Question about GE Profile 22.2 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Black
Not cold I actually have a GE Profile PSC23NGSB. Lights are flashing, the fridge and freezer are not cold. Tried everything in the troubleshooting manual. Nothing is working. Can't find a "showroom" button. Unplugged and plugged back in and tried a new outlet to no avail. Any help is appreciated as it is Sunday. Thanks. Interior lights are on, the LED just flashes HRS and the LED isnt responsive. The fan and the compressor are not on..Not cold..This was in a Model Home for 1 year therefore it wasnt ever used. Could it be that the wiring configuration is different in that it was in that it was in a model home?
  • GE Master
  • 4,654 Answers
The most likely suspect is a defective WR55X10656 main control board. The board is located on rear of refrigerator and the fridge will need to be unplugged to examine it. Remove cover to the board by removing the sheet metal screws on the cover concealing the board. Examine both sides for burn marks or signs od heat or loose solder damage. If you find no problem there then we will mover to the next step. You can see a photo of that control board at both site below. Enter your model or part number in the search feature to check for those or other parts. Let me know if you need more help. Thanks, Sea Breeze
http://appliancepartseast.blogspot.com/
http://servicepartstec.blogspot.com/
Posted on Jul 08, 2009
I have a ge Profile (bottom freezer) refrigerator and the freezer is working but the fridge has now stopped working. Lights and controls seem to be working fine but fridge has not been cold now for two...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 27, 2010 | GE Refrigerators
My GE Fridge is not getting cold
if the freezer is still o.k. then replace the control board located in the lower rear of the unit
Dec 24, 2009 | General Electric Profile PFSF5PJX Bottom...
GE profile fridge not cold, freezer ok
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Dec 18, 2009 | GE Refrigerators
INSIDE LIGHTS FLASH..NOT COOLING..NOT SHOWING TEMP
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
jhjk
Oct 26, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE fridge is warm and broken; the freezer is cold though.
Air circulation problem. Evaporator fan in freezer moves some air to refrig. Either fan is not working or air passages are blocked with ice. If ice found, then a defrost component failure has occurred. Fix what you find.
Sep 19, 2009 | GE Profile PDS20MFS Bottom Freezer...
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Use the damper control to direct less air into the refrig compartment from freezer
Apr 23, 2017 | GE Profile PFS22 33" Artica French Door...
Wow, so you dropped some money into it, eh? I would take a look at the damper door asslb(DIFFUSER). located at the very top left of your refrigerator section in back. It has a motorized door that opens and close's and it may be stuck open. More than likely it is broken and needs to be replaced. GOODLUCK!!!!
FYI: All your cold air in your refrigerator comes from your freezer!
Dec 17, 2007 | GE Profile PFS22 33" Artica French Door...
Not cold
What lights are flashing,dispenser lights? Is the compressior running? fan by the compressor? or the fan in the freezer?
Aug 19, 2007 | GE Profile PSS26NGS Side by Side...
GE Profile 22.2 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Black Logo
289 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
