Sharp Aquos LC-37GD6U 37 in. HDTV LCD Television
Problem for Sharp Aquos LC-37GD6U 37 in. HDTV LCD Television
Sharp Aquos LC-26D4U sound problem
By too oh ate on Oct 12, 2007
I have the LC-26D4U Sharp Aquos model tv. Everything has worked fine for the 18 months or so that I've had it but now it seems as if something is internally wrong with the speaker connection. When the TV first turns on I hear a popping sound come from the right speaker. The first time this happened I turned the TV on and off a few times and the problem fixed itself. Since then, however, I hear that popping sound (just from the right speaker) and I get no sound. When the sound did work, both the left and right speaker worked fine and I still only heard the popping sound from the right speaker. I have tried different connections (HDMI, component, regular video/audio cables) and still nothing. It is certainly something internal that is the problem and I was wondering if you have heard of this problem before and know of a solution or advice. I am out of warranty and do not want to pay a few hundred if this is something I can easily fix myself.
Thanks for any help.
Clarification Request
Posted by estore on Aug 14, 2009
my 26D4U sound went dead. No sound available to drive ext amp either. Where is the board described in Solution #10 located?
Posted by Firerider on Feb 24, 2008
Did anyone ever find out anything about this issue? The same thing has happened to us here -- right speaker popping, have to reboot box constantly to get sound to come back....
Thanks!
Same Problem
May 16, 2009
-   Today sound stopped at our Sharp Aquos LC32X20E. This after purchased in January 2008; theoretically out of warranty. However, we would expect that Sharp repairs it for free since many other face the same issue.-   Guest
Apr 11, 2009
-   Experiencing the same problem with the Sharp LC37DU
the sound no longer works after 36 months of use
Need advice on repair
-   Guest
Apr 08, 2009
-   I'm having the same problems. It started last week when the sound would not come on, then when I turned it on/off a couple of times it came back on. Now the sound does not work at all. I have had this TV for about 18 months as well. Sharp needs to recall! -   ses4bama
Apr 06, 2009
-   Does anyone have the technical service bulletin on this I would like to get a copy. Please email me at sognibene@gmail.com I would appreciate it.
-   sognibene
Mar 24, 2009
-   I have the LC-26D6U and too have lost the sound. Sometimes we can tap the back of the TV and then turn it off and back on and the sound will work. It seems to get worse and worse; lately we can rarely get the sound on. It all started when the unit was past warranty, but less than two years old. Won't be buying another Sharp any time soon! -   Guest
Best Solution
posted on Apr 02, 2008
Very Helpful)
Guest
Rank: Apprentice  Televisions & Videos  Expert
Rating: 0%, 0 votes
i had the same problem lc26d4u. called sharp and they gave me a place to send it to . cost me 260.00 estimate to fix tv. have not heard from them since. but heard they may have sent the tv to the manufacturer. same sound board problem
Solution #2
posted on Mar 21, 2008
Helpful)
za21790
Rank: Apprentice
Rating: 93%, 8 votes
i have a simlar problem with my lc-26d4u. i bought it in april of 2006. i had absolutely no problems until last week when the tv had no sound at all. i plugged in my dvd to see if this was a problem with my cable setting but this was not the case. the problem was obviously internal.
i called the sharp authorized technicians. they told me this was a common problem with this model and the only solution was a company upgrade of the soundboard which would cost ME $425!!!
I believe this is ridiculous given the fact that this is a problem not only prevalent on this message board but ALSO WELL KNOWN and recognized by Sharp themselves. I believe it is unfair to pay these costs. Have any of you approached the company about this issue???
Was this helpful?
Yes
No
6 people thought this was helpful
Solution #3
posted on Mar 09, 2008
Helpful)
rsuchowi
Rank: Apprentice
Rating: 89%, 15 votes
I have experieced the exact same problem with a LC37D6U. The problem fixed itself a few times by turning on and off, but now the sound is just dead. I have bypassed the internal sound by connecting the audio outputs on the TV to the stereo and going into the TV's menu and changing the sound output from fixed to variable so I can use the TV's volume control for the sound.
I have recently run into problems with other electronic equipment notably PC video cards and PC motherboards where just around 18 months capacitors bulge and leak and in some cases explode. I would not be supprised if these TV's are suffering from the same problems that I have seen on other electronics.
