Question about Garden
How to replace line in ST5400
Replace line in a B & D ST4500?
Ground wire off on Black& Decker Trimmer Motor ST4500 Type 2.Where does it go? Is there a diagram?
Follow the steps in the manual if you have a manual and if you don't have one I recommend that you get one.
May 09, 2014 | Garden
.brakes line locateions 1996 gmc 1500
Have to fabricate new brake tubing & just replace the rusted
lines as you see them.
If you get under there & look, you will have your answer
A guess from my experience, would say you start at the proportioning valve & go past the door & leak, to the rear
somewhere at a junction block on the axle housing or to an
abs hcu unit, if one of them there along the way
Sometimes you need to make two lines with a union under the door,
as that is the longest run under a truck & to do one piece may not be
possible & get it in place, with all the bends & things you have to pass
On a 1996, I would suggest you bleed all four corners first
Then remove the master cylinder & clean out the moisture
Then replace All rubber flex hoses
Then replace the entire brake system lines
Once one rusts out, their all months apart & unsafe to use
piece mealing it one section at a time
Apr 09, 2014 | 2002 GMC Sierra 1500
Nissan Patrol 98 petrol valve clearance
hi, i have a nissan patrol st4500 running on gas and petrol and I need a new valve since it has been bad to switch between gas and petrol, do any of you know where I can order it?
Mar 30, 2012 | Cars & Trucks
Please advise if your Black & Decker Weed Thrasher model # ST4500, has been recalled? I purchased mine less than a year ago and used it now approximately 12 times and it is dead, no power? I have...
Black & Decker warranties all of their products for at least 1 year, and some of their units for 2 years. Go to http://www.blackanddecker.com/Service-Centers.aspx to find your nearest authorized repair facility. Do not return it to the store you bought it from.
Good luck
Dec 03, 2010 | Weed Thrasher For Gas Grass Trimmer Wacker...
Leaking fluid
Only so many places these trans 41 TE can leak on the vans. Lines on top, speed sensors(input, output)one is below the lines the other is to right of the lines. Dipstick tube, trans solenoid gasket, Oil pan & extension gasket. Wipe off & clean area very well. Lines leaking, check clamps first before replacing. Speed sensor leaking replace o ring, Dipstick tube replace o ring, Trans solenoid replace gasket, Extension plate replace gasket If the pan is leaking you change the trans filter & put a gasket on the pan. The book says RTV on the pan, but FelPro make a gasket for the pan $6.99. Use a Chrysler trans filter!!!! O rings for sensors, tube around $3 each, trans solenoid gasket $3, extension gasket $10, Filter $11 + gasket $7 & 4qts trans fluid if doing the filter or extension gasket.
Jan 18, 2010 | 2000 Dodge Caravan
WHAT MAINTANCE IS RECOMENDED FOR A PRELUDE 1998 WITH 165K
Replace Balance shaft belt
Inspect Brake lines, hoses & connections
Inspect Brakes
replace Coolant
Inspect Cooling system
Inspect boots & seals Drive axles
Inspect Exhaust system
Inspect Fluid levels
Inspect Fuel lines & hoses
Check Idle speed
Inspect/adjust Parking brake
Replace Spark plugs
Inspect Steering linkage
Inspect Suspension
Inspect Tie rod ends
Replace Timing belt
Inspect Water pump
Rotate/adjust air pressure in Wheels & tires
Sep 25, 2009 | 1998 Honda Prelude
Did the black and decker ST4500 weed trimmer get recalled I heared on the news that a black and decker weed trimmer got recalled Im just not sure what model
I haven't heard this, but you can go to their website and check, or call Lowe's, H-Depot service departments and they might know. I do know that they both post consumer recall notices, and they'll check their board for you.
Regards, --W/D--
Aug 09, 2009 | Black & Decker String Trimmer Cordless 12"...
Vertical 1 line
Check voltage supply at vertical amp ic ,if present than change vertical amp ic.Some times supply line is dameged by faulty amp ic.therefore you have to rctify supply and replace ic.Check supply line fusible resistors.
gopal
Dec 13, 2007 | Televison & Video
Garden Logo
116 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
