Around the air duct there is water leaking. We have a white rodgers thermistate. I don't know the center air brand.
  • losbanos8 May 11, 2009
    Is this job hard to do will it cost a lot to fix
  • 116 Answers
The drain line from the condensate could be stoped up causing water to pool up and be blown into the duct or coil freezing up
Posted on May 11, 2009
Does white Rogers thermostat 1f56n-444 have a reset button
White Rodgers 1F56N-444 User's Manual - ManualAgent
www.manualagent.com > White Rodgers Manuals > 1F56N-444
White Rodgers 1F56N-444 PDF User's Manual Download & Online Preview. ... Download Air Conditioners User's Manual of White Rodgers 1F56N-444 for free. .....Set anticipator to match the setting of your old thermostat you noted in Step 3, ..
Aug 04, 2015 | Home Security
White rodgers 1361 troubleshoot
Next valve you sweat in, make sure you remove the valve stem, or use heat dissipation paste to not get the valve too hot.
Oct 25, 2013 | WHITE-RODGERS DIV White Rodgers 1361-102...
Rheem water heater with White Rodgers controller FVS bad (open circuit)
I don't know.
Copy following link for general service manuals by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Ask question on pro water heater forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
While tank water is cool, loosen and replace anode rod so tank is up-to-date on rust protection.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Oct 29, 2012 | Rheem Water Heaters
98 Toyota Camry LE AC will not blow through center vents...stuck on defrost
Vacuum hose not connected or leaking or something interfering w/door flapper inside ducting, bet it's actuator under dash on the duct but wouldn't be surprised if it's cable controlled either way the flapper is not moving need to find the pivot shaft swing arm and see if something came off or broke then find out why check by moving the flapper by hand if it moves ok problem is not there now don't force anything after you fix it could be object rolling around in duct or something freezing up like a/c cooling condensation water not draining out properly could be that two year olds pacifier no one could find I have seen many forign objects bouncing around in ducting
Apr 02, 2012 | 1998 Toyota Camry
My white rodgers control panel is set on vacation (green light) is on. I have held down the arrow buttons to get it off of vacation mode but it is not working. Obviously i need to switch it off as we have...
Water heater and gas valve are not clear:
Add a comment with description of water heater and gas valve for possible help.
Open following link for White Rodgers intelli-vent gas valve thermostat:
http://waterheatertimer.org/pdf/Intelli-vent-gas-valve2.pdf
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#Intellivent
1) Typical instructions for Kenmore and AO Smith water heater with Intelli-vent say:
Set on-off switch to ON position.
Hold down both arrow buttons for 1 second.
Then press hotter button.
2) Also check that 120Volt electrical outlet has power, and check outlet with cheap circuit analyzer from home center.
3) If Intelli-vent gas valve thermostat is malfunctioning, and won't reset, then contact manufacturer of water heater for replacement gas valve.
Label on side of tank will have Model number, manufacturer, type of gas LP NG, serial number for part ordering.
Add a comment for more help.
Jun 10, 2011 | White Rodgers Water Heaters
Model 1f90w-51 the up down buttons stopped working this is a white-rodgers
Electronic Digital Multi-Stage Thermostat 1F83-261
  • 1F83-51 - White Rodgers Installation and Operating Instructions Thermostat 1F83-51
  • 1F86-344 - White Rodgers owners manual Thermostat 1F86-344
  • 1F86-444 - White Rodgers Installation and Operating Instructions Thermostat 1F86-444
  • 1F87-251 - White Rodgers Thermostat 1F87-251 OPERATION INSTRUCTIONS
  • 1F87-51 - White Rodgers Installation and Operating Instructions Thermostat 1F87-51
  • 1F89-11 - White Rodgers Installation and Operating Instructions Thermostat 1F89-11
  • 1F90-51 - White Rodgers OPERATION GUIDE Thermostat 1F90-51
  • Hi, This is a good stat and I have used it alot in the past as it is a older model. If you have 24 volt control voltage at the stat, and the battires are good, then you have a malfuntion in the ciruitry and will need to replace it. I have sent you a ton of manuals on there products I thiught they may be helpful. Please dont forget to rate this post as I know you will be kind. I hope I have been of help to you.
  • Sincerely,
  • Shastalaker7
  • A/C, Heating Contractor
Sep 22, 2010 | Heating & Cooling
Two zone heat /ac upstairs thermostat appears to be on but no air is being forced through vents. downstairs zone works fine.
Sounds like a problem with your furnace or blockage in your duct work, not a problem with the thermostat. You are not missing a cat are you? The Operating Manuals for many White-Rodgers thermostats can be found in PDF form HERE, however they are not indexed by model number so you will have to download each file in turn until you find the one you want. All of the file names beginning with "0037-" seem to be W-R products.*Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab Professor
Aug 20, 2010 | White Rodgers White-Rodgers 1F85RF-275...
White rodgers motor turning heat not going thru
This item is a buy -out from Thermodisc send a inquiry to there contact us.
Link: Contact Us
Dec 10, 2009 | White Rodgers 0754-1 Electric Water Heater...
Heating & Cooling Logo
55 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
