Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
GE WHDSR209DAWW I have a GE washer, the water will not shut off. It will fill up and then over flow.
Won't agitate
Posted on Feb 22, 2009
  • 64 Answers
The water level pressure system is blocked
Posted on Oct 26, 2007
2 Suggested Answers
beltronic205
  • 1474 Answers
SOURCE: GE Washer Wont Fill
Make sure drain hose not too low , creating syphon...
Posted on Jun 01, 2010
Testimonial: "After posting this question I saw something on the internet suggesting the same. I think this must have been the problem. Thanks for your help!"
What does Code nf on washer machine Samsung vrt model mean
NF indicates no water flow. This could mean that the incoming water valves were shut-off, the incoming water flow is low, or that the washer didn't detect the water flow into the washer correctly. If the drain hose is too low, the washer could fill and drain simultaneously. This can also cause the problem.
First if the washer is not getting any water, then check your shut-off valves and the hoses. Disconnect the hoses from the washer and place a bucket under them. Check the flow by turning on each valve for a bit. Clean or replace the filters at the shut-off valves and in the washer. Consider replacing the hoses. Some anti-flood hoses will reduce the water flow if they detect leaks. Make sure that the hoses are not kinked. If the water flow is good at the shut-off valves, then the inlet valve may have failed in the closed position.
If water is filling the washer, then the problem is in the water flow detection system. This could indicate the small reed switch is damaged, the air tube to the reed switch is clogged or that tube has a hole in it. Some washers check for fill by the change in the drum weight. This signal may not be reaching the control unit due to a problem with the sensor or the wiring.
If the washer is filling and draining, pull your drain hose up. It is below the washer fill level. This creates a vacuum that will drain the washer.
I hope this helps.
Aug 25, 2017 | Samsung Washing Machines
My g.e washer does not fill with water mod#whdsr209daww
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Jan 11, 2013 | GE G.e. Gtwn4950lws He Top Load Washer
Water won't shut off when the washer is filling up
the water pressure switch that controls water flow on the control panel is defective
Jan 31, 2011 | GE WJSE3110A Top Load Washer
GE Washer Wont Fill
Jun 01, 2010 | Washing Machines
Washing maohine doesn't take water '
If you have established that the water is reaching the washer, then either there is ni power to the valves, or the valves are faulty.
Hope this helps.
Jan 27, 2010 | GE Washing Machines
Same problem...water won't shut off but drains in the spin cycle.
Hello my fellow Mountaineer. I think your problem is most likely being caused by a defective water level switch. This switch senses the water level in the tub and shuts off the water. It's usually a diaphragm like device with a small clear plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, the pressure on the air in the tube increases and when the pressure reaches a certain level it signals the switch to shut the water off and signals the timer to begin the agitate cycle. Clear any obstruction in the tube or replace the switch. Hope this helped. GO MOUNTAINEERS!
Jul 19, 2009 | GE WHRE5260E Top Load Washer
Cold water flows just fine, within 2 minutes the flow is down to
Make sure you clean both screens at each end of hose. If they are clean,you got dirt caught in valve. Good luck.
Jul 17, 2009 | GE Washing Machines
No spin - agitate
You just do this
  • Test the lid switch
  • Inspect the motor coupler
  • Inspect the drover belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the Agitator
  • Inspect the pump coupling
  • Test the Water switch level
Good luck !!!
Regards
PCmania
Jul 08, 2009 | GE Washing Machines
Water Won't Drain from Washing Machine
Hello phylislw61,
If you had an incident where a pillow broke and feathers where dispersed throughout the washer..then there is a good chance that teh drain fiilter screen, pump or hose feeding the pump is clogged. I would verify that the filter is free from anything that would limit water flow from getting to the pump.. then if the problem is still there.. examine the pump itself to make sure it isn't clogged...
If you or someone in your family is reasonably handy, here is a link to your washing machines exploded view and parts and this should provide sufficient information for how to access the pump and associated hoses etc that feed into and out of it for cleaning..
If you are having problems after you verify the lines are free of restriction, feel free to contact me and I will try to assist you in solving your problem.. Here is the link..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Dec 06, 2008 | Roper RAS8445KQ Top Load Washer
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
519 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
