Question about Gateway T-1625 Notebook
Gateway T-1625 media buttons won't lid, (should they?)
Only the main button with that activates windows vista media did light up in two occasions (just received the computer form eBay). It won't anymore, I am not sure if it's because I messed with the power options. However, something tells me the rest, FF, FW. Stop buttons should also light up when pressed and none does. Help please, can't find any info on it in Gateway's website.
Thank you!!!
Gateway laptop wireless button
Hold down Fn key and hit F2. It will be used to turn on and turn off the wireless switch.
If you have window vista, Click Start, All Programs, Accessories, Window Mobility Centre, Turn Wireless On.
Apr 15, 2010 | Gateway T-1625 Notebook
Gateway T-1625 Laptop won't boot up - screen blank
Yes, if the CPU/motherboard will not POST (Power On Self Test), then changing the CPU is the only thing that you have not tried.
Sep 10, 2009 | Gateway T-1625 Notebook
Mouse is not accepted by the system.
it is likely that the mouse is not compatible with Vista
Jul 15, 2009 | Gateway T-1625 Notebook
1625 no boot
Try to Repair your windows from original CD. Boot from CD and follow instructions for Repairing your Windows. Most probably this error will remove after this repairing process.
Please report back to the thread the results of your work.
Regards;
Hassan
Jul 14, 2009 | Gateway T-1625 Notebook
How i can start recovery from partition D
Hi Sir, Welcome to FixYa.
You can find the detailed solution of your recovery problem at this link
http://support.gateway.com/s/software/MICROSOF/vista/7515418/7515418su531.shtml
I solved my problem of recovery using this. Think you also might get help from this
If you find posts helpful, answer 'Yes' below
Jul 06, 2009 | Gateway T-1625 Notebook
Gateway t 1625 laptop not booting
If u can, try to reformat it, reason i say this simple solution is because u already had the laptop looked at professionally, and due to you're laptop being stuck at the windows screen, i see this happen on HDD swaps a lot. The HDD needs to be repair-formatted or fully reformatted to talk to the new mobo when switched out, try this if all else fails, i personally think giving this simple solution may fix the boot up issue, but do make sure ur friend who looked at your laptop hadn't reset ur C MOS and may of not reconfigured it, this may also be the main cause of boot up troubles so make sure everything looks fine in ur BIOS. Gabriel will have a more proper solution than this but i believe by doing this it may help u bypass ur loading issue
Jun 24, 2009 | Gateway T-1625 Notebook
Gateway T-1625 - System only recognizes parts of the Memory
I bet that the video card on the motherboard is using some of your main memory. As for the cpu driver I would go to the device manager and revert back to last driver or use a utillity like Uniblue's DriverScaner.
Jun 05, 2009 | Gateway T-1625 Notebook
Gateway T-1625 Laptop won't boot up at all
It sounds like a motherboard issue. The fan spinning and the LED lights are running off of battery power. This indicates that power is getting to the system. You should look into replacing the motherboard at this point. Before you replace the motherboard feel your system to see if there are any really hot spots that would indicate overheating. If not proceed with the replacement. If so, let me know where the hot spot is.
Regards
Dec 20, 2008 | Gateway T-1625 Notebook
Gateway T-1625 Notebook Logo
246 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
