Question about Locks & Locksmithing
Outside parts for our main door lockset lost the shine
The outside parts for our main door brass-look lockset got discolored with age - lost the shine. Is there a way to replace just those parts without having the buy and install a full lock set for main door?
  • 104 Answers
Have you thought about respraying them , i do it all the time as i,m a fully qualified painter -decorator ,
just remove the locks thoroughly clean them in mineral turps then allow to dry , spray with metal primer leave to dry then spray with brass coloured spray paint , you can even spray over the top with clear coat to retain the shine , they will look good as new [ actually better ]
Posted on Jun 06, 2009
Chevy Venture 2002: power sliding door want open using buttons. Electric motor will engage and open door when outside door handle is used. Door closes fine electrically using button or handle.
Try using steel wool to clean the contacts for the door. Open the side door. See the brass pins sticking out from the door? Clean those. Then look at the plate with brass squares near the bottom of the door opening, where the brass pins would eventually make contact. Steel wool those too. Might make a couple of little sparks but don't worry. See if that helps.
Sep 13, 2017 | Chevrolet Venture Cars & Trucks
Cannot enter user codes. shuts down before all digits are entered.
Sounds like either your batteries are dead or you have a wiring problem inside. First try replacing all the batteries in the lockset and see if that fixes the problem. If not remove the lockset from your door and see if you have any water damage inside. If you have water damage then you are getting a short in the lockset causing it to not open up. The best solution is to get a new lock unless you can find a place to fix the wiring on the inside. If you bought the lockset from Alarm Lock I think they might cover that on a warranty. If not I don't know. Check on that and see. When you go to install the lockset make sure to seal the outside of the lockset with either silicone, caulking, or any other water proof sealant. Water can be very lethal to electronic locks. If you need help on installing one I might be able to help as well.
Feb 25, 2013 | Alarm Lock DL5200 Trilogy Electronic...
How do you clean headlights on a 2002 chevy impala?
They can be adjusted up/down. see picture for adjustment screw.
The headlight housing can leak and condensation will form inside and maybe stain the inside. It is very difficult to take the housing apart... do go there.
It's more likely that that outside of the headlight is discolored with age. There are kits available at parts stores to recondition the outside of the lense.
The bulbs will also get dimmer with age. I recommend Philips VisionPlus; 9006 for low beams. You can get a pair on Ebay for $20 or less. They'll be $40-50/pr at the parts store.
This headlight is the easiest I have ever seen to remove. The headlamp can be easily removed by pulling up on the two white strips about a half inch (??). Then wiggle and pull the assembly straight forward.
Jan 01, 2013 | 2002 Chevrolet Impala
I have a Larson storm door with an Intevia Keyless lockset. The door handle assembly comes apart, i.e. when I pull on the outside door handle it comes completely out of the door! How do I fix this?
I've been unable to find any installation instructions or diagrams for your lock. However, here is the customer service contact information. Call them:
Homeowner Helpline:
1-800-352-3360
Monday - Friday
7:30am - 4:30pm CST
Feb 27, 2012 | Locks & Locksmithing
We have a new Larson Storm Door with an Intevia Keyless Electronic Lockset. We know that it is working as we can hit the button once on the inside and it will lock and like wise we can hit it again and it...
I MESSED AROUND WITH ONE OF THESE LOCKS ON A LARSON STORM DOOR LAST SUMMER. IT ATE LITHIUM BATTERIES FASTER THAN I COULD BUY THEM. DO YOURSELF A FAVOR AND REMOVE THE LOCKSET, LIMBER UP YOUR ARM AND THROW IT AS FAR AS YOU CAN. CALL THE FACTORY AND TELL THEM YOU WANT A MANUAL LOCKSET FOR YOUR DOOR. I DID THIS LAST FALL AND HAVE HAD NO PROBLEMS SINCE!
May 01, 2011 | Garden
We have the thumb press elongated handle on the outside of the front door entry. I was ready to enter the front door when I pressed the thumb handle and the whole set fell apart. Need instructions to put...
For the Lido Keyed Entry, go to this page:
http://www.kwikset.com/Products/Details/Door-Levers/740LL-26D-SMT.aspx
and click on "Installation Guide", found under the red text " Technical Documents"
If I've steered you to the wrong lockset, the product main page foe Kwikset can be found here:
http://www.kwikset.com/Products/Categories/Handlesets.aspx
Feb 13, 2011 | Kwikset 4 Lido Lh Passage Levers Satin...
Our Qwikset Powebolt system is not working properly. I can lock the door from the inside and someone on the outside only has to press the lock key and it opens! How do we resolve this issue?
I think that you lockset is not set up for the proper "handing" of the door; that is, are the hinges on the left or right as you face the door from the outside. Although is see on the Kwikset website that the Powerbolt can be changed, I did not find out how to do it. I suggest that you call their Customer Service and they should be able to explain how to change it over. Here's the link:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Consumer Service
19701 DaVinci
Lake Forest, CA 92610
Kwikset Customer Service
Call: 1-800-327-LOCK (5625)
Feb 09, 2011 | Kwikset UltraMax Powerbolt 1000
Pulled of doorknob, all the peices fell out and now i cant put it back together
If this is an inside door from an old house, just take another one apart very slowly to see how the pieces fit. If this is an an outside door from a newer house, you might want to just buy a new lockset and follow the directions carefully. I assume you took it apart because it wasn't working anyway.
Jan 04, 2010 | Top Knobs M826 Door Pull
Hi, we have Kwik Set polished brass locks on our exterior doors that have discolored. We have lived in our newly built home since 2000. You have replaced our locks on the front door once and now both the...
We replace locks? News to me!
Well heres a cleaning tip.
Brass will tarnish in weather and from hand oils, so if you want to clean them and have them shine again like new. Next time you boil peeled potatoes, save the water and using a plastic scourer apply the potato water to the brass and rub gently. Then finish off with a soft cloth
Kindly rate our help++++Thanks for using FIXYA
Oct 16, 2009 | Kwikset 907 907-L03 Lifetime Polished...
MintCraft entry door lockset one will not stay locked ,
Try reversing or flipping them upside down.....If you put them on in the same day, Parts may have gotten Mixed up..... Try combining and Such as to make Things work....As long as you have all the parts that came with it...It should work.......Hope this helps.....Joe
Dec 30, 2008 | Hardware & Accessories
Locks & Locksmithing Logo
95 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
