Question about Refrigerators
Ice maker The ice maker stopped working. It stopped feeding water into the freezer. The day before, I had emptied the ice from the bucket for an ice chest. The next day there was no ice. The water dispenser still works. The ice dispenser still move to deliver ice accept there is no ice to deliver.
    President:
  • 1,136 Answers
Hi, it sounds like made the inlet tube to the icemaker is frozen up. First thing to check tho is that the water valve to the icemaker is ok. If you take the water line off of the icemaker valve, you should be able to blow through it. If you cannot blew through the inlet line that leads to the icemaker tube, it is plugged with ice. You cn thaw that tube out woth a hair dryer.
If I can help further, please let me know.
Thanks
Vic
Posted on May 11, 2009
Having problems with ice maker. Was slowing down it seemed in making ice... and now it does not seem to be making ice. I tried the fast freeze ... still no ice. Obviously must be a water problem... the...
I had the same problem and the Samsung customer service person told me to set freezer to -2 degrees, remove the ice bucket, press and hold test/reset button (look for arrow on top right of ice maker inside the fridge), replace the ice bucket and wait 24hrs.
Dec 02, 2010 | Samsung RFG297AARS (285 cu ft) Bottom...
Ice maker has ice motor doen't dump the ice
Your ice-maker may need to be "hard-reset". To do this, perform a manual-defrost by emptying out the freezer (and fridge) and shutting all power off to your unit for several hours (at least half a day unless you can be sure the temp in the freezer has fully reached ambient. Next, with freezer empty, restore power, make sure the "ice" setting is set to off, then set the forced power-freeze mode (you can refill the fridge, but leave the freezer empty for now. When the power-freeze completes (at least 2.5 hours) you can refill the freezer, set the "ice" mode to block/crushed (IE something other than off) and then hit the "black reset button" to restart the ice-maker. IF it still will not dump the cubes then the ice sensor/control board may have failed.
May 24, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
My ice maker stop working
Knowing how an ice maker works can greatly increase your ability to diagnose and repair it. Just like vehicles, ice makers all may look different but they all work on the same princible. A thermostat starts the ball rolling, turning on a motor and a heater to loosen the ice, as the ice dumps a trigger fires up the water valve and refills it. The whole thing comes to a halt and waits till the thermostat gets satisfied once again.
So what can go wrong? The ice maker will give a clue. If their is ice in the ice maker but none in the bucket that is an ice maker failure. If the ice mold is empty and no ice in the bucket then the water valve is bad.
One thing you can do is get a bottle of water and fill the mold. If it kicks out a batch but no more, water valve replacement needed. If it don't then ice maker problem. If you have shelling or fouled cubes, look for dirty coils below the ice box that make for faulty cooling. Ice forms at 32f but ice mold tstats don't kick in the afterburners till 25f. I have some more detailed tips with videos and manuals: HERE
Jan 10, 2010 | Freezers
Ice maker stopped working
if there is ice in the mold then the problem is the ice maker unit , replace the ice maker for the fix.
Phil
Jun 10, 2009 | KitchenAid KSRG25FKSS Side by Side...
Ice maker flooded top freezer compartment
It may be just the water control valve on back of refrigerator. Put tap water in ice maker and lower lever for on. After ice is made, does it drop to tray? At this time when empty is the time the control valve is asked for water. The problem could be in valve on back or the inside ice maker itself. If you can try a few test with me I will help you locate the problem. Let me know what you find as I go through this with you. Sea Breeze
http://servicepartstec.blogspot.com/
May 19, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
The icemaker in my Bauknecht KGN 7010 F/F has stopped making ice
First you need to find out if the lie is blocked. Disconnected water feed and try to run water through it into a bucket or sink. If you get water it is a valving problem. Also make sure the filter is clear.
Dec 29, 2008 | Freezers
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Feb 06, 2008 | Samsung RM255LASH Side by Side...
Ice maker is not working but water dispenser is.
Try the following check:
First make sure that the temperature in the freezer is 5 degrees or below.
Self-Diagnostics
Unplug the fridge and then plug it back in.
If the compressor is running when you unplug it make sure that you wait 15 minutes before you plug it back in.
You will then have 60 second to open the freezer door and 2 second to view the LED output code.
Ice maker check 3 pulses pause 3 pulses
Optics receiver 4 pulses pause 4 pulses.
Optics emitter and receiver 2 pulses pause 2 pulses.
All good 5 seconds on
Dec 28, 2007 | Whirlpool ED5SHAXM Side by Side...
Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Nov 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
279 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
