I cannot hear any sound when i connect the DVD player with the external Speaker amplifier. i have checked all the slots. the leads are installed properly but still cant hear a sound.
  • 59 Answers
Make sure that your on the right input
Posted on May 11, 2009
The volume has went off on my tv. its a samsung le26b450c4w
First verify that the mute is disengaged (toggle the mute button). Second, check the sound configuration to make sure the internal speakers are on, or check the sound output to make sure it is going to the inputs of an external audio amplifier (stereo receiver) and that the external amplifier is working. Try a different input source - perhaps the problem is your cable feed or DVD player.
If the internal speakers are on, the volume is up, and you still don't get any sound from a known-good source (TV channel, DVD player, etc.), then try running the sound to a stereo system as described above.
If that works, you may have a shorted speaker amplifier (depending on the set's design, this may blow a fuse supplying power to both left and right amplifiers or a speaker protection circuit will keep the speakers disconnected). These aren't usually hard to repair, but if you find a blown fuse, fix the amplifier before replacing the fuse or you'll just waste another fuse.
Jan 09, 2012 | Samsung Televison & Video
I have no sound. Do i need to setup to run this dvd and get sound.
You better check first the sound setting.Try to set up dvd and check if there is a sound.If didnt work,maybe the problem is in the speaker, wirings,connector , amplifier or the sound signal.So its better to check inside the following.Thanks..
Aug 25, 2011 | Televison & Video
I have no sound from one channel. I have swapped speaker leads (sound just swops with the speaker). I have taken lead out of CD player and touched ends of leads for "earth hum". Only get hum on...
If the sound stays with the speaker, then the problem is with the speaker not the receiver (unless I misunderstand). You state that changing the speakers that the sound stays with the speaker. This means that both channels are producing sound, it is the speaker which is defective. You can verify this by using a 9V battery. Quickly touch the leads from the speakers to the battery. You should hear a pop or click. If the speaker is defecive, you won't hear anything.
Let us know what happens.
Dan
May 08, 2011 | NAD C350 2-Channel Amplifier
I can hear the music when playing dvd's on my Spectoniq dvd player, but can't hear when people talk. Can anyone help me?
Yes, I can help you. Your DVD player should have output connectors in the back of it to plug your amplifier or receiver into. If you have a Stereo system (no surround sound speakers, or front center speaker) connect the DVD Audio Cables on the back of the DVD player to the STEREO Output Jacks. If it is connected to the Left Front and Right Front jacks of the "Surround Sound" output jacks instead of Stereo is that the dialog on is sent to the CENTER channel output. If you have no center channel speaker you will not hear it.
If you have a surround sound system with two speakers in front and two speaker in back. Then you need to make a change in the Receiver Setup (Which may be set up for 3 speakers in front) so that it is set up for 2 speakers in front.
The last thing my simply be that you have a center channel front speaker that is not completely connected because of a wire falling off, etc.
Hope this helps,
Best,
Mark
Jan 13, 2011 | Spectroniq PD-3000HD
Radio turns on but no sound 1999 dodge intrepid
If all your connections are made correctly its is possible that one or more of the speakers have shorted out. Some radios will shut down the internal amplifier if it sees a problem.
Best way to check is to remove the radio and access the speaker leads. One speaker at a time take a battery like a 9v and put the positive and negative leads on the terminals of the battery. If the speaker is connected correctly than you should hear the speaker pop. Don't worry it will not damage the speaker. If you do not hear the speaker pop than there is issue between the wire leads and the speaker. Maybe the speaker is blown or just disconnected in the door.
If all the speakers DO pop when you applied the voltage than it is an issue with the deck.
Hope this helps.
Please Vote & Rate
Mar 08, 2010 | Pioneer DEH-P4700MP CD Player
I lookig to connect a external speaker with philips divx dvd player.Is there any speaker available with inbuilt amplifier.
The bottom range speakers will just have the stereo attachment and will look cheap and will give you bad sound output in a large room.
However if you get active speakers this means that they have an external power source (AC plug) then you will be able to increase the dB power output to the maximum that the speaker will deliver however on bottom end speakers you will get amplitude clipping and speaker cone vibration however it is the cheaper option.
The best method is to pipe the 3.5 " stereo jack output or 2 x RCA phono outputs to a decent amplifier on a midi hi-fi system or similar that will be able to handle the vibrations and power output
Apr 01, 2009 | Philips DivX DVD Player
I CAN NOT GET ALL 5 SPEAKERS TO WORK
I know this is not the answer that you want to hear, but: That television is not capable of delivering audio output to all 5 speakers - it is a stereo-only TV, which only delivers 2 channels.
Furthermore, that Coby DVD-937 only has Digital Audio outputs rather than inputs, which is very strange and complicates our problem immensely. You will get 5-channels with DVD or radio play, but getting 5 channels for TV is not possible without additional equipment.
The manual for the Coby mentions a "Digital Decoder Amplifier," which would work. You would connect a digital audio cable from the area marked "Coaxial" on the back of the Coby to a digital audio IN on the back of an external amplifier. You would connect the speakers to this amplifier, instead of directly to the back of the Coby. Then you would need a cable or satellite box with digital audio outs (fairly common nowadays) to another digital audio IN on the back of the amplifier. The cable or sat box you may have already, but you may need to purchase such a "Digital Decoder Amplifier" or other digital amplifier with appropriate speaker wires and 2 digital audio input slots (not to mention two digital audio cables). Fairly complex. Possibly expensive.
-Tha Mp3 Doctor
Feb 20, 2009 | Coby DVD-937 5.1 Channel DVD...
Question: how do you connect to a cable box?
That Coby DVD-937 only has Digital Audio outputs rather than inputs, which is very strange and complicates our problem immensely. You will get 5-channels with DVD or radio play, but getting 5 channels for TV is not possible without additional equipment.
-Tha Mp3 Doctor
Jan 31, 2009 | Coby DVD-937 5.1 Channel DVD...
I dont get any sound
Many vehicles have factory amplifiers that must be activated or bypassed when installing a replacement head unit. If the factory amplifier isn't integrated or bypassed, you won't hear sound from the factory speaker locations. Another possibility is that you have a shorted or pinched speaker wire or terminal. A short at any speaker will shut down the head unit's internal amp, killing the sound to all the speakers. The RCA outputs wouldn't be affected, so the subwoofer keeps playing.
Feb 23, 2007 | Jensen VM9510 Car DVD Player
No sound with discs playing
There should be some sort of outboard amplifier. Mine had an amp at each speaker, and also a receiver mounted behind the passenger seat. Could it be that the power antenna lead from your headunit is connected to the amp turn-on lead? That way, when the radio is playing, the antenna lead is powered and thus the amps are too, whereas when the CD is playing, the antenna lead would not be powered and thus no sound. Try reversing these two wires (Power antenna and amplifier turn-on) and your CD should work.
Jan 21, 2006 | Jensen VM9410 Car DVD Player
Televison & Video Logo
Top Televison & Video Experts
