Question about Homelite Garden
Old homelite ST145 trimmer needs fuel tank - Homelite Garden
    President:
  • 272 Answers
This one might work. Randy is the man for homelite parts. contact him through this page if your not sure. I'm sure he has the part you need.
http://cgi.ebay.com/PART-FUEL-TANK-up00020-308181004-HOMELITE-TRIMMER_W0QQitemZ390009800095QQcategoryZ71278QQcmdZViewItem
Posted on May 11, 2009
  • rjbeg123 May 11, 2009
    If my solution helped you please rate me!
Sears has a page that can get you to a parts list and order source. Go to: http://www3.sears.com
Posted on May 25, 2009
How to replace the fuel tank
308181004 Homelite Ryobi String Trimmer Fuel Tank ...
www.amazon.com > ... > Replacement Parts
Amazon.com, Inc.Amazon.com: 308181004 Homelite Ryobi String Trimmer Fuel Tank replaces ... Ryobi CS30 & Homelite C300 Trimmer Replacement (2 Pack) Air Filter # 98760-.
Oct 07, 2015 | Garden
Homelite weed trimmer bogs down and smothers out quits running
This could be a number of things. Clogged air filter/fuel filter/carburetor/fuel tank lid breather hole, cracked fuel line or primer bulb, or clogged spark arrestor in muffler. Here's some links that will help to change the bulb, fuel cap, fuel lines, rebuild carb, replace spark arrestor, and troubleshoot.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
http://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
Apr 27, 2014 | Homelite Garden
Homelite string trimmer 275, which fuel line do you attach the fuel filter to?
its the line to the carb You have to find the one in the fuel tank Its more than likely the longest one If it hasnt been removed it will have the old filter attached to it already. if not it will be the longest one
Jun 15, 2011 | Homelite Garden
Model ut21004 homelite gas weedeater want stay
fuel issue, look for cracks or holes in the two lines from tank to prime bulb, check prime bulb, adjust/clean carburetor, may also need to check filter inside tank it is connected to the bigger of the two hoses. Tim
May 30, 2011 | Homelite Mighty Lite Lawn Trimmer
I have a 25cc homelite weed trimmer.... the fuel line is loose in the fuel tank... how do i get it back in
You will need the correct size fuel line first. Follow this:
1. Remove the old filter/weight from the fuel tank.
2. Take a new fuel line piece about 8 inches long and cut about a 45 degree angle cut on one end.
3. Lightly moisten the cut end of the fuel line and insert it into the tank from the outside, pushing it in while turning as far as possible.
4. Use a needle nose plyers to reach in and pull the line to the fuel line cap. Cut the line and replace the filter.
5. Pull the line back the way you put it in leaving about 4 inches within the tank and re-attach to the carburetor or primer bulb (depending on the actual model/age)
It will work, but it is extreemly important to have the correct size fuel line to work with.
Sep 27, 2010 | Homelite Consumer Products 4.0 Amp, 13 In....
My homelite string trimmmer will not run when choke is run position. it will run, but not at full throtle, when choke is set between full choke and half-choke.
you've got a fuel system issue , most likely carb problem, if this a newer trimmer it will likely need the carburetor replaced or adjusted, also check for cracking fuel lines or signs of old fuel varnish in the tank
May 31, 2010 | Homelite Mighty Lite Lawn Trimmer
Primer button on homelite gas trimmer
It's possibly the filter, can't help there. I would check for a split line or loose connection between the tank and bulb and even splits in the bulb itself.
Apr 24, 2010 | Homelite Mighty Lite Lawn Trimmer
How do you replace the fuel filter on a homelite st 145? the hose snapped and the filter fell into the fuel tank. Thanks
Take the old piece of fuel line and have the vendor match the size. Buy 1 ft. so that you have a little extra to work with. Cut fuel line at an angle. This will allow for easier insertion into the hole in the gas tank. Feed the line through until you can pull it out of the opening where the gas cap is. Cut the line off square. Attach the fuel filter. Pull the line back through until it rests comfortably on the bottom of the tank. Assemble the trimmer. You will then get a more accurate measurement to the carburetor.
Jim
Jun 10, 2009 | Homelite Garden
Fuel Lines leak where they pass through opening into tank
i had the same problem with my trimmer. you could replace the fuel line but if you don't want to hassle with fishing it thru the hole i suggest going to homelite.com and ordering the gas tank. it only cost me $18 with shipping and came with everything (tank, lines-with fuel filter, and gas cap). all you need to do is take out the 4 bolts on back of trimmer and the 2 top bolts holding the housing together. be careful not to nick any gaskets especially the one behind the 4 bolts. this is the crankcase gasket. also don't get anything in the crankcase that will score it as this will ruin the trimmer. also there are 3 spacer gaskets that go in the holes in the fuel tank and i believe a plastic heat shield between the gas tank and the bottom of the trimmer. you will see this when you take the tank off. just be careful and be sure all the bolts get tightend up (especially the 4 on the back as this is the back side of the crankcase). it only took me 15 min to replace it and the trimmer runs great. all the above info is if you have a trimmer with the gas tank on bottom. if the tank and gas cap are on top hopefully someone else will be able to help.
good luck
Jun 03, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
1,089 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