Was this helpful?
Yes
No
5 people thought this was helpful
Solution #4
posted on Jun 16, 2008
Helpful)
tjrose869
Rank: Apprentice
Rating: 88%, 3 votes
I have the same problem "lost audio complete" and at the bottom of the screen it will shift to the right for a split second. I bought my 32" in 2006, at the time I was a sales man and sold allot of them to customers. :(
I have found out that the heat sink on the A/V board has a Jell pack that becomes conductive after a while and damages A/V board "the Technician that came to my house told me that's a common issue with the Aques 24" - 42" TV. I bought the extended warranty and I had it replaced, within 2 hours it lost the audio.
sharp did not figure out the problem until it was too late the A/V board is a removable board and their answer is to replace the board, forget about it and hope it doesn’t happen again.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #5
posted on May 10, 2008
Helpful)
BlueScreenEr
Rank: Apprentice
Rating: 86%, 3 votes
Same problems as everyone else, no sound a few months after warranty expired. I bought some high quality computer speakers (Altec Lansing VS4121) and connected them to the sound output of my TiVo. I have to manually switch the wires when I play a DVD and there’s no remote volume control, but it’s cheaper and quicker than replacing the soundboard.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #6
posted on Jul 07, 2009
Very Helpful)
cali1111
Rank: Apprentice
Rating: 100%, 15 votes
GOOD NEWS - - According to the Sharp Technician I just spoke with a "Service Bulletin" went out to all their techs about the sound issue on these Sharp Aquos. I'm having the exact same sound probem and I'm in the process of having the technician come out at no charge so call the number given in Solution #6 and #9 (1-800-237-4277) and keep pressing #1 until you get a technician. Have your serial number ready and they will need your name, address and telephone #. They will then give you a case number and transfer you to dispatch (which closes at 5pm central). Thanks everyone for your help and posts - you made our day!!!
BTW - We also have the problem of the TV turning on and off by itself but the technician said they had not received a service bulletin about that yet.
Was this helpful?
Yes
No
15 people thought this was helpful
Solution #7
posted on Jul 04, 2009
Very Helpful)
RossComer
Rank: Apprentice
Rating: 100%, 10 votes
This is a common problem with Sharp Aquos TVs and just started happening with my 32" LCD. Per craig3215's suggestion below (from Jun 26, 2009), calling Sharp at 800-237-4277 (and pressing "1") immediately got me to a technician who said "It's a common problem with these TVs so we are handling them out of warranty." They take your name, address, and phone number, give you a case number, and send someone out to fix it for free.
In the meantim, attaching a set of powered speakers to the Monitor Audio Out can get you by until the technician comes. You can go to the TV menu and change the Audio Out to Variable if you want to control the external speaker volume from the TV volume.
Was this helpful?
Yes
No
10 people thought this was helpful
Solution #8
posted on Jun 26, 2009
Very Helpful)
craig3215
Rank: Apprentice
Rating: 100%, 8 votes
Thanks to the avsforum thread I did the below, they treat it like your under warranty
Thanks to all the info on this thread, I got the sound on my LC32D6U fixed for free. Even though the TV is out of warranty, Sharp considers it under warranty for the sound problem. The number i 800-237-4277.
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #9
posted on May 24, 2009
Very Helpful)
s-petersen
Rank: Master
Rating: 93%, 7 votes
I followed Ggleg's suggestion about the ic502 chip,it didn't work,but I then tried the other heatsink, same problem,different chip( ic3800),and that seemed to fix it! I don't know what the chip does, but it get's pretty warm. I still have to do a better job before I put it together.Thanks Ggleg!
Comments:
May 25, 2009
- I found a post elsewhere on this site by Ggleg,his post started me in the right direction,what seems to be the problem with several models in this series is the heat-sink insulators break down and start leaking on the chips and boards the worst problem is that under the input board,under ic502 there is a heat-sink that is insulated from the circuitry by one of these insulators,what happens is that the heat-sink slowly works through the insulator and shorts the circuit, Tv works great now Thanks Ggleg! Scott
Was this helpful?
