Question about Singer Featherweight 140Q
The machine stopped during sewing
The handwheel is stucked and could not be manually moved. The power is OK because the light is still on.
  • 25 Answers
Thread is caught in the hook...Remove the upper thread and bobbin case, turn the hand wheel backwards and forwards by hand and remove the thread remands. Good Luck
Posted on Jun 02, 2009
My sewing machine has stopped working, it was working ok , just a bit noisier than usual but now the needle wont move at all, even if i try to turn the wheel by hand
the machine may need oiling, check in your sewing machine manual to see about oiling it, it's also possible that the machine could have a damaged or broken part inside,,
Mar 17, 2016 | Singer Inspiration 4210 Mechanical Sewing...
Brothers xl3010 sewing machine is not letting needle move but is getting power light comes on
Can you turn the handwheel manually? If so, most likely your foot control is malfunctioning.
Sep 26, 2015 | Sewing Machines
How can I fix a stuck needle bar on my Bernina 730?
If this is a Bernina 730 Record, it needs to be cleaned and oiled. Do not attempt to run the motor if the mechanics are stuck as it could damage the motor.
Consult your owner's manual in the Maintenance section, use only good quality sewing machine oil (NOT old stale oil, 3-in-1, WD-40, or cooking oil) and apply 1-2 drops every place that metal rubs on metal (while you hand-rotate the wheel). Pay particular attention to your problem areas--the needlebar area and the handwheel area (Do NOT oil the cams, the belts, or the plastic gears!!) To speed it up, you can direct hot air from a handheld hairdryer into the internal mechanics. (You may have to repeat several times over several days depending how "stuck" things are.)
If you are impatient, try to find a bottle of liquid Tri-Flow Synthetic Lube at the hardware store or bike shop and use it in place of the sewing machine oil. Once the machine is running smoothly again, you can use sewing machine oil or continue to use Tri-Flow in its place.
In the future, following the instructions in your manual, clean and apply 1-2 drops oil to the shuttle/race every time you change a bobbin (about every 8 hours of constant sewing), do a thorough but light oil as explained above every 40 hours of sewing, or if in storage or not in regular use, every 6 months. If it hasn't been used in a while, always give it some TLC before asking it to work for you.
Sep 17, 2015 | Sewing Machines
What could cause the motor to turn but the needle doesnt move?
it's possible that the sewing machine may need a adjustment or a part could be broken, the machine should be checked
Dec 06, 2014 | Necchi Sewing Machines
Motor stopped; locked handwheel
Remove the needles. See if the handwheel moves now. Since it's a new machine, consult with the seller.
Dec 23, 2013 | Juki MO-655 Mechanical Sewing Machine
My Shark 7133 slowed down while sewing and stopped. The handwheel won't turn at all. I cleaned the bobbin area but it still won't work. The light switches on and the machine motor reves up but...
Slacken the stop motion as if to wind a bobbin and press on the foot control, if the motor runs really fast then you have either thread stuck in the bobbin case area or you may need to oil the machine
Sep 01, 2011 | Euro-Pro Shark 80 - 7133
The handwheel is stuck down. It seemed to be sewing perfectly, and then stopped. It is a brand new machine,so not really sure what's wrong.
If its brand new, perhaps give the dealer a call for some help troubleshooting your issue.
Not sure what you mean by handwheel? do you have a manual with this machine that you could check out, most manuals will have trouble shooting at the back as well as the instructions to use it.
Mar 09, 2011 | Bernina 1008
Viking 936 Serger- handwheel will not turn properly
hi there,
this type of problem related to "overload protection" the motor can't overcome the load work,then it would able to stop your machine,theres problem on motor assembly try to check the carbon brush.if worn out replace,handwheel are couple to motor pulley inside machine.there an opening for the belt.if you want to check it loosen bolt cover,have move the belt you can figure why handwheel moving tight.if you realease the belt handwheel will move independently but handwheel is connected to a cam shaft w/mechanical link connected such as gears,cam and bushing that
can also suspiciuos of obstruction can came there.take this to service center if trouble link to mechanical problem.have a nice day
rate me and thank's
Apr 19, 2009 | PfaFF Hobby 4260
Singer Featherweight 140Q Logo
222 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
