Samsung Tantus Picture Problem. Green Yellow Black Hue
Hi, I have a Samsung Tantus W542HP that has recently began to play up. The problem is that the screen will sometimes be normal for a few minutes if left off for say a week, then the problem starts up again. The problem is the picture will begin to go red then yellow then green sometimes greening out to a black, you can see the picture happening behind the color changing (except when it goes to dark green/black). Then it may have a normal picture for a few minutes then the problem flares up again for a minute or two, followed by normal picture again. I am not sure what the problem is however after reading other problems I think there is a possibility that it may be the color wheel? Any help would be very much appreciated. Thankyou, Aaron
  • wakizashi99 May 11, 2009
    Loose contact? Where exactly do you think the loose contact may be occurring based on the information provided?
    Thankyou for your help.
    Sergeant:
    Champion:
  • 255 Answers
It seems that your unit got loosed contact.i mean it needs resoldering.call a technician to do further troubleshooting.
Posted on May 11, 2009
What causes the yellowish hue in the centre of the screen
There are several different types of projection sets: some use 3 picture tubes, red,green,blue--if this kind of set is what you have the coolant used in the blue tube is bad-----this type of problem leaves red and green which = yellow.
Most common in Samsung, Philips, Magnavox type sets.
If it is a newer set without picture tubes (a dlp style set) yellow in the middle of the screen would denote a damaged optical light engine.
Let me know brand, model number, date made----all are on back of set.
SD TECH
Feb 25, 2011 | Televison & Video
Green hue
Hi,If you are experiment hues,color distortion ,black and white picture,hear buzzing high pitch sounds, it could be time to replace the color wheel.Your part # will be BP96-00250A you can find it here: http://www.discount-merchant.com/Samsung-BP96-00250A-ColorWheel-Assembly-p/bp96-00250a-color-wheel.htm? and here's the instructions to replace it: http://www.fixyourdlp.com/guides/samsung/bp96-01579a.php Have a blessed one!
Feb 19, 2010 | Samsung HLN467W 46" Rear Projection HDTV
Samsung Tantus (SP-43J8PF) Has Green Tinge - Easy fix?
You may try to get into the service menu and adjust screens/drives level(procedure below). But first turn the color off completely and adjust you brightness to mid-range, what you`ll want to do is a grey raster or bring it as black and white as you can while adjusting the red/green /blue guns or tubes. Also get a piece of paper and pen because you`ll want to record the original values of the items you may change. You want to go into the adjustment menu. Hope this will help Good luck
In quick sequence on the remote press:
MUTE - 1 - 8 - 2 - POWER buttons.
The TV will turn On with the Service Menu displayed.
ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
Select the function and use the VOL+ button to enter.
Save settings and exit by pushing MUTE twice then POWER .
Nov 19, 2009 | Samsung PLH403W 40" Rear Projection...
My TV has recently started to gat a yellow hue on
YOUR COLOR BULB IS GOING OUT GOT TO GET A NEW ONE.
Mar 18, 2009 | Televison & Video
Samsung Tantus problem
your main power supply is gone out
Aug 30, 2008 | Samsung PCH521R 52" Rear Projection...
Samsung tantus 1080i
hi i have a 47" samsumg tantus tv and i haven problem with the screen. has some red lines
Feb 17, 2008 | Hitachi 57F500 57" Rear Projection...
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
Samsung 52" tantus pch521r no picture
1) Loss of color = bad solder connects on signal board
2) Loss of pix = probable CRT coolant leak onto signal board
Have a technician check it out.....can be expensive......T.
Nov 24, 2007 | Samsung PCH521R 52" Rear Projection...
Televison & Video Logo
279 people viewed this question
Top Televison & Video Experts
Electro Med Services...
