008 | iLO DVD Recorder DVDR05
Setting the time on my iLO DVDR05 Recorder
1 Press Setup to enter the setup menu.
2 Press the up/down keys to select GENERAL, press enter, Use up/down keys to selet clock setting. press enter.
3 Move to the field to be edited using the up/down keys
4 use up/down keys to increase or decrease the value of the field.
5 To exit a field using the right/left keys
6 Press return to exit the clock settings menu.
Select time format from the menu and press the right arrow key. Use the up.down key to pick hour mode(12hr or 24 hr).
Thats the instructions from my manual.
Mar 18, 2008 | iLO DVDR05 DVD Recorder
I purchased the DVDRo4 and its been pretty reliable so far.
These R04 are fickle,some Brands of DVD discs won't work in ILO,try another brand.Also clean laser in iLO it may be dirty,use commercial cleaning disc,put a drop of rubbing alcohol on brushes.Do not use any other chemical.
It is possible you laser is defective or starting to go.If that's the case you need to replace burner/loader.
Some dvd recorders formulate a little differently,I have made recordings in my iLo that won't work in all brands of players/recorders.
Aug 14, 2007 | iLO DVDR04
Mr ilo dvd R04 recorder is locked at the hello screen!!!!
The unit is not finishing the start up diagnostic. This could be forseveral reasons. The most common problem with the Ilo04 is power supply. On the power supply board check the two big capacitors to see if they are swollen or leaking. If so then change them and try that.
Jul 13, 2007 | iLO DVDRH04 DVD Recorder
LVW-5005X DVD Recorder setup tv tuner
You have the wrong firmware,or cd is corrupted.These Liteon recorders have had some issues with the timers.The 5005xa can actually be transformed into the Ilo R04.Look on internet the Wizard has free firmware for your unit, look for iLO R04 which is almost identical to your unit.
If the remote is broke they are easy to replace ,if the recorder is a 5005xa the remote is a clone to ones used in the iLO RO4,used ones can be bought on Ebay for $10 to $20.If it is 5005XSA use the Liteon Rm 51 remote.The Gateway AR 230 recorder and some of the Akai remotes are clones to the Liteon5005XSA remotes.
Jul 10, 2007 | Lite On LVW-5005X DVD Recorder
ILO tv
you are not saying if it is with or without remote that you cannot turn up or down your volume please repost again for help.good luck.
May 14, 2007 | iLO V27DMBX Television
When I burn a dvd on the ILO it works fine, but can not be viewed on any other dvd device.
check the program you are using it might not be compatible to other system.
Feb 16, 2007 | iLO DVDR05 DVD Recorder
Ilo DVDR05 Firmware help
Goto www.cyberfixer/ilodvdr05_repair_guide_FREE.htm At the very bottm of the page there's updates you want.
Jan 27, 2007 | iLO DVDR05 DVD Recorder
iLO DVDR04 Logo
103 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Radames Pagan
Radames Pagan
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
