Question about Car Audio & Video
Radio works intermittent - 0603 code / CHECK on the display
2003 passat stock monsoon radio started shutting off and popping intermittently, now will light up and say CHECK or 0603 and no buttons will work ??
  • 78 Answers
Some can go into "security mode" if power was lost. Popping sound doesnt sound good to me, VW often has seperate amp under driver dash. Id check all power sources but I bet the error code is mech failure.
Posted on Jul 07, 2009
I have a 2009 VW Beetle with a Monsoon radio. While driving, the radio suddenly starts seeking or scanning through all the FM stations - looping constantly. I can't seem to get it to stop on one chann
Seems to be a common problem:
http://newbeetle.org/forums/car-audio/47902-complete-guide-factory-audio-systems.html
Hope this helps they seem to know their stuff and there is a complete pdf manual for Moonsoon but I would hazard a guess and say you may well need a new one or aftermarket one soon
Sep 19, 2014 | 2009 Volkswagen Beetle
Radio does not work
what kind of vehicle? Is it a stock radio? Does it never work or is it intermittent?
check fuses and grounds to the stereo. If that all works then its probably the radio itself.
Lastly if you'd provide more info then maybe somebody could give you better tips. Good luck
Feb 11, 2013 | Saturn Cars & Trucks
CP185 has intermittent static, when pressing button to talk screen displays "channel busy" and battery will not keep a charge.
Could be one of several issues. A few which come to mind are:
1) You have a bad or poorly charged battery. Static is a sign of a bad or poorly charged battery. Try swapping a battery from another radio, with a known good battery and see if the problem is solve. If this resolves the issue check your battery and charger. Tip: Clean all charge contacts with a pencil eraser to ensure good charging. Also, check your 3- or 4-digit date code on the battery. If more than 2 years old, replace the battery. (4-digit date code example 1303 would be 2013 the 3rd week; on 3-digit date codes the first number is the year and the next two the week of the year.)
2) You are trying to use the radio in an area where you are experiences high RF on your frequency. This is the "busy"... someone/something is on or near your radio's frequency and interfering with transmission. Try your radio at a different location and see if the problem persists.
3) Another radio in the workgroup is stuck in transmit, causing static, and the channel busy. Turn off other radios, one at a time, and see if the problem still exists.
4) Or if you have an audio device plugged into the radio, try unplugging it and see if the problem stops. FYI: All audio devices must be plugged or unplugged with the radio shut off. If you plug one in with the radio turned on, you can experience some unexpected intermittent issues.
If none of these seem to be the problem, your radio is likely in need of repair.
Best regards.
Jan 17, 2013 | Motorola CP185 (16 Channels) Two Way Radio
03 silverado radio worked this morning.started it in afternoon no sound but display lights up.
No solution but same problem. However mine intermittent. It will come on and run the passenger side speakers and then shut off. All panel displays are on. Next day same thing. I think it has something to do with weather. When it is below 30 deg it doesn't work. When it gets 45 deg and up it works somewhat. It sounds like a bad circuit board connection.
Sep 09, 2010 | 2003 Chevrolet Silverado 1500
2003 Envoy intermittent display, radio, ac control, shift, comp.
This sounds like your alternator maybe going bad. When your alternator starts to go bad lights such as headlights, radio lights will go dim wipers will start to move slower but if you cut one of the things off such as the wipers the lights will get brighter for a few minutes then not long the car will shut completely down. Hope this helps.
Jul 22, 2009 | 2003 GMC Envoy Xl
2003 vw monsoon stereo control my ipod?
there are adaptors that go between antenna and radio that ipods will disrupt the signal and work that way
Jul 21, 2009 | 2003 Volkswagen Passat
2003 Volkswagon Passat Monsoon Radio, nosound,
checek the speekers they may be unpluged.
Jul 14, 2009 | 2003 Volkswagen Passat
I bought a used 2003 Jetta for my daughter with only 12,000 miles on it. The Monsoon radio suddenly stopped working. The display shows FM 88.1 (the radio staion) but there is no sound and the radio is...
I have come to find out that in the 90's auto makers started installing factory amplifiers in their cars so they could use low wattage stereos in the dash. It's usually a blue wire off the stereo that runs the amp, maybe it couldve become disconnected? I also know that even if you put in an after market stereo, this wire must be hooked up or you'll get no sound from the speakers. hope this helps.
May 26, 2009 | 2003 Volkswagen Jetta TDI
Monsoon cd changer gives message - changer parked
Ok, there has been a discussion about this over on g6performance.com.
Here is a copy of the service bulletin one of the guys there dug up:
#PIC4509A: Radio Displays Changer Parked Message - keywords battery CD display int intermittent intermittently no owners park radio - (Dec 27, 2007)
Subject: Radio Displays "Changer Parked" Message
Models: 2004-2007 Chevrolet Malibu
2008 Chevrolet Malibu Classic
2005-2008 Pontiac G6
This PI was superseded to update models and model years. Please discard PIC4509.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
A customer may comment that the radio will display a "Changer Parked" message intermittently at times, and there is NO explanation in the owner's manual for this message.
Recommendation/Instructions:
This message will display after the CD mechanism has initialized or when you manually park the CD mechanism. Initialization occurs normally upon a battery reconnect. The mechanism will unpark itself once you press the CD load button.
Note: After pressing the CD load button, you will NOT get a message that's it's unparked.
Nov 26, 2008 | Car Audio & Video
Car Audio & Video Logo
214 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
