Question about Dometic Rooftop RV Air Conditioner
Dometic A/C Vibration
My 8 year old unit just developed a bad vibration, don't know if it is the motor going bad or if there are dirt dauber nests on the squirrel cage. Problem is, I can only see a portion of the inside of the cage, none of the outside. It is surrounded by thick styrofoam, and I can't see how to get the fan out. Is there a way to do it without tearing up the foam shroud? Thanks.
  • Gary Scott May 11, 2009
    I removed the top off of the unit and cleaned dirt daubers from the squirrel cage. On the motor I noticed it had a shaft on each side - one going to the squirrel cage and the other to a sealed compartment. Does the sealed compartment have another squirrel cage? The unit works however it really vibrates.
    Scholar:
  • 152 Answers
Sounds like the fan bearings are on the way out , these units are designed to be removed to be opened and usually they op from the part that touches the roof of the car not the top so remove it first might be a start
Posted on May 11, 2009
My dometic aircon is very quiet outside but inside very noisy and vibrates throughout motorhome
You may want to remove cover on roof and inspect for mudwasp nests on shafts, fan blades, blower wheel etc. Quite common for that to happen and cause vibration. The nests throws off the balance.
Mar 06, 2013 | Heating & Cooling
My dometic ac model 57915.531 suddenly developed
The 20 amp will be sufficient, you'll just need an adapter to match to your plug.
Jul 31, 2010 | Dometic 57915531 Air Conditioner
Fan motor vibration
Could be motor mount bushings, or bearings going in motor, but another common cause is mud-wasp nests, or other debris on the blades of your condenser fan. You'll need to shut off power at breaker, remove cover on roof unit, and have a look, and clean off as necessary. While power is off try moving motor shaft up and down, side to side, to feel if there is excessive play that may be the cause. This will also allow you to have someone turn unit back on, while you stand back with cover off and observe for possible causes of movement. Turn power back off at breaker for re-install of cover.
Jul 05, 2010 | Dometic Rooftop RV Air Conditioner
I have a dometic roof mounted air conditioner 3300 series and it developes this vibration like a real loud hum
sounds as if the fan motor bearing have worn out lettin the fan cage wobble upon reaching full speed hence the vibration. There also could be build up of debris in the fan assembly. Good luck on your repairs
Dave
Oct 16, 2009 | Dometic Rooftop RV Air Conditioner
RV ac is vibrating
Take a good look at fan blade for a crack in one or more, as well as turn unit on & watch for vibration , then take a look at mount bushings on all items. Also with fan off (obviously) check shaft for movement, side to side, up & down, in & out. Your gasket between roof should only be compressed approx half it's original thickness. Some manufacturers tighten them down too much and can be a source of vibration as well. Not expensive or hard to change. Don't forget blower wheel as well.
Jul 21, 2009 | Dometic Rooftop RV Air Conditioner
What causes the air conditoner to vibrate? will run okay for up to an hour, then starts vibrating on high setting. On low setting it's not as bad, but if you feel the coach side, you can feel a vibration....
take the covers off and look for dirt dobers nest, they are made of mud like stuf. spray some water threw a squart bottle use needle nose and a screw driver to bust them. this hapend to my home and motor home.... bill
ps might be some other debree in the fan.. take a look you will be suprised how easy it can be.
Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
AC unit on Viking popup is loud and vibrating
take the cover off the front of unit and look down inside at the blower wheel see if there is something in it
Jan 22, 2009 | Dometic Rooftop RV Air Conditioner
Duo-therm a/c
We had this issue also and dirt daubers had built a nest on the end of the fan blade
Jul 28, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
484 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
