Question about Baby Gear
Front seat stuck and will not move uses a manual bar
Our 2003 Dodge Neon SXT front driver seat will not move forward or back and it is a manual bar in front. When you lift the bar nothing happens at all. Not sure if it is stripped or needs a spring underneath to help. Looking at taking it to the dealer to see what is the problem and don't want to pay a bundle for it.
    Problem Solver:
  • 10 Answers
The spring/wire under the seat that goes from side to side in probably undone or broke causing the seat to not slide
Posted on May 11, 2009
Driver side electric seat is stuck in the far forward position and won't move. How do I move it manually or fix the motor.
Auto Repair: How to Replace a Power Seat Motor - YouTube
? 1:44
https://www.youtube.com/watch?v=EDh-0rs5Fjo
Oct 26, 2010 - Uploaded by automdvideos
Auto Repair: How to Replace a Power Seat Motor ... 2007 - 2008 Ford Expedition/Lincoln Navigator Driver Bottom Install Video ...2003-2006 Chevy/GMC Seat Cover Install 1 of 3 - eBay Ready ...2000 Ford Explorer Front Seat Track Stuck Motor Repair - Duration: 4:39. by cubmancan 4,959 views. 4:39.
Drivers seat is dead! No power seat or heat. - TheDieselGarage.comwww.thedieselgarage.com/.../96465-drivers-seat-dead-no-power-seat-hea...Mar 22, 2010 - 2003-2005 Chevrolet Avalanche, Silverado, Suburban, Tahoe 2003-2005.... Power seat on driver side didn't work.....passenger did! Neither ...DANG electric seat ' Chevy Truck Forum ' GM Truck Clubwww.gmtruckclub.com/forum/threads/dang-electric-seat.2990/Apr 27, 2006 - 10 posts - ‎7 authors'03 Tahoe My driver seat just stopped, of corse not where I need it, the ... I have a 2003Tahoe and both heated seats are not working. ... with my seat heater on the drivers seat in my 03 Avalanche, it turns ... The driver's side on my Silverado gets way warmer than the passenger side. ... Frozen New Member.Power Seat Problems?? - Tahoe Forum - Che
Dec 29, 2015 | 2003 Chevrolet Avalanche
2003 dodge neon goes forward no problems but no reverse
If we assume it's an automatic....and the shifter locks in position for each selection...etc....
1. Your transmission fluid is too low or too dirty to engage reverse.
2. Your reverse bands are worn out or damaged from shifting to or from reverse while moving forward?
Mine had reverse totally burned out but drove ahead fine...for a while.
Apr 29, 2015 | Dodge 2003 Neon SXT
Removing front driver seat
Hi Edward, if you are only changing the drivers seat with a new one, here's how its done. You'll need to move the seat reward all the way, then remove the 2 bolts holding the seat to the floor, then move the seat all the way forward and remove the 2 bolts holding the seat to the floor. NEXT, tilt the seat up and unplug all connectors that run from the floor to the seat. Thats it, reinstall your new seat in reverse procedure. Hope this helps, have an awesome day Edward.
Apr 21, 2014 | 2005 Dodge Neon SXT
My 2003 dodge neon sxt with a manual transmission will not shift into Reverse
is it grinding when you try? try to turn car off hold in clutch put into reverse and then start car
if it pops right out you need to get it to a transmission shop.
i recently replaced a transmission in an SXT that had no reverse, all it would do it grind and pop back out
Sep 23, 2011 | 2003 Dodge Neon
I want to install a seat cover, but I need to remove the head rest on a 2003 Dodge Neon SXT
most head rest have a lock button to hold and lift the rest off..... or pull up harder my be stuck
Mar 30, 2011 | 2003 Dodge Neon
03 neon sxt 2.0. Po440, 441
Those are indicators for a fault in your Emission Control System. There are a lot of things that can cause them to appear but the most common is actually a code you haven't mentioned. The O2 Sensor under the driver side of the vehicle. If your looking for a book on the vehicle Auto Zone sells a Haynes Manual for the vehicle. I recommend you use that book and have them look at the codes with a code reader. Also have the Gas cap checked for leaks. A vacum leak on the fuel system can cause this fault to appear. If the gas cap is good I would replace the O2 Downstream sensor, It is located just forward of the catalatyct converter on the driver side under the vehicle.
Mar 10, 2010 | 2003 Dodge Neon
What is the proper sequence for rotating tires?
My understanding is that with radial tires that are in use today, you should rotate front to back on same side. Not side to side.
Jul 09, 2009 | 2005 Dodge Neon
I can't get to the back of the driver side headlamp assembly to pull out the bulb. Any ideas? I have a 2003 Dodge Neon SXT.
is it behind the air cleaner? if so, you will need to remove the cover and then you'll have access to it. replace the bulb and then replace the cover.
Apr 14, 2009 | 2003 Dodge Neon
Baby Gear Logo
216 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