Yes
No
Solution #10
posted on Feb 16, 2009
Very Helpful)
dhadams
Rank: Apprentice
Rating: 100%, 1 votes
One solution that I found can work is the following. In the winter months, if you are in a geographic part of our country that experiences cold winter, the humidity inside a house can be low, creating static electricity. Thus, there is a the possibility that the issue may be with your digital video box and not your t.v., assuming you have such a set up. Try not only unplugging your t.v., but while it is unplugged, randomly hit the buttons on your digital box. On the surface, it doesn't seem like doing this makes any sense, but a t.v. repair professional indicated that it empties out the memory in advance of the box resetting (or something along these lines). In summary, it work and we have since moved a humidifier from another location into the house into the room with the Sharp t.v. and (knock wood) have not had any other problems surface since the t.v.'s sound went out. If this technique works, you will have saved yourself several hundreds of dollars. If not, there is the possibility that the insulation around your sound board is an older type of insulation that (for lack of a better word) "melts" and causes problems with the Sharp's sound. I learned through my repair experience that the newer Sharp's use a different type of insulation. Good luck and respond back if this approach works.
Was this helpful?
Yes
No
Solution #11
Very Helpful)
Ggleg
Rank: Master
Rating: 100%, 57 votes
Almost all intermittent audio or audio failure problems with Sharp Aquos LC**D4U, LC**D5U, LC**D6U, and LC**D7U televisions are the result of a relatively simple design flaw involving the heatsink pad compound used on the Tripath TA-2024 amplifier chip (IC2502) found on the A/V board. This compound has a fairly low melting point and, over time, tends to seep out from between both top and bottom heatsinks onto the legs of this chip as well as onto circuitry immediately surrounding it. Further, over time the seeping compound also becomes somewhat conductive creating bridges which short the audio amplifier circuit causing everything from intermittent audio to complete audio failure.
Fortunately, in almost every case audio can be completely restored by cleaning the old compound from both top/bottom heatsinks and from both sides of the
PC board in the area immediately surrounding the chip (I used rubbing alcohol which worked quite well). Sharp has issued a service bulletin addressing this issue (LCDTV-194) wherein a ‘2502 Heat Kit’ is specified. This kit is Sharp Part Number: PSPKIT663WJZZ and is available from circuitcity.partsearch.com for $19.95. However, it’s entirely possible to get by with the heat pad only, Sharp Part Number: PSPAZA663WJKZ for only $9.95. Please note that board replacement for this problem is almost never necessary, so if you’re working with a repair technician be sure and insist that he/she be certain to try cleaning the old board and replacing the aforementioned heatsink pads before charging you for a new board.
If one is reasonably familiar with
electronics disassembly/reassembly and is willing to take their time, this can even be a DIY project. It is possible to find ‘important service references’ by simply entering LC26D4U (the 5, 6, and 7 series are very similar, and this information covers all screen sizes) into the search field at eserviceinfo.com. This will greatly aid in disassembly/reassembly of the TV, as the A/V board is somewhat ‘buried’ under other boards. Please refer to post # 373 at avsforum.com/avs-vb/showthread.php?t=647174&page=13 for pics of the information detailed here.
My knowledge of how to solve this issue came primarily from finding the research efforts of ‘Aureius’ on the AVS forums, and particularly from his taking the time to post the solution publicly so that others might save time, money, and aggravation. I'm just passing along the information. Thanks Andy!
I also wanted to mention that a couple of other very pesky common problems with these series of Sharp TV's involving symptoms of random powering-off and/or powering-on, and 'function lock-ups' of various sorts are easily remedied through two firmware updates (Main CPU: PH1UU112, Monitor: MD1UA104). These are not available to end-users via the internet but it may be possible to get the files from an understanding factory-authorized repair tech. They are installed using an SD memory card (don't use the HC high capacity sort, use only those that are NOT HC) which is inserted into a special slot in the back of the machine. For those of the DIY persuasion, information about how to check whether your TV has old firmware in need of an upgrade is readily available through internet search.
Comments:
Apr 06, 2009
- PLEASE SEE SOLUTION #6
Was this helpful?
Yes
No
20 people thought this was helpful
Solution #12
posted on Aug 08, 2008
Very Helpful)
nikolago
Rank: Apprentice
Oh ****. Offtopic: I was searching today with the hope of finding something as of why my Sharp does not get any sound out when it's connected to the PC. DVI-to-HDMI (video signal) is fine. But I cannot get any sound no matter, goddamn...
