Tankless promotion is certainly slick and inviting...
-Tankless gas save about $100 per year vrs pre-april-2015 gas water heater for 'average family of 4.'
-New energy standards will reduce the expected savings to $70/ per year.
-Tankless electric cost about $100 more per year to operate than ordinary electric water heater for 'average family of 4'
-Do-it-yourself repairs are generally not possible with tankless.
-Tankless gas require larger vent and larger gas line, and a condensate drain.
-Whole-house Tankless electric will probably require a new electric service panel
-Tankless require yearly deliming/ descaling of heat exchanger... and heat exchanger will lose efficiency over time because of scale... even if unit is delimed each year.
-Electronic controls are vulnerable to surge
-Only the alloy heat exchanger has long-term warranty, but otherwise the warranty is same as typical tank heater
-Tankless cannot be exposed to more than 11 grains hard water or parts can fail within 2-3 years
-Tankless might not be able to keep up with higher temperature setting needed to fill very large tub (or any bathtub) if incoming water is too cold due to winter conditions. Etc.
Example Rheem tankless resource:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pro-n-con-for-tankless-water-heater.html
Example installation for tankless electric
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
Gene
Water Heater Timers Save Money If you need further help, I’m available over the phone at
https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
This question was posted under the wrong heading. But there doesn't appear to be a way to delete or correct this post. Please advise if there is a way to delete or correct misplaced entries.
Thanks for your comment. I've had a tankless water heater for 18 months and it works well most of the time; but it's not as reliable as my old tank type heater. The tankless heaters are technically complicated and difficult to maintain and repair. I was thinking of getting an inexpensive, tank type "backup" water heater. The no-frills tank types seem to work well for years on end. My tankless water heater consumes a lot less energy; but it's also subject to unpredictable, inconvenient down time and high repair costs.
