Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
When I mow with my 42" craftsman tractor it leaves a strip of grass down the center of the cutting path. How do I get rid of this?
  • 246 Answers
Hello:
This is Usually Caused by Worn Blades or a Bad Mandral/Blade Spindle Bearing.
Remove the Deck from Under the Mower.
Remove the Deck Belt.
Check the Mandrals/Blade Spindles for Bad Bearings. Do the Sound Rough when you Spin the Pulleys by Hand? Can you Move the Mandralls/Blade Spindles from Side to Side? If Yes, then the Bearing s Require Replacing.
Look At the Tips of the Cutting Edge of the Blades. You will Se the Tips are Rounded and Not Square. This Condition will cause the Strip in the Center of the Deck.
I have Just Joined this Site. If you Send me the Model Numbers Off the Unit, I can Assist you Better.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
Posted on May 11, 2009
  • 122 Answers
Some mowers decks had blades that where timed,but it can also be from dull blades,or mostlikely an uneven deck, check for level deck height on a nice flat surface
For some reason, I'm getting a strip of semi-unmowed grass down the center of my deck cut. Last fall, I had new spendles put on the deck because I hit a stump in high grass. I mowed fine, bvut when I
Are you using the correct size blades. They should nearly touch each other as you rotate them by hand. Also are they attached the right way up. Look at them and the sharp cutting edge should be stained from the grass.. If not turn them over.
Jun 21, 2014 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
I have a Craftsman SL3500 42" riding lwan mower. the two blads make uneven paths ans the left blade makes a cut about 1/4" lower than the right blade. What do I do?
You should be using a up lift blade it will help by sucking up the grass to be cut. You should have an adjust on both sides of the blade deck . As for the strip check to see if you have a wheel behind the mower deck. If you do it might be the cause for mower leaving a strip uncut . Sears has been noted for putting wheels in the path of the blade area and smashing the grass down . That is also why I suggest to use an up draft blade it should **** the grass back up again so you can cut it.
Oct 07, 2013 | Craftsman Garden
I have a John Deere LA105 Riding Mower and when I mow it leaves a strip of grass in the middle. Left and right sides are cutting fine. I have taken the blades off and shaarpened them and have leveled...
jack the tractor (using a tractor jack) or remove the deck, measure the blade tips against each other where they meet in the center of the deck and see if they are the same tip to tip. Bearing wear, a bent deck or blade can make them cut at different heights in the center.
Sep 25, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have an 07 craftsman 24 ohv, 42 " cut riding
Left blade is on backwards (liftng edge is contacting grass). Try reversing the blade on the left side.
Jun 15, 2012 | Garden
I have a Craftsman Lawn tractor. Blade leaves grass uncut.
Hi Tom,
Check your spindle shafts for loose play. If your bearings are worn out and sloppy, the belts pull the spindle to one side and an angle cut results... close cut grass at outer edge and high in center will leave this grass trail you are describing. I'd replace the bearings next year for sure.
I hope this helps... Good luck!
Oct 04, 2009 | Garden
I have a 19hp craftsman 42 deck. It has two blades. It does not cut the grass in the center. It leaves a strip uncut. What adjustment should I do
You may be running too fast on ground speed for the mower deck to cut completely. It may be time for some new blades. The blades may be worn down to where they are shorter than when they were first put on.
Sep 26, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
42" deck - uneven mowing in the center
yes its repairable & yes it can bend the spendle but most likely the blades is it one that does it or both blades or the center or the sides of deck is bent by stepping on the deck let me know if i can further help thanks wade
Jul 02, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
A row of uncut grass left between blaces when mowing
THE answer that FINALLY worked for me. Torque the bolt that holds on the blade to the recommended torque specified in your owners manual (for my Exmark this torque is 120 ft-lbs). When I first used the torque wrench, i was quite surprised by the amount of addional force I needed to apply to reach 120 ft-lbs Exmark blades have a round blade hole with a washer and therefore, relies only on friction provided by torquing bolt to the proper torque to prevent slippage so that the blade rotates at the same speed as the spindle. When slippage between the blade and spindle occurs, blade tip speed slows leaving uncut grass.
Note: this solution will NOT work for mowers with a blade and spindle design which uses a positive means (e.g., a star shaped hole on the blade) that assures the blade rotates at the same speed as the spindle with no slippage.
Jun 15, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
561 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