Anyway, I bought my Sharp LC32D44E 2 weeks ago. From time to time, I thought I was just hearing things, that that popping sound as you call it came from whatever place just not the TV. Until today I'm not convinced that it comes from the TV, but the fear that it does is all there and present. Then I read you guys having the same frickin' problem with your Sharp TV's and it poped out for me that.. that just might be it. Although my TV is brand new, I DO think I heard some irregular clicking, popping sounds coming from the TV. But they are too random to really test anything. And I was saving for it for some time... ****!
Was this helpful?
Yes
No
Solution #13
posted on Jul 20, 2008
Very Helpful)
theeoriginal
Rank: Apprentice
I've had the same issues that started last week. I just bought my TV model lc-32d6u in 2006 before Thanksgiving and it's not even two years yet and the soundboard also overheated.
Tried the whole system reset/reset jig at first audio came back fine without any problems, but as soon as you turn off the tv and turn it back on dead silence... How frustrating!!
In the meantime, I'm using my home stereo for audio, but I can't play my PS3 now =( what a bummer...
Sharp reps are no help either, they'll ask for your address just to give you a contact number for the nearest dealer that can fix the problem.
They should be ashamed of themselves.. I want a full refund.. good picture but picture is not good without sound.. what a total ripoff... they should recall these aquos tv's until they fix the problem. what a waste of $$$$$$$$$$
Was this helpful?
Yes
No
Solution #14
posted on Jul 03, 2008
Very Helpful)
soundproof
Rank: Apprentice
Exactly the same problem with my two year old Aquos LC-26D4U: popping sound from the right speaker (always the right speaker), then no sound. I called Sharp and they gave me a local shop with very poor customer reviews. I emailed Sharp customer support and forwarded them a link to this page as well, they got back to me with the same local shop and nothing else. Very disappointing.
I followed rsuchowi and BlueScreenEr's solutions and connected my TV with my computer speakers, now the sound is back. But Sharp's reputation is lost.
Was this helpful?
Yes
No
Solution #15
posted on Jun 25, 2008
Very Helpful)
eastonp
Rank: Apprentice
I have a Sharp LC32D6U with the exact problem, light pop out of right speaker, no sound. The unit was purchased in August of 2006. I contacted Sharp with tjrose's information about the heat sink, asking about a service bulletin and to see if Sharp was going to do anything about this for customers...we'll see.
Was this helpful?
Yes
No
Solution #16
posted on Oct 13, 2009
Helpful)
lhp_1
Rank: Apprentice
Rating: 83%, 3 votes
I had this sound problem with my (almost ) two years old LC-46D64U , call Sharp: your model is not included.. your service visit will be $250.- (South FL) Then I call VISA, they sent me the claim paperwork by email, I'm sure  I'll get it fix for free. Never again a Sharp.
Was this helpful?
Yes
No
Solution #17
posted on Aug 27, 2009
Somewhat Helpful)
fuckinquit
Rank: Apprentice
Rating: 75%, 8 votes
I have the repair for this unit but that is how we technician's make a living just as you do nothing is free in life hell i wish my car would last for years and then get it fixed for free waaaaa waaaaa!!!
Was this helpful?
Yes
No
Solution #18
posted on Jul 09, 2008
Somewhat Helpful)
Guest
Rating: 0%, 0 votes
all issues discussed above, yup we've had the same. **** sharp. go sony.
Solution #19
posted on Nov 27, 2009
Not Rated)
mityjoe67
Rank: Apprentice
Rating: 0%, 0 votes
This is a great site. I have the same problem as everyone else. I called the phone number 18002374277 and followed what number 6 did, kept pressing one till I spoke with someone, they took my info sent me to dispatch and they said as a 1 time courtesy they would fix it free of charge since it was out of warranty. Thanks for the posts.
Was this helpful?
Yes
No
Solution #20
posted on Aug 01, 2009
Not Rated)
rx7racer
Rank: Apprentice
Rating: 0%, 0 votes
Contacted Sharp as per Solution 6.
Note that the first person I spoke to said he wasn't aware the problem. But then they transfered me to Dispatch and they said it would be taken care of.
Repair was as described in Solution 10., Only the heatpad was replaced, after cleaning the area with solvent.
So far, so good. Kudos to Sharp for fixing my 5 year old TV.
