Question about Samsung SyncMaster 920N 19" LCD Monitor
SyncMaster 920n Monitor 1 1/2" greeen colour vertical bar
I have Samsung SyncMaster 920n Monitor recently purchased. I have a problem that I have a Vertical green bar on left side of the monitor about 1 ½ inch it coming few minutes after power on. It is slowly appearing with crispy effect and getting full vertical line a line. It is less then a year I bought this monitor is it under warranty but I lost the bill please some one help to resolve this problem,
thanks and regards
  • Anonymous Feb 06, 2008
    Left half of my monitor goes either black or some times with different color bands grouped in the left half only.One local mechanic solved the problem but after two months it is back again.Samsung people said the panel has to be changed which is costing almost the same price as the new one, but a local guy could atleast rectify it for some time. One friend said that that LCD monitors are not capable of handling high resolution PC games.I do not know why it happens. Anyone who have some idea? Solomonjey@yahoo.com
  • 52 Answers
Samsung products does not require u to produce a bill during warranty, ur product info will be registered in the database of the customer care center. So you can go in and get ur claim with the warranty. And the about the green lines, it could be that something is wrong with your graphics adapter.
Posted on Dec 02, 2007
  • 983 Answers
This discoloration problem occurs commonly in every1 s pc ... this problem occurs due to the nearby magnetic field emitting appliances just like speakers... so what u have to do is u must keep some gap with the speakers from the monitors & after that press menu button on ur monitor and give degauss.... this will solve your problem....
Posted on Feb 06, 2008
SOURCE:
Syncmaster 920N 5 Minutes of dark Screen It takes 5 minutes for screen to light after computer has been awaken from "sleep" mode or if monitor has turned off while listening to music online.
Hello Dfrank,
The 920N units use the same power supply board that the 710T uses and it was a known issue with bad capacitors that fail. When they fail it can cause the issues that you are having - Either slow to show a picture, wavy display or no power and flashing power light. The boards can be repaired if you can do a little soldering, the parts are cheap. We have a step by step repair guide posted on our tech support web site at: http://www.ccl-la.com/blog/index.php/repairing-the-samsung-syncmaster-710t/ This is an easy repair for a very nice monitor, well worth repairing it.
I hope this helps, if so please rate my solution.
BuddyMc
Jul 28, 2011 | Samsung SyncMaster 920N 19" LCD Monitor
I have a SyncMaster 920N Samsung Monitor and today it stops working. The power light is slightly constantly blinking,but the monitor is not turning on,when I m pressing power button. I tried changed power...
A fast blinking power light is an indication that the power supply is in a shorted condition. Parts called capacitors that filter the output power on the power supply board can fail and the power supply will short out causing the fast blinking power light. If you can solder then you can repair the monitor. Here is a link to a repair guide that has pictures and videos showing how to dis-assemble the unit and what to look for and replace to do the repair.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
BuddyMc
Jan 06, 2011 | Samsung SyncMaster 920N 19" LCD Monitor
Power on/off not respond, what can i do ? my screen Samsung SyncMaster 920N
This may due to power supply is not connected properly or power supply itself gone bad. check and repair/replace the power supply may solve your problem.
Revert back for assistance.
Jan 20, 2010 | Samsung SyncMaster 920N 19" LCD Monitor
We dont have drivers of sumsung syncmaster 920n
LCD usually doesnt require a driver, it is plug and play
Jul 14, 2009 | Samsung SyncMaster 920N 19" LCD Monitor
Screen is banshed up vertical in a 2 " wide a strip '
It sounds like the logic board inside your LCD is broken.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new monitor.
Mar 02, 2008 | Samsung SyncMaster 920N 19" LCD Monitor
Shadow on screen
hello
yes this is the problem due to dry sold or bad ic presuent. plz call a hardware engineer to check the problem
thanks
ramesh
Dec 01, 2007 | Samsung SyncMaster 920N 19" LCD Monitor
SyncMaster 920n Power Cable (?) Issues
I think my monitor power connector broke too
Sep 29, 2007 | Samsung SyncMaster 920N 19" LCD Monitor
Samsung SyncMaster 920N 19" LCD Monitor Logo
305 people viewed this question
Top Samsung Computers & Internet Experts
asber
Stormi  Paulk
Stormi Paulk
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
