Question about Maytag EPIC MFW9700S Front Load Washer
Error number 3?
I have a maytag front loader, and it starts cycles and goes for a while until it stops and beeps and displays error number 3 on the screen. can anyone tell me what that means?
    President:
  • 272 Answers
From the tech manual:
Drive system is not working
correctly. Bad windings, speed
sensor, wiring connections, or
Control Board.
Posted on May 11, 2009
3 lights and loud beeping
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Dec 12, 2013 | Fisher and Paykel Washing Machines
Maytag neptune error message e5
This normally indicates that the thermistor is bad. Try measuring it to prove it is OK. It should be 10K Ohms at room temperature (20C / 68F).
If necessary, replace it then clear the error code.
1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard.
2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read it.
3. Press SENSOR DRY and TIME keys for 3 seconds to clear it.
4. Power OFF to exit Service Mode
5. Power ON
Sep 06, 2012 | Maytag MDE9700AYW Neptune 174 Electric...
Front loader stops mid cycle and blinks Er until start button is pressed, the cycle will continue, and sometimes repeats this scenerio three -four times each load. any thoughts anyone?
The control board has detected an error. Press any button to wake the machine then wait for 5 seconds. Press and hold the START/PAUSE and CANCEL buttons simultaneously then the failure code will appear in the display as an "E" followed by two numbers, a number and a letter or two letters as long as the buttons are held. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. Post back the code for further advice.
Jan 11, 2011 | Frigidaire Washing Machines
I get a PF error. That goes away and shows 52 in the display. The buttons light up, but pressing any buttons does nothing but to make 3 beeps.
PF is Power Fail, means the Power was cut off. PF Power failure Power to the machine has been lost during the last cycle. This may occur on start up of a new machine due to factory testing.
Mar 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune MDE9700AYW ts t5 error
Check to see if your thermistor is bad by measure the resistance. It should be 10K Ohms at room temperature.
If it's bad, replace it BUT you have to CLEAR to error code.
5. Power ON
Hope this helps
Jul 25, 2009 | Maytag Dryers
Fisher and Paykel washing machine will not stop washing. It does not advance between the cycles. It fills, then washes, then drains, and then starts all over again. It doesnt move beyond the wash cycle...
Fisher & Paykel GW608U Top loader washing mashine. On power up it will pass the self test, but then it goes to error (single beep every second and lights: green 3rd, 4th green and 7th orange from left are on). Could you advise on the problem please or supply error message codes table. Greatly appreciate your help and looking forward hearing from you
Jul 18, 2009 | Fisher Paykel EcoSmart GWL15
Controls locked on front loader washer. please help
Press far right button ('with a lock picture) for 3 seconds, the lock will come off.
Sep 15, 2008 | Whirlpool GHW9150 Front Load Washer
Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
Mar 19, 2008 | Frigidaire ATF6000ES Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
148 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