Was this helpful?
Yes
No
Solution #21
posted on Jul 18, 2009
Not Rated)
just2cgeorge
Rank: Master
Rating: 80%, 59 votes
Was this helpful?
Yes
No
Solution #22
posted on Apr 24, 2009
Not Rated)
jennstar87
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem and I just got a Home Theater System and hooked it up very simple and It worked I bought from target for 173.00 but there are cheaper ones you just have to look around maybe walmart or sams club or any other places that have electronic. You can find one as low as $70-90 bucks
Was this helpful?
Yes
No
Solution #23
posted on Jan 03, 2009
Not Rated)
travmimi
Rank: Apprentice
Rating: 0%, 0 votes
I had the same sound problem. I took off the speaker, went to Radio Shack and bought some small speakers. I needed a Y-adapter Audio Cable and coupler too. I hooked it up to the audio out on the TV and now I have sound !!! Only problem is the volume can't be adjusted with the remote. Worked for me, hope it works for you ! At least I saved the set and avoided the repair cost, which now seems to be up to $500.
Was this helpful?
Yes
No
Solution #24
posted on Nov 04, 2008
Not Rated)
Guest
Rating: 0%, 0 votes
Same problem as the rest of you. I replaced with a Samsung and will move the sharp to the bedroom and use self amliied computer speakers. Will never buy SHARP AGAIN!
Solution #25
posted on Oct 29, 2008
Not Rated)
Guest
Rating: 0%, 0 votes
Our Sharp has been popping since we bought it two years ago and now, no sound. Unbelievable!! I am finding people with the same problem all over the internet. Sharp should really sit up and take notice as I will definitely tell everyone I know NEVER to buy a Sharp.
Solution #26
posted on Oct 28, 2008
Not Rated)
Guest
Rating: 0%, 0 votes
Just add me to the list. Same timeframe and everything. I was quoted $264.95 to see what the trouble is and initial labor. Parts and whatever else (additional labor) would cost more. I've already tossed it.
Solution #27
posted on Aug 30, 2008
Not Rated)
Guest
Rating: 0%, 0 votes
Same problem with my Sharp Aquos. 18 months and then no sound. What a pain. No one wants to work on it. Never another Sharp!
Popular Solutions for Sharp Aquos LC-37GD6U 37 in.
Questions and Unsolved Problems for Sharp Aquos LC-37GD6U 37 in.
Do you recommend Sharp Aquos LC-37GD6U 37 in. HDTV LCD Television?
Answer
Answer
tv comes on. no pic.. just the words just wait on screen
Answer
I keep getting an audio message at the upper right of the screen as it switches from mono to stereo.... (More)
Answer
My television keeps on turning off by itself - how do I stop this automatic timed shut off?
Answer
picture "blinks out" frequently, for 1 or 2 seconds. sound continues. frequency every 3-5... (More)
34 Other Users Have The Same Problem - Continued
Comment by sognibene, posted on Mar 09, 2009
There is a technical bulletin on this LCDTV-194 I have contacted Sharp and they are no help at all. You have to contact someone (dealer) to help obtain this bulletin.
Comment by andyj33, posted on Mar 08, 2009
We have model LC 28D6U and we have the same problem! The sound goes off and or without any rhyme or reason, although switching channels often causes it. We have tried all types of cable connections, gotten a new cable box and more and are extremely frustrated.
Comment by harrykatz, posted on Mar 08, 2009
Yes, I have the LC-37" purchased two or three years ago and tonight, March 6th, 2009, the sound just stopped dead cold. I have wireless headphones connected to the TV which still produce sound, but the internal TV speakers are dead. I suppose I'll just have to get speakers to connect to the TV, I guess...
Comment by dhadams, posted on Jan 18, 2009
My Sharp Aquos, 46 inch has the same problem as described here. Acquired in September 2007, and now in January 2009, there is picture, but no sound.
