Question about Olevia LT32HVM 32 in. LCD Television
Olevia LCD 32 inch
Am I interpreting the manual that the cable coax can be connected directly to the TV (and not necessarily through a cable box) and get all the channels, or at least the basic channel lineup?
You can hook up direct but you will not get hi def channels, only the standard or digital depending on your hook up.
Posted on Oct 21, 2007
There is no co-axial cable female receptor screw in the coax from the cable box ??? what to do
get an RCA cable (the one with 3 males RED, WHITE AND YELOW), plug in the proper colors each one in the tv and the cable box, go to the INPUT setting in the tv to find the proper one
rate me
Aug 15, 2010 | Olevia LT32HVM 32 in. LCD Television
Cable/Olevia 32" tv
TRY THIS Audio Out of your Cable box colored RED and WHITE is connected to your TV's Audio In RED and WHITE. And connect the VIDEO out of your cable box YELLOW to your TV's VIDEO IN function c_getProfessional_AskGet_refreshPicture() { var imm = $("getProfessional_ask_fromprchat"); var val = false; if(imm) { val = $("getProfessional_ask_fromprchat").checked; } var pOn = $("c_AskGet_checkBoxOn"); var pOff = $("c_AskGet_checkBoxOff"); if(!pOn || !pOff) return; if (val) { pOn.style.display = ""; pOff.style.display = "none"; } else { pOff.style.display = ""; pOn.style.display = "none"; } } function c_getProfessional_AskGet_toggleImmediate() { var oImmediate = $("getProfessional_ask_fromprchat"); if(!oImmediate) return; var val = oImmediate.checked; oImmediate.checked = !val; c_getProfessional_AskGet_refreshPicture(); } c_getProfessional_AskGet_refreshPicture();
May 29, 2010 | Olevia LT32HVM 32 in. LCD Television
47 inch Olevia plugged directly into cable no box and will not program. All other old cable ready tv sets work without box
Diffrent tv,diffrent signals,deffrent frequencies.Talk to ur cable company for the box,to many pay tv signals in one area this day,that why need a box.
Nov 05, 2009 | Olevia LT42HVi 42 in. LCD Television
When hooking my direct tv into the coaxl in it does not work ? When I use the AV cables it works. and I do try all inputs.What can I do
If the coax RF OUTPUT cable of the direct TV BOX is set to channel 3, the the TV will have to be SET TO TV CH3.
Nov 02, 2009 | Olevia LT32HVM 32 in. LCD Television
My 32 inch LCD tv does not seem to work with my new cable box (digital) that I just traded in to get my cable bill down. Where does the coax go on the tv?
For best result when using digi use the scart lead that should have come with the box ~ You should have at least 3 scart sockets on the back of your tv. any 1 will do - then all tv will run through the av channel that should come on auto. when digi box is turned on.
Aug 08, 2009 | Olevia LT32HVM 32 in. LCD Television
I hooked my olevia tv up to cable tuner box but cannot get a pict
Try switching throught the various video inputs on your tv until you get a picture.
Jan 30, 2009 | Olevia LT32HVM 32 in. LCD Television
No cable signal on 32" flat panel Olevia tv
When you write 'tuner,' do you mean the internal TV tuner or do you have a cable box between the wall connector and your set's input?
If you are connected from the wall to the set, then the sensitive circuitry (it may only tolerate a few volts max video) is damaged.
If your set was a couple of decades old, it might be fairly easy to repair.
If the set was damaged via the cable service, you may have some recourse unless your cable provider has seen fit to absolve themselves from liability, I suspect they have.
I do not know your set but it is not impossible that the video input circuitry for cable and antenna is on a smaller assembly that processes it before reaching the main board.
The latter has obviously survived since you still have the other functions.
Jul 29, 2008 | Olevia LT32HVM 32 in. LCD Television
36 inch toshiba Tube tv manifactured in 1997
Program TV =
1) set-up.....Select CATV also called STD Cable
2) Auto-program channels.........
.......Owners manual ? Let me know.................T.
Dec 11, 2007 | Toshiba 32AF43 32" TV
32 in Olevia LCD Display Screen Cracked
youre screwed. panels for tvs cost almost as much as the tv, and they are very hard to replace. i suggest you sell the parts out of it.
Oct 21, 2007 | Olevia LT37HVS 37 in. LCD HDTV
Remote control codes
You need remote rc64 to control the Olevia 32 inch LCD. You can call Directv and order the remote. Use code 11610.
Oct 15, 2007 | Olevia LT32HVM 32 in. LCD Television
Olevia LT32HVM 32 in. LCD Television Logo
192 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
