Question about Toshiba 32A41 32" TV
No user manual
How to change screen to be able to use vcr
Plug your VCR into the back of the TV, using the "VIDEO 1" input. (Yellow - Video, White - left sound, Red - Right sound). Press the "Ant/Video" button on the front of the TV until Video 1 is selected.
Posted on Oct 14, 2007
SOURCE:
I need a user manual for an RCA Model VR612HF VCR
Apparently the manual for VR613HF is functionally the same as the manual for the VR612HD rca vcr.
You can download manual here:
http://tv.manualsonline.com/support/other/vcr/is-the-vr613hf--the-same-as-the-vr612hf-that-i-am--5033671
Jan 29, 2016 | RCA VR612HF VCR
Have a westinghouse lcd tv 50inch model ew50t5kw and would like to know before changing any parts or boards what causes a blue screen no sound or picture
  1. Frank: Verizon. com says try this: Change your VCR's Channel to 3 or 4. Most blue screen issues are caused by the VCR not being set to Channel 3 or 4. If changing the VCR's channel (using the channel buttons on the VCR or from the VCR remote control) did not change your TV screen, go to step 2.
  2. Make sure your TV is not in Video mode. There are three possible ways to change your TV's mode using your TV remote control: 1) Press a Mode button, toggle through the options and select TV, 2) Press a Video button to change your TV's mode from Video to TV or 3) Press Menu, locate Mode or Audio/Video setup and select TV from one of the options. If you are not sure how to change your TV's mode, see your TV's user guide for more information.
  3. Check to make sure your set-top box is plugged in and turned on.
  4. Check to see if other TVs (connected to different outlets) have a blue screen. If they do, contact the Verizon Fiber Solutions Center.
May 21, 2015 | Westinghouse Televison & Video
I have acquired a Panasonic NV-FJ620B-S Video Cassette Recorder which has 2 x scart sockets on the back. 1 marked AV2 DECODER/DECODEUR(EX) the other AV1 (TV). The AV1 scart connector works fine on the TV...
Have just visited the Panasonic UK website and the User Manual for the Panasonic NV-FJ620B-S is available free. It lists on page 11 all the details. I'll e-mail it you Tom to see if it helps.
Jan 25, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
VHQ940 VHS VCR: hi-----I NEED A USER MANUAL FOR A VHQ940 QUASAR VC...
Download the manual here:<br>http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000032686.pdf<br><br>
May 17, 2010 | Quasar VHQ940 VHS VCR
I have a panasonic pv 9451- is there a way to reset the auto programming for the channels? can i reset the vcr programmed information entirelyu and start anew?i think i programmed out channel 3 which is...
Should be able to use the remote to access the VCR menu, and setup the auto programming. If not automatically, then you'll have to do each channel manually. Just check all your options in the menu.
Usually all vcr's have the option of channel 3 or 4.
Apr 14, 2010 | Panasonic PV-9451 VHS VCR
How do I program this VCR to record the same program each week?
Here is a site that has the user manual for a price.
http://www.orionsalesinc.com/miva/merchant.mvc?Screen=CTGY&Store_Code=OSI&Category_Code=VHF6010C
Mar 19, 2010 | Sansui VHF6010 VHS VCR
Vcr does not run
Try changing the channels on the VCR itself. If you can do that, then it would indicate a problem with the VCR's remote. If you are still unable to change channels on the VCR manually, it could indicate a circuitry problem, for which you will have to get the VCR serviced.
Oct 25, 2008 | Sony SLV-685HF VHS VCR
I lost my user manual and the VCR remote control how do i access the menu from the VCR?
http://www.manualsparadise.com Has a wide selection of users manuals
Sep 08, 2007 | Sanyo VWM-900 VHS VCR
Channel changing
You can obtian the user manual at http://www.thomsonnetwork.com/EN/Public. It is likely that during intital set up you selected iether VCR or cable box. If so unplug the tv for about 5 minutes. Whenit is turned on again you will get the intial setup screen. Select "nl" when asked if you have a VCR or cable box.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Apr 15, 2007 | GE 46GW947 46" Rear Projection Television
Toshiba 32A41 32" TV Logo
35 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