Comment by Guest, posted on Dec 14, 2008
Same problem just started with my LC-32D6U. It hs progressed to no audio. Same popping. At first i could unplug the tv and it would work for awhile. Finally all digital audio stopped working. I then by passed my HD Cable box and ran the cable directly in to the analog in connection. Worked ok but progressed to not working unless I disconnected and reconnected the cable. Now it only works for about 10 minutes until I get the very distinct pop followed by no audio. I also called Sharp. Waste of time. I called the local listed Sharp master repair site. They acted like they were unaware of any audio issues but did give me a "guessamite of $250-$300
Comment by andyepst, posted on Dec 13, 2008
I have the same problem. A few weeks ago, directv upgraded my receiver that was hooked up to my sharp hd tv thru an hdmi cable. Picture was fine with new receiver but no sound from the tv. tried component and composite cable both of which have red/white sound rca cables and sound was fine. switched back to old receiver thru hdmi and sound was back again. tried three other new directv receivers and none of them were able to get sound out of the tv. borrowed a tv from a friend with an hdmi input and the sound worked fine with the new directv receivers using the same hdmi cable. There is apparently some compatibility issue going on here. I still don't have an answer and am going to use component for the time being.
Comment by Guest, posted on Nov 09, 2008
I also have the same problem, soon after warranty expired, sound difficulties. I have just given up and use my home theater speakers, but what a pain in the neck; turn on reciever, cable box and tv just to watch tv. I refuse to spend the several hundred $$ it sound like it will cost to fix, because who knows what will happen next. At least I am not the only one.....
Comment by civil-kelly, posted on Sep 17, 2008
Hi, I have a 42" Sharp Aquos LCD TV (not sure of the model #) and it was a floor model I bought from Future Shop in Jan 2008. Just recently it started losing the audio. No popping sounds just no audio. It has only happened twice that I am aware so I have not yet been able to determine any patterns but the most recent was this morning, after it had been off all night. So this may be a sign or worse to come based on what I read here.
Since it was a floor model it may have aged the TV so that this problem is showing up sooner than it might have otherwise (lucky for me). But the salesman assured me even though it was a floor model I still had a 1 year warranty. So at the very least we should be able to get it fixed under warranty.
But does anyone know if Sharp has a permanent fix (replace A/V board?) or is it likely to do the same think after 18 months or so again?
Thanks
Comment by reb03el, posted on Aug 17, 2008
Same problem as everybody else I see. Worked just fine for the last two and half years and now pop - no sound! Called Sharp just to see if anything has changed and they told me it was no longer under warranty and not their problem. Great customer service to go along with a great product!
Comment by Marlenablue, posted on Aug 10, 2008
Same problem as already described. We purchased the unit 20 months ago, now there is a clicking sound in the right speaker and no sound.
Comment by Guest, posted on Jul 12, 2008
I own a two year old LC-32D4U television.  Loved it until a couple days ago when the sound suddenly quit.  No sound on any input (TV itself, Wii, or DVD).  I made sure all connections and audio settings were correct.  Eventually pressed "reset" button on back of TV and all was well.  Next morning I Turned on the TV, watched TV with perfect sound for 10 minutes, and suddenly the audio quit again.  Tried the reset button again (several times) still no audio.  This is driving me crazy!
Comment by macor247, posted on Jul 08, 2008
I have the exact same problem except my TV is a LC37-D4U ( right speaker pops when I turn it on than nothing it also started intermittently, now I can't get any sound at all. I tried resetting and checked all the settings
Comment by Guest, posted on Jun 10, 2008
ive got a 26-d6u that started doin th same thing
Comment by Guest, posted on May 27, 2008
LC-26D4U same problem no audio, just went out after 1 year.
Comment by Guest, posted on May 12, 2008
I have a 2 yr old LC-32DU and the same sound problem started up a couple of weeks ago. No sound when I turn it on in the morning. For a while I was doing a hard boot by pulling the power cord for a couple of minutes and it would correct itself. However, it is now getting worse and harder to get audio. Tried the reset buttons and power on/off etc, but nothing seems to work. Sounds to me like a heat problem, but I'm sure no expert.
Will phone the salesman today and see what he suggests. What a bummer!
Comment by Guest, posted on Apr 24, 2008
I am having a intermittent audio tapping or beating sound.. you could call it a popping sound, I guess.  I do not get any audio on the left channel of my stereo ... I have not diagnosed it yet.. but maybe only one side of the TV works.. I get back to you after the repair man gets here.
Comment by rednag, posted on Apr 23, 2008
L37D6U: 18 months from new, sound would suddenly quit. For a month, unplugged TV 10 mins, then OK for a while. Now does not have sound at all. Can get sound by plugging into "sound out" connectors on TV, send sound to auxiliary input on my stereo system.
