Question about Ricoh Office Equipment & Supplies
Ricoh fax 3310, when printing has dark background on left side, new drum has been installed.
  • 1,959 Answers
Ricoh's Support suggests reseating the toner cartridge or re-distributing the toner inside the cartridge. This makes sense since you're experiencing darkness only on 1 side of the page. I hope this helps you with your issue and wish you the Best of Luck!
Posted on May 11, 2009
Line through print
Perhaps did not specify paper thickness (check control panel and print driver).
Toner getting low.
Clean registration roller with clean damp cloth.
Aug 17, 2012 | Ricoh Aficio SP C811DN Laser Printer
Print out of faxed copies are too dark AFTER the first 3
You need a new drum unit. The built-in cleaning blade has worn out.
Apr 11, 2010 | Brother IntelliFAX 2800 Laser Fax
Ricoh aficio 1515f printing dark line down left side
If the print can be rubbed off then this suggests the fuser unit is not working correctly. It could be that the thermistor is covered with toner and making the machine think the fuser is hot enough when it's not.
The black line could also be caused by the fuser if one of the pick off fingers is coated with toner or has worn into the Teflon of the roller.
Does the machine show the lines when you print a page from memory - such as a counter or config page? If not, this would suggest the optical path is dirty. Try cleaning the glass and look at the mirrors inside the scanner to see if they are dirty/dusty.
Feb 18, 2008 | Ricoh Aficio 1515F Plain Paper Laser Fax
Copies and outgoing fax quality
your machine most likely has toner spills in it.
if you send faxes face side down follow these instructions ;
1- take out toner
2- look for thin glass strip on bottom inside the machine
3-wipe clean
if you make copies side up then do the same except look for glass strip on the upper side of machine
Nov 27, 2007 | Brother IntelliFAX 4100 Laser Fax
Ricoh FAX2900L printing too dark
check the scanner white roller witch is under the front cover where you feed in the paper to be scanned sometimes this gets dirty you can take it out by releasing the levers on each side..this also sets the density for copying.. if you have just put a newe cartridge in also check that it is seated properly as the contacts for the charge might not be connecting properly
Nov 08, 2007 | Ricoh FAX2900L Plain Paper Laser
No printing
A common reason for background shading is a low toner. Install a new genuine brother toner. If you have already loaded a generic toner in the drum unit, it is too late. You have damaged the drum asm. You can still buy a new 2800 with new supplies for just a little more than a new drum asm. Did you have the grey baqckground before you worked on it?
Mar 19, 2007 | Brother IntelliFAX 2800 Laser Fax
122 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
