Question about Refrigerators
My frig and freezer quit cooling its 3 years old ive taken the back panel out of the freezer and the condensor is frozen i was told it needs freon were are the charge fittngs
  • 234 Answers
There are not fittings on your refrigerator.
You have to put it in yourself.
Here is a link to articles about how to do this:
http://answers.yahoo.com/question/index?qid=20070403143615AA6RorQ
If you need more help, email me at trpabc@charter.net.
Thanks,
Tim
Posted on May 11, 2009
Where is the evaporator fan motor? My Freezer and fridge would quit cooling/freezing. I took the back panel off in the freezer a week ago and the evaporator coils were completely frozen over with ice. I...
I do not believe the problem is the fan. sounds like the frig. is low on Freon this is what will cause the ice build up. you need to find the leak, you can do this by spraying soapy water on coil tubes & watch for bubbles. repair leak & recharge.
May 25, 2015 | Samsung RS261MDBP Side by Side...
Refrigerator and Freezer not cooling
Wayne, lower back panel, the fan in back (condensor) should be running with the compressor. If the compressor is running,( you should be able to hear it) and the condensor fan is not running. Then the condensor fan motor is your problem. Another sign of a failed condensor fan motor is that the divider between the freezer and refer is extremely warm to touch. If the compressor is not running, it could be the compressor relay and overload (PTC) might be shorted. They made a bunch of these, white in color that failed quite often. Check yours out, it will be mounted to the front of the compressor. Take it off and shake it. If it rattles, there's your problem...Catriver.
Jun 11, 2007 | KitchenAid Superba Architect KSCS25INSS...
Our 14 year old KitchenAid Superba side by side refridgerator (Mondel KSRS22FGBT01) is not cooling the top half of the freezer section. Bottom half seems to be able to keep cold - but top half doesn't....
Do you see any ice build up on the back wall of the freezer compartment? You probably have one of the following problems: A failed defrost system, meaning the defrost timer and/or element has gone out and your evaporator coil is frozen over; you are low on freon and this too will cause your evap coil to freeze over until the freon drops so low all cooling stops; or there could be a clog in the capillary tube which is the very small diamiter copper tube that carries the condensed liquid freon to the evap coil. Unless you have gauges, a licence to buy freon and service valves (or a buddy with such) you are limited to what you can do. Here is my advice:1. unplug the frig and let it defrose over night, unplug the frig and empty the freezer to remove the back cover to look for ice, a frozen fan and if so get your hair dryer out and melt the ice so you can test the fan and the defrost element (you will need a volt/ohm meter to do the element check. You can do it.
Oct 13, 2013 | Refrigerators
My water dispenser quit working on my GE GSH25JFTAW side by side frig (I believe 4 years old). When I defrosted the freezer (because the fan was making a howling noise) and re-assemble it, the water...
Ken
Most likely the water line inside the freezer door is frozen( very common problem.. No long term fix out there other than defrosting the line(you did that when you defrosted the whole fridge) the trick is to run the water a lot the first day or so..sensors and motherboard have nothing to do with that..
Jul 07, 2017 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
We have a Roper side by side, it is only 4 yrs old. Frig side quit cooling, freezer was fine. We took everything out and saw ice build up in freezer behind a panel. We defrosted and placed everything back...
hi do you have a volt ohm meter pull the back out of freezer check the element see if it has continuity if so it may be the timer witch should be somewhere near the thermostat hope this helps you jim
Oct 10, 2010 | Roper RS25AEXLQ Side by Side Refrigerator
...The temperature in the frig is now + 40 degrees
uve probably got a freon leak check to see if compressor is running and fans inside are blowing if so then u probably have a freon leak
Feb 24, 2010 | Kenmore 63822 / 63824 Bottom Freezer...
Frigidare refrigerator FRS26ZTH FREEZER FREEZING UP/FRIG NOT COOL
also check defrost timer,defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 01, 2009 | Frigidaire FRS26R4A Side by Side...
Sub zero 532
you might have a few problems,, make sure to check the condensor is clean, also make sure the condensor fan motor is going... you might have a bad Condensor fan motor, and Ref Control or a Freon Leak @ the Evaporator... I would call a tech to check it out...
Sep 27, 2008 | Sub-Zero 690 Side by Side Refrigerator
GE Refrigerator Problem
you have a leak in the freon line
Aug 16, 2008 | GE Refrigerators
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