Comment by helpless1, posted on Apr 21, 2008
I have an LC-32gdu. We seemed to have problems with the sound fading so that you had to keep turning it up. Today, while listening to the news the sound just died. Turnign it off and on did not do anything. I did hear a slight popping sound one time when turning the TV on. Some other people have mentioned that just leaving the tv on worked, however, my sound went out while the tv was already on. has anyone else had the same prolem?
Comment by vstrattman, posted on Apr 09, 2008
Same problem as everyone else, also at around the 18 month mark. This is ridiculous!! I'm going to try some of the solutions others have suggested but I'm not good with electronics so keep the help coming if possible! thanks
Comment by pato57, posted on Apr 01, 2008
our LC-26D4U is 18 months old, and out of warranty. And no sound. Repair person said he called the company, and was told, we needed a new sound board. AND, the problem was happening with all these TV's. . . cost $246.00.
Comment by robnj, posted on Jan 30, 2008
it seems I am in the beginning phase of this problem. It happens sporadically, I turn the set on/off and it comes back. I will call Sharp tomorrow and see what they can do about it
Comment by Guest, posted on Dec 10, 2007
WOW! Ive had mine for 18 months too and the sound just went, after turning it on and off for 30 minutes, the sound comes back on. But as soon as you turn it off and on again, there is no sound.
We are now leaving it on forever until it totally burns out. Called Sharp and they didnt care AT ALL... warranty had expired 6 months ago...
Comment by sharp_pain, posted on Dec 08, 2007
I have the exact same problem. I own the Sharp Aquos LC32-D6U and bought it in Feb. 2006. When the problem first started occurring it would seem to correct itself at first by turning the TV off and on again. Then the audio just seemed to go completely! Given all these comments this has got to be a serious manufacturer defect. What a rip-off, just as the warranty expires the TV begins to malfunction….enough to make me not want to buy a Sharp product ever again unless they fix the issue.
Comment by katydid, posted on Dec 02, 2007
I have the LC-37D4U, which is almost 2 years old.  It has been working fine until about a week ago, when suddenly the audio just quits.  Turning TV and HD cable off and on again will sometimes work and get the sound back for awhile.  The cable company came out and provided new cables and box, but the problem continues.  When the TV guy came, the sound problem didn't present itself (until 1/2 hour after he left).
As a temporary fix, I hooked up external speakers directly from the cable box.  It works just fine.  These are just small speakers from my computer.
Now I am thinking that if I get a better speaker system (or DVD home theater type of system) and bypass the TV's speakers completely that might be a cheaper fix than having a TV repair service replace the audio board or whatever.
Has anyone had any experience with this type of set-up which would not use the TV's audio system?
Thanks
Comment by Pan Out, posted on Nov 23, 2007
I have had the same exact problem with the speaker and popping sound on the right side of my LC-37D4U. I have tried a variety of connection options with the HDMI cables with no real success. Oddly enough, the sound will randomly work some days without any intervention but as soon as I turn the TV off and back on I hear the popping noise and the sound is lost again. I would love to find a cost-effective way to repair without returning to the manufacturer since I am also out of warranty.
Comment by Sakshi Bajaj, posted on Nov 22, 2007
I have a 2 years old LC-32D6U and I am experencing the same problem of no sound. First time it worked after I turned the tv on and off few times. But after that no sound what so ever.
Comment by Pinard, posted on Nov 19, 2007
I have the exact same issue. My TV is 18 months old also. Did you ever find out how to fix it?
Comment by Bepps, posted on Nov 05, 2007
I have a Sharp Aquos that is only one month old and is making continous popping noise from one of the speakers. I am contacting the retailer and will advise of the cause and hopefully the fix.
Comment by Gavin888, posted on Nov 04, 2007
I have exactly the same problem on my LC-37D4U. It first happened a month ago and I had someone come out and fix it but now it has just happened again. The company that fixed it charge $150 but don't tell you what the problem is other than it has something to do with the cable/HDMI set-up and they fixed it using the TV remote. I have tried everything but without luck. Tomorrow I have someone from Time Warner coming out to look at it.
Describe your Flat Panel Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(704) 315-5981
Chat Now
Insert Link
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
