Question about 2wire (1000-100052-000) 802.11g/b Wireless Adapter
Wireless adaptor problem
Hi I am using your wireless adapter and i cannot get it to work. I can go all the way through the installation process using the passwords and everything but at the end it says that my 2 wire wireless is not working or is not plugged in. I have it plugged into one of my usb ports, so I cannot determine what the problem is, i tried plugging it into my other ports and it comes up the same. I am using a desktop computer ans the main 2 wire is in another room and that one works fine. What do you suggest??  jim
  • endopain Mar 03, 2008
    i'm having same problem as guest. mine keeps coming uninstalled ans it's still plugged in. i was thinking i was gonna have to get a new one. but at&t doesn't offer them. i have the usb wireless adapter and also have windows xp pack 2
I have xp pack 2 (had same problem w/ pack 1), mine keeps coming uninstalled some how. it doesn't get unplugged, but it says device not connected. it won't let me reinstall it. i look in network and have no devices. anyhelp would be appreciated.
Posted on Feb 24, 2008
How is he going to download pack 2 if CAN'T CONNECT TO INTERNET.....MORON.
Posted on Dec 13, 2007
Download micosoft pack 2 for xp
Posted on Oct 13, 2007
Cyclic Redundancy Error
HI! this is Alex Walker expert to fix this issue for you call +1(518)348-9393 Thank You
Jul 03, 2017 | NetGear WG111V2 Wireless Adapter
My wireless adaptor seems to have disappeared from my PC. I can't see available networks and can't see the adaptor under hardware.
Download and install this driver-->click here to download
to open zip files use Winrar .
Save it to your desktop --->Double-click the ".EXE" file. Select "Run." Wait for the wireless adaptor driver to install-->plug in the adapter -->restart your computer.
Plug the wireless adapter in another usb port than the previous time.
Dec 07, 2010 | ASUS (WL-167G) 802.11g/b (wl167g) Wireless...
My wireless adaptor isn't working. I have an Acer travel mate5720 which has a switch on the front for blue tooth & wireless access. Bluetooth works ok but the Wireless adaptor won't i have checked in...
This model does have wireless. I had a similar problem a little while ago, I plugged the unit in to a wired connection, and on it's own, disabled the wireless adapter.
Go to start--> control panel--system-->hardware-->device manager
look under the "network adapters", there should be a wireless adapter or 802g something something, right click on this item and click "enable".
You should then be able to browse for wireless networks now.
Jan 06, 2010 | Acer TravelMate 5720-6635 Notebook
I am trying to install a wireless usb adapter. Problem installing driver software "process cannot access the file because it is being used by another process2 please help
Did you have a similar wireless adapter install previous to this one? If the software is similar then you need to uninstall the old software so that you can install the new software. The problem might be the old software version is running and you can't write over a file that is running. You can't delete or overwrite it until that process is closed.
Oct 01, 2009 | Belkin (F5D7230-4) Router (587009)
Cannot aquire ip address from wireless router
Hi, If your newer usb wireless adaptor does not have the same settings as your router this is the problem you have. First make sure you have installed the cd software that came with the usb adaptor without it plugged in. After that is complete make sure the wireless adaptor is seen by the computer it is attached to. Then you need to open the settings of the usb adaptor and set it up same as your router's settings. This includes the WEP security password if you use it. Good Luck.
Sep 19, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
NETGEAR WG311v3 Wireless PCI adapter STUCK on scanning.
Hi
What you to do first verify that the device is installed properly for that ---
Go to Device manager-- click on Network adaptors -verify the your wireless adaptor is listed there without any yellow or red mark .If you see a yellow mark then you need to install and reinstall the adaptor
Second , You might see an icon for netgear adpaptor in right lower corner under taskbar and you need to Right Click on it , it will show you several options just look for use window to manage wifi or xp wifi client , like that .. sect that option ..
after that it will display a message wireless network detected , click on the messege , you will see your network . select and connect
Mar 29, 2009 | Computers & Internet
Aspire 5050 network adaptor not found ??
ok, the problem is that your wireless adapter of your notebook has not been installed yet. locate the cd that comes with your notebook and install the wireless adapter.
Dec 22, 2008 | Acer Aspire 5050-3242 Notebook
Wireless g usb network adaptor
install BT using ether cable 1st, then unplug and u will be able to use ur wireless card.
Aug 03, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Wireless-G USB 2.0 adaptor stops midway through installation
Are you sure the adapter is VISTA compliant? Some are, some are not. BPCS
Dec 28, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Wireless USB adaptor not found
Hi zlyman, The Belkin N1 Wireless USB 2.0 Network Adapter might be choosy with what motherboard it is attached to. Pls refer to this similar problem > http://www.fixya.com/support/t201253-not_identify_belkin_n1_wireless_usb Hope this be of some help/idea. Post back how things stand or should you need further information. Good luck and kind regards.
Oct 02, 2007 | Belkin N1 Wireless USB 2.0 Network Adapter...
2wire (1000-100052-000) 802.11g/b Wireless Adapter Logo
232 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
