Question about Panasonic (KX-TG1032S) Phone
Panasonic Cordless Phone Set KX-TGA1016
Do I leave the phone on the charger all day if it regesters fully charged already?  Will that hurt the life of the phone?
  • hattimaerita Mar 28, 2009
    Panasonic (KX-TGA600B) handset battery replaced and it is still dead. Nothing at all working.
Yes, leave it on the charger all day, it will not hurt the life of the phone.
Posted on Jan 16, 2008
Panasonic kxtca 121cx link problem
Posted on Aug 03, 2009
My Panasonic kx-tga552m phone will not stay registered to the base. As soon as I re-register it accepts it but then when I go to make call it won't respond. The battery appears charged but I have had the...
Leave the phone off the charger for a day without using it, then measure the voltage of the battery. Brand new is 3.6 V. If it's around 2.8 v or less, then it's time for a battery replacement. They usually only last 2-3 years. That doesn't guarantee a fix, but it's cheap and easy to give it a try.
Jan 12, 2018 | Panasonic KX-TGA552M Cordless Expansion...
I have a panasonic KX-TG5431and for a cordless i have no link to base and the cordless off. the battery is slow after charging. Thanks
Hi, I have the same problem. My set is Panasonic KX-TG6522C. Please let me know how you fixed this issue (if you already have)
Dec 13, 2010 | Panasonic KX-TG5431 Cordless Phone
Phones won't charge
hi,
have tested the charger if it is working?
if you test the charger with another phone and is working perfectly then the charging port of your phone is bad.
the charging port is the port where you insert the charger.
try and get a new charging port and replace with the bad one, the phone will charge.
thanks for using fixya.
Jun 06, 2010 | Panasonic KX-T7885 Cordless Phone
I hit a button on phone, screen went blank, not able to dial. I put in the charger and it is fully charged
If battery is charged and phone is working simply do this: Press the power button for a few seconds, which is the same as the "hang up" button with red ink on it). Voila! It took me serveral days and a number of dealers telling me I had to pend $300 for a new phone before I uncovered this fix.
Feb 16, 2010 | Panasonic KX-TD7896 Cordless Phone
My panasonic kx-tga520m cordless handset does not display caller id anymore. the second handset does display this feature. What should I do?
Because your phone was low on battery, you will not see this feature. Once you charge your phone fully, you will start receive phone calls and you will see this feature activating again.
Jan 18, 2010 | Panasonic KX-TGA520M Cordless Expansion...
Panasonic CORDLESS
1st check that the charger is plugged and energized. It should light up when dropping a hanset into the craddle.
2nd Check that the batteries are connected properly inside the handset and that they have the full voltage. Try 1st step again
Oct 14, 2009 | Panasonic KX-TG1033S Cordless Phone
Battery fully charged but phone dies within a minute
A friend that worked for GTE advised me some yrs ago to do this and I have NOT had a problem with another battery since
when you get any new Battery charge it plugged in to the ac AND phone jack for a minimum of 24 hrs without using it.
all batteries have some memory and deminish power over time but if it was NOT fully charged to begin with as a yr goes by so does the battery life. hope this works,
Apr 16, 2009 | Panasonic KX-TG5438 5.8 GHz Cordless Phone
Panasonic KX-TG6051M 5.8 GHz -Caller ID view problem
I have a panasonic KX-TG6051CM 5.8 phone with 3 handsets. After less than a year 2 of the 3 handsets developed the same problem, almost in the same time ( a couples of hours apart). The battery indicator shows low battery and is charging continuously even though the battery is fully charged ( when i swap the battery with my 3rd handset, the battery indicator shows fully charged and works fine ). The handsets were never dropped, never used in a moisture ladden environment ( like bathroom ) and when not in use they were kept in the charger. Any help or suggestions will be much appreciated.
Mar 23, 2008 | Panasonic KX-TG6051M Cordless Phone
Phone is discharging battery
I assume you mean the phone is discharging it quickly, probably not capabale of holding a long charge anymore, you can get batteries here - Panasonic KX-TG2422 battery
Oct 30, 2007 | Panasonic KX-TG2422W Cordless Phone...
Panasonic (KX-TG1032S) Phone Logo
1,002 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
