Question about Brother LS-2125 Mechanical Sewing Machine
Morse 6300, the thread keeps breaking every attempt i make
The top spool of the machine, once i thread it through it works fine for about 5 sec. then it refuses to go through and frays until it breaks. i have no idea what it causing it either. is it not catching the bobbin? the bobbin works perfectly, it's the top thread that keeps breaking. PLEASE help!
  • bleesthyhand May 12, 2009
    the needles are new, it's like it wont go through the fabric though, the thread dosent, becuse the needle is fine too
    yes ive gone through the motions.. an ive done all those. it's almost like it dosent want to go through the fabric. because the thread from the spool wont stich, just the bobbin =/
  • 37 Answers
Change your needle, make sure the needle is new. and change your thread. Use a high quality thread and rethread the machine carefully, following all the guides. Also, check your tensions. I bet it is the needle tho.
Posted on May 12, 2009
  • Cindy Yunke May 12, 2009
    Check the needle position? Are you using a good thread? You shouldn't see any fuzz when you look at the spool. Also, make sure you have the spool disk on over the thread spool, the disk should be bigger than the spool top.
Kenmore mini ultra The top thread breaks off from needle after a few stitches. The bobbin seems to Be catching the top thread. Thank you. ??
If the top thread sews a few inches and then breaks, something is catching the top thread and holding it until it breaks. Usually, this will happen when using the old style thread cones with the slit in the edge to keep the thread from raveling off the spool. To prevent the thread from hanging up, turn the thread spool over so the slit is at the top instead of the bottom. Sometimes top thread breaks will happen if the thread becomes looped around the thread spool pin.
Remove the thread, ALWAYS RAISE the presser foot and then rethread the upper thread. Verify that the thread path is correct and that the thread has not looped around a guide.
If the thread is fraying at the needle eye, the needle/thread are not compatible. Also, the tension may be too high.
Check that the upper tension disk is clean--no gunk buildup or thread pieces stuck.
If the thread is actually breaking when it penetrates the needle plate hole, there may be a burr or nick somewhere below that is catching the upper thread. You can wrap your finger with a piece of fine fabric, like an old pair of hosier, fine knit fabric, etc. and running your finger around in the bobbin area, under the needle plate. If you get snags, then you have a burr or nick. If it is small, you can sometimes smooth it with a fine emery board. If it is a large burr, you may need to purchase a replacement part.
Why Does My Top Thread Keep Breaking Sewing Machine
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Sep 05, 2016 | Kenmore Sewing Machines
How do I fix a White sewing machine #445 that keeps breaking the upper thread
Check the thread spool to make certain the thread is not getting snagged on the edge of the spool (or the little slit where you pull out the thread from the spool); then check your tension paths and settings (I once found broken, tangled metallic thread in the needle 'uptake' loop that was snagging the thread and making it break).
Canned air is excellent for cleaning out older models as well as the new electronic machines.
Feb 03, 2015 | White Sewing Sewing Machines
The top cotton keeps breaking
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Aug 19, 2014 | Singer 8763 Curvy
Top thread keeps breaking
Mar 09, 2014 | PfaFF Sewing Machines
Pfaff 1200 top thread keeps breaking
Sep 03, 2013 | PfaFF Sewing Machines
Thread keeps breaking on my E&R machine. Making bean bag, and started off o.k. but nothing I do now stops thread breaking! HELP
Aug 07, 2013 | Sewing Machines
Have a Janome 1600P-Top thread keeps breaking
Apr 21, 2013 | Sewing Machines
Upper thread keeps breaking
Mar 28, 2013 | Simplicity SE3 Computerized Sewing Machine
My machine keeps breaking the thread
Mar 02, 2013 | Sewing Machines
New Home 7500 sewing machine top thread keeps breaking?
Jan 30, 2013 | Sewing Machines
Brother LS-2125 Mechanical Sewing Machine Logo
322 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
