Question about Home
Need wire schematics -circuit panel box & heat element ARIES SPA
Need wire schematics for circuit panel box and heating element wires on ARIES SPA curcuit box model # TH026KWf2 AASofb(LT) serial # 059372
    Scholar:
  • 80 Answers
Did you check inside the cover of the control box. Most spa's have a schematic of their components there. Hope it is there.
Posted on Aug 19, 2009
I HAVE A 2 1/2 TON PACKAGE HEAT PUMP . THE60 AMP BREAKER AT THE DISCONNECT BOX KEPT TRIPPING . I DISCONNECTED THE HEAT STRIPS AND NOW THE 60 AMP BREAKER ISNT TRIPPING . WHAT IS CAUSING MY BREAKER TO T
You need to check the current rating of your heat strips. If it is more than 60 amps then you need a bigger breaker. If 60 amps or less then your heat strips are going bad. Also make sure your fan turns smoothly without any wobble.
Jan 06, 2014 | Electrical Supplies
I need to know if a double pole 30 breaker acts as a jumper from 1 hot bar to the other.
1) Copy following links:
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-8-8.jpg
http://waterheatertimer.org/Color-codewire.html
2) Double-pole circuit breaker snaps down over both hot busbars.
Each busbar supplies 120Volts, and each busbar is out-of-phase with the other busbar. Together, the two 120volt out-of-phase wires have 240Volt potential.
3) Does the double-pole breaker act as a jumper?
No.
Typically a 'jumper' wire bonds two electrical connections together so power flows between the things that are jumpered together.
If you 'jumper' one busbar to the other busbar in live 240V split phase panel, it will short out.
4) 240Volt circuit requires two hot wires. One hot from each busbar.
When the two hots are applied to two screws on a heating element, that action will complete circuit, and element will heat.
Instead of shorting out, the element has resistance in the form of a coil of wire that impedes the flow of current and converts the electric current into heat at the element.
This is same as filament inside light bulb.
If the element does not have resistance to impede current, then the two hot wires in the 240Volt circuit will short out and cause flash of overheating and burning that will burn out element. If element does not burn out immediately, and short continues, then the wire connected to circuit breaker begins to heat. When heat on wire exceeds circuit breaker rating, then the breaker trips off.
Circuit breakers are triggered by heat.
This is why wire size and breaker size must match.., to avoid overheated wire inside wall that will catch house on fire.
Dec 23, 2012 | Electrical Supplies
I have a fisher & Paykel electric dryer. D-DE62T27D that works but won't dry. Any solutions? Thanks Rick
Disconnect the power source to your dryer before you conduct this or any other test. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Dryer heating elements come in various shapes and sizes. They are all strung with a coiled wire made of a nickel and a chrome alloy. This wire receives, but resists, a controlled electric current and as a result, the wire heats up. The heat produced is used to heat and dry the clothes in your dryer.
Once you have gained access to your dryer's heating element, set your multimeter to the R x 1 resistance scale. Touch each meter probe and to one end of the element. If you receive a reading of infinite resistance, then your heating element is no longer functioning properly and you will have to replace it.
Jul 12, 2011 | Fisher and Paykel DEGX1 Electric Dryer
50amp breaker for spa heater gets hot after about 45 minutes and then trips. does it need replaced?
MUCH more likely that your heating element needs to be replaced. Check all connections for heat damage, due to resistance. If you ever stop water flow, the heater MUST be turned off, or you can kill it. Fortunately, it costs tons less than the breaker.
Mar 05, 2011 | Siemens 50 Amp Ground Fault Circuit...
OUR WATER HEATER IS BLOWING FUSES ..
1) Turn off power before touching water heater that is shorting or wet or was flooded.
2) Circuit breakers & fuses blow because of heat. A short will cause heat. Tighten screws on terminals inside box, listen for crackling sound/burning smell from loose-fitting parts.
3) Easy test for circuit breakers: move water heater wires to another same-size breaker. If same-size does not blow, then problem is breaker.
4) A short between fuse box and water heater could be gnawed electrical wire. Inspect wire.
5) Wires have size markings. 5500 watt water heater needs #10 wire. 4500 watt water heater needs #10 wire but can work with smaller #12 if distance is not long. See label on side of heater for wattage, voltage, etc. Element wattage is water heater wattage even with 2 elements.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
6) Short inside water heater can be elements or thermostat. Open covers and inspect parts for burning. Screws should be very tight against copper wire. Sediment could fill bottom of water heater cause lower element to short.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Sep 16, 2010 | Little Giant Water Heaters
Roper model rex5634kq1----won't get hot---already removed &ck'd heating element & attached part (thermostat?)--they're both ok--what else could it be?
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Dec 31, 2009 | Dryers
Water heater keeps popin the breaker replaces breaker still no good. new heater just installed all wires are good
I assume this is a 240 volt water heater that runs on a 30 amp circuit. Read the instructions that came with the new water heater to be sure. If the wires are connected correctly then you have a defective water heater. Let's first make sure it is wired correctly. Turn the breaker off and take a look at it. It must be a 30 Amp breaker and the wires going to the water heater must be 10/2 with ground. This is an orange wire. If you cannot see the water heater from the service panel it must be wired to a disconnect box. Look at the breaker and make sure the red & black wires are tightly connected to the double pole breaker and the copper wire is connected to the ground bar. At the disconnect box (if applicable) the red/black wires from the service panel must be connect to LINE and ground to ground bar. The wire going to the water heater from the disconnect box is connected to LOAD. It is easy to get these mixed up because they are not always in the same location and are hard to read on some disconnect boxes. Look carefully and make sure they are correct. At the water heater you connect Black to Black and Red to Red. Make sure the ground is connected tightly and none of the wires are touching each other. Use wire nuts and then tape the connections with electrical tape. You should not have applied power to the water heater until it was full of water. If you did then your burnt out the electrodes. I would suspect you have a short somewhere or the water heater is defective.
Dec 10, 2009 | Cars & Trucks
No heat in dryer
Hi
Thanks for using FixYa. If your dryer isn't working or isn't getting heated up, you'll need to check the following to be sure what exactly the issue is--
Blows fuses or trips circuit breaker —ELECTRIC Models:
• The amperage readings are at 240 volts. One line will be 24 amps and the other line will be 21 amps. The neutral line will be at 3 amps. If the above amperages are not present, then the house wiring, fuse box or circuit breaker should be suspect.
• Shorted heating element to housing.
• Incorrect wiring or a wire shorting to ground.
• Drive motor winding shorting to ground.
Blows fuses or trips circuit breaker —GAS Models:
• If igniter is not glowing, check for 120 V at igniter.
• Igniter harness may be loose and shorted to base.
• Incorrect wiring or a wire shorted to ground.
If it runs for a few minutes and then stops, then check for the following:--
• Empty dryer.
• Check motor spins freely.
• Lint buildup around drive motor.
• Low voltage present.
• Blower impeller blocked in blower housing.
• Drive motor - start switch contacts stuck closed.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 12, 2009 | KitchenAid Dryers
No heat, 120 power to only one leg of heating element. The power was read on the side of the heating element that came from switches. I do not have a schematic, so it is hard to ttrouble shoot, not knowing...
Heating element
Thermal fuse
Wiring
Jul 31, 2009 | Dryers
30 amp breaker trips intermittently
It sounds like this circuit breaker is worn out and needs to be replaced. good luck
Jan 19, 2009 | Siemens 2 pole 30 amp breaker
Home Logo
705 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
