Question about Dell Dimension 2400 PC Desktop
No power on .. wire detach from power button in the front panel ... where do the wire go so i could re attach them .. thanx ?
Dimension 2400 power button wires are detatch .. where do i re attach them ???
    Sergeant:
    Champion:
  • 255 Answers
The connectors are labeled.power switch is labeled PS.reset, RS.you can reattach them by following the labels.
Posted on May 11, 2009
Dell motherboard diagram of wiring and front pannel connectors
most front panel connectors with a 4 x 5 pin configuration are intel compliant, and are all the same.
The "nine" pin is missing, and is the "KEY" to orientation, no matter which way the pins are situated on the board.
1 3 5 7 X
2 4 6 8 10
1= HDD LED+, usually green
3= HDD-, usually white or black
2= PWR LED+, usually red
4= PWR LED-, white or black
These are polarity specific, and must be connected to the proper + and - terminals to work properly
5= RESET
7= RESET
9 is missing, can be used to determine location of other pins
6= PWR
8= PWR
Thes are momentary contact pins, can't get them backwards
Pins 6 and 10 are jumped together in the Dimension 2400.
Apr 18, 2014 | Dell Dimension 2400 PC Desktop
Where is the hard drive in the dimension 2400 dell. I see the cd drives, the power supply, the cooling fan, the heatsink, the video card, the memories... so where is the hard drive?
You know the power button in the front? If you open the cover to see the insides, there is the HD that is kind of covered by a metal slot (has like holes...). Well, the HD is right next to the power button in the front, but inside.... Here is a picture. The wires are attached to the HD. yup.
Feb 22, 2011 | Dell Dimension 2400 PC Desktop
I have a dell dimension 2400 with a blinking amber light what do i do
The blinking amber light on the dimesion 2400 generally means that the power supply on the system has gone bad. Switch off the system and disconnect the power cord from the back of the system . Press and hold down the power button in the front for 10 seconds.
Reconnect the cable back and try powering on the system.
If the same ,fails you would have to take the system in for repairs
Thanks for using Fixya
Proton
Sep 03, 2010 | Dell Dimension 2400 PC Desktop
I NEED HELP IN REPAIRING THE FRONT HEADPHONE JACK ON THE TOWER, AND WOULD LIKE TO HAVE ACCESS TO THE SHOP REPAIR MANUAL. DELL DIMENSION 2400 DESK TOP PC, THANK YOU AND KINDLY APPRECIATED !!!
You can just remove and replace the front I/o panel rather than repairing it . The part is not more than 10$. You can get the part from the following site
http://www.txcesssurplus.com/servlet/the-5850/Dell-Dimension-2400-4600/Detail
or
http://www.impactcomputers.com/d0971.html
How to remove the front panel
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/fpanel.htm
Thanks for using fixya
Proton
Aug 20, 2010 | Dell Dimension 2400 PC Desktop
I have a dell dimension 2400. My starts up fine
Most likely a motherboard issue.
Also ensure the CPU Heatsink is firmly attached. If the heatsink is loose, replace the plastic heatsink retainer
If it is secure, then the motherboard is the most likely failure point
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
May 19, 2010 | Dell Dimension 2400 PC Desktop
How to turn my computer on, i found the power button but dont know what to do next
wireit all in as per instruction (if lost her they are http://www.andovercg.com/datasheets/dell-dimension-2400-series.pdf ) press the button on the front (above the dell logo) and hay presto all should work failing that conntact your supplier (where you brought it)
Nov 11, 2009 | Dell Dimension 2400 PC Desktop
Most likely from tripping over cables over
Hi George
I would simply recommend having the board replaced or upgraded as its not wise to have soldered connections flying around. The only problem is that the system being that old is not going to be an easy one to source a motherboard for.
Sorry i couldnt be any more help.
Taz
Oct 24, 2009 | Dell Dimension 2400 PC Desktop
Dimension 2400 can not power on
If you have no power by pressing the front power button and you have verified that the black connector coming from the power switch on the front is connected properly to the motherboard, then make sure that both connectors from the power supply are connected properly, the main connector and the p4 connector. Reseat both of the connectors to be sure.
If you still have no power and still have the light coming up on the motherboard then I think the motherboard may be bad cause that means something is shorting out the motherboard and not allowing power to go thru it properly.
Mar 08, 2009 | Dell Dimension 2400 Power Supply ** FREE...
Dell Dimension 2400 PC Desktop Logo
104 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
