Question about Grilling
New bbq won't light
I just bought a brand new patio chef lower end bbq, spent 2 hrs assembling it following the directions EXACTLY and it will not light. I connected a new, full propane tank, turn the knob fully on, put the burner on high, and press the igniter button. nothing happens. I tried lighting it with a match but no go. I smell the gas, so that's coming through but I can't figure out why it won't light. help!
  • Anonymous May 13, 2009
    We boutght Char Griller model 3001 and can't get it to light. Hear only a clicking noise when pressing it in.
    Sergeant:
  • 187 Answers
Try turning the gas down a little while you use a match?
Posted on Aug 07, 2017
SOURCE: no gas getting to bbq
I switched to the new style 20# tank with the new turn-on knob.  I couldn't get enough gas pressure to the BBQ burners for all three burners to light or to keep a strong flame on even one burner.  The new style tanks have a safety valve on the inside of the tank that shuts the gas off if you turn the knob on too fast because the safety valve thinks there is leak.  Shut everything off and then try turning the knob on real slow, especially at first, before turning it all the way on.  If that doesn't work (it didn't for me), then replace the large plastic connection valve knob (female end) that attaches the regulator to the tank.  Mine was for the old style tank and was black (low pressure).  I went to a propane company and had them replace it with a green knob (higher pressure).  Took it home and WALA!  Everything works fine now.  But it was very frustrating trying to figure why I couldn't get any gas to the burners after buying a brand new tank.  I hope this helps solve your problems.
Posted on Dec 22, 2008
  • 494 Answers
SOURCE: Can't light the bbq
You make have turned the propane tank valve on too fast. Close the valve, disconnect it, reconnect it and very slowly turn the tank valve back on. That should solve your problem.
Posted on May 31, 2010
  • 218 Answers
SOURCE: Just attaached the full Propane
the regulator has went bad and needs replaced.
Posted on Aug 17, 2010
SOURCE: Hi, I am problems with my Cadac Carri Chef bbq.
I brought a Cadac grill BBQ about 2 years ago. We used it on the weekend and found that it wasn't getting hot. to our surprise it wasn't burning properly. there was no blue flame just a flame which made all the nuder neath turn to soot and very black. We took it apart and found that where the cylinder slides into the top of the cooker, that inside the sylinder is a blue plastic molding which has melted. there should not be any heat at all in this area, so can any one help with why and how 2 fix it.
Posted on Jun 12, 2011
SOURCE: cadac Carri Chef bbq replacement gas valve.
Remove grey plastic cover by removing two screws inside cooking area, then pop handle off valve, undo nuts to release valve body, carefully remove two screws in body, watch out for spring!
Take the small hexagon jet out of other end, find a small straight item that will pass through hole where jet was, tap the internal part out of the main body , clean everything up, probably carbon on it! Apply a tiny bit of oil to the plug you tapped out, avoid the tiny hole in plug! Now reverse the strip down, making sure that the valve goes back together the right way and still turns through right sequence! Normal cause of it sticking is not pushing it in whilst turning off!
Email me at grundy
Posted on Sep 30, 2011
Need assembly instructions for a jackaroo flinders 4 burner bbq
It is a discontinued product so you are probably going to have to just lay all the parts out and guess. You could also look for assembly instructions for a similar BBQ made by Weber. They all follow a logical sequence.
I did find reviews, you could ask if anyone has the manual and when you ask a question, the question is sent to those who have reviewed already.
Jackeroo Flinders 4 Burner
Dec 28, 2015 | BBQ Guys Grilling
How can a roast chicken,beef or pork in my patio bbq? how many burners should I use with the bbq covered? should be on hi or low ? how many degrees 200? or more?
Hi Gary....advise make and model of your bbq and I will
try and find out where you can get a manual..
Regards,
Dennis
Oct 13, 2014 | Grilling
Just bought a brand new pre-assembled unit from Lowe's - same problem! Can't get any propane flow through the valve in the normal position. Spent the last 2 hours just getting the pilot light to work -...
Try having all propane turned OFF. some systems auto shut off for leaks. SO....if you have the valve turned on when you open the tank valve, safety systems stop flow.
Dec 25, 2010 | Rta International Patio Heater
Patio comfort heater won't light
Sometimes you have to completely disassemble the pilot assembly to clear the blockage, the orifice for the pilot jet is very small and you can not get directly to it unless you take it apart. If this does not help, you may need a new valve.
Jul 12, 2009 | Stainless Patio Comfort Natural Gas Steel...
A friend just gave me her chefs and bakers gourmet BBQ grill. They've used it recently and works but believe it needs cleaned or new burners as food doesn't cook evenly. I've never had a gas grill so I'm...
it is abaker and chefs 9905TB-LPG grill
go to the following link, if you want, you can copy the part number for the parts you need and order it from your nearest appliance repair center.
http://www.appliancefactoryparts.com/search/modelinfo.php?modelsID=8413
Mar 23, 2009 | Grilling
Need leveling screws (bolts) for my patio table legs
Hi I would try a local patio supply place. Something like BBQ galore
Dec 17, 2008 | Hardware & Accessories
Grilling Logo
646 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Marvin
Marvin
Are you a Grilling Expert? Answer questions, earn points and help others
