Question about SanDisk Sansa m230 MP3 Player
Not enough space for music db
When i turn it on it loads up and then it says so room for music db please free 8mb. After that it goes to where it is plays music but it says no files. It started after i downloaded songs. And there were already songs on it.
  • 626 Answers
Your device has too much music on it.
You need at least 8MB free in order for it to build the "database".
Connect the device to your computer, delete 10 songs, then re-start the player and you should be back to normal.
Best of Luck.
Posted on Oct 13, 2007
2 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: Not Enough Room For Music DB.. Please Free 8MB? ...HELP
Get the firmware upgrade from SanDisk's website:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jul 05, 2008
Says" not enoughh space for music db please free 8 mb" wont let me put music on or delete
Try removing the microSD card then delete something from the e250's internal memory to free up 8MB.
Feb 07, 2010 | SanDisk Sansa e250 MP3 Player
Sandisk m230 MTP DB mismatch...
Here is a link to get the manual:
http://www.sandisk.com/Retail/Default.aspx?CatID=1304
On page 30-31 it explains how to RESET the unit to the factory defaults. If nothing else, I believe that will clear your DB Error.
Jun 07, 2009 | SanDisk Sansa m230 MP3 Player
Cant load memory
put it into the computer and delete some things on it its just to full
Apr 26, 2009 | SanDisk Sansa m240 MP3 Player
Sansa m230
whenever i turn on my sansa m230 mp3 player, it displays the message, "not enough space for music DB, please free 8mb." And so i plug it into my friends computer and when i open the music folder on the device, its empty, even though it says that there is quite a bit of space used up. Do you have any answers?.
Sep 07, 2008 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa
try plugging it into the computer and viewing at as a hard drive, then you will probably be able to see everything on the player
Mar 19, 2008 | SanDisk Sansa m240 MP3 Player
Not enough space for Music DB, please free 8 MB
The Sansa m250 requires a separate folder to load your songs to in order to achieve the full 2 GB. Set your USB to MSC. Plug it into your computer. Create a folder TUNES. Then drag and drop your mp3 or wma files to this new folder.
Jan 28, 2008 | SanDisk Sansa m250 MP3 Player
No files
The device needs at least 8MB to build the Music DB (database or GUI). You need to manually delete some files from the device. You will need to connect it to the PC and open it in My Computer>Device Name>Music Folder. Delete a few songs, disconnect and restart the device. You can add to the question if you need more assistance. Best of Luck.
Sep 30, 2007 | SanDisk Sansa m230 MP3 Player
MTP DB Mismatch format?
i have the same problem...but i have a deferent model....and what is a scan disk
Jun 12, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
159 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
