Question about Maytag Neptune MDG9700A Gas Dryer
Maytag Neptune Dryer sometimes dries sometimes not?
Dryer sometimes dries sometimes damp?
    President:
  • 1,136 Answers
Hi, Have you checked the venting that goes outside. Most of the time, this helps especialy because it is electric dryer.
If I can help further, please let me know. Thanks
Vic
Posted on May 11, 2009
Maytag won't dry on any cycle
if you have gone that far you have it fixed
since you diagnosed that there was flame you can fix this really easily
unplug the unit
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47083&diagram_id=678789#d678789
look for the two parts 7 and 8
those are going bad and will need to be replaced
hope this helps
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer not drying clothes properly
Have you tried cleaning off the sensor? Many of the newer dryers have a sensor that, when dirty, can no longer determine the moisture level of the clothes. Some manufacturers recommend using a light vinegar solution. Check your owners manual for location and recommended cleanier. Also, make sure your exhaust hose is clear of obstructions and that you vacuum out your lint trap area. HTH.
Aug 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Jun 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have a maytag intellidry dryer and when finished with drying, clothes or whatever are still damp
Check the ventilation for lint. You may need to replace the duct vents if you have any. The lint tends to build up and prevent the dryer igniter from staying on thus the clothes do not dry all the way.
Apr 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer purchased 5 years ago - panel completely lit up
you may have it in advertising mode
Try Pressing the damp dry and sensor dry keys
for 5 seconds will take it out of the
Advertising mode.In Advertising mode No functions will be run
except illuminating the LEDs
Let me know if it works
Oct 08, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Intermitten heat
We have a Neptune Gas dryer,my husband changed the belt cause it was making noise,now the heat hardly works,i put the dryer on for 40 minutes and usually it is dry,now i did that twice and clothes is still damp,would you know what the problem is please help
Jan 12, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune W/D (Stacked) Drying Irregularly
Mj, 90% of the time long dry times are caused by a pinched or clogged vent. Other things that could be causing this are: cycling thermostat trips too soon, if your dryer is a gas model, weak gas valve coils, drive motor centrifugal switch not allowing voltage to the gas valve or heating element. Check the harness to the motor to make sure it is on tight. Catriver...post back.
Sep 25, 2006 | Maytag Neptune MLE2000A Front Load Stacked...
Maytag Neptune MDG9700A Gas Dryer Logo
203 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
