Alcatel Newbridge MainStreet 3600 Multiplexer
Problem for Alcatel Newbridge MainStreet 3600 Multiplexer
What is the function of expended card.how many band width of mux 3600 single shelf,doul shelf.27LC car...
By shamas_pdl on May 11, 2009
why we use expanded card in mux 3600?and DINC card use for how many data soport.and which modem sport this card?
Solution #1
posted on Jun 25, 2009
Somewhat Helpful)
lenconradie
Rank: Guide
Rating: 88%, 4 votes
You mean Expander Card.
The original chassis was fitted with only 6 slots and thus the control card can only manage these 6 slot single bandwidth. (2Meg per slot). As the 8 slot chassis was develop it was I think cheaper to build a new card as to build a new control card to manage the other two slot (7 and 8). So the expander card was build and to extend the shelf to 16 slots you do need the expander card fitted with a +16 expander module so that you can manage both chassis and provide double bandwidth per slot (4 Meg per slot).
There are two types of DNIC cards, nl. 6 circuit and 12 circuit. This card must be fitted with a DSP module if you want to configure the ports for 128K. Only 26XX DTU’s will work with this card. This card and DTU’s has been discontinued.
The 27LC2 card is a 6 circuit card and only 27XX and 2751/2/3 DTU’s will work with this card. This card and DTU’s has been discontinued.
The replacement for this card is the 27LC3 card and 27XX and 2751/2/3 DTU’s will work on them.
The 3600 mux is a single shelf which can be extended to a dual shelf. Each slot using a expander+16 can deliver 4 Meg. If only a single shelf is used you can fit a +8 module on the control card to provide you with 8 slots and 4 meg per slot.
Was this helpful?
Yes
No
Popular Solutions for Alcatel Newbridge MainStreet
Questions and Unsolved Problems for Alcatel Newbridge MainStreet
Do you recommend Alcatel Newbridge MainStreet 3600 Multiplexer?
Answer
Answer
can we incoperate adsl on newbridge ?can we configure newbrige mainstreet 3600 to opperate on adsl... (More)
Answer
Hello there, I'm looking manual for operation and manitenance to troubleshoot the DACS. Appreciate... (More)
Answer
on a mainstreet 3600+ oc-3 card what is the receive min/max levels and what is the wavelength band... (More)
Answer
How to reset 90-0667-01 Controller Database to default setting I can't Access the spare controller... (More)
Answer
When I Check for list of CPSS connected on my DXX node , I found one CPSS connected to Serial Port 1... (More)
Describe your Concentrators and... problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Concentrators... Experts
Top Computer & Laptop Repairmen
in , MD
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
