I have a Xerox XC 1044 copy machine. Copies have grey streak
Hi
Any ideas on how to fix?
Thanks
  • 1 more comment
  • susanne360 May 11, 2009
    Hi
    My message did not come out.
    The copymachine is a Xerox XC 1044
    When I press start to make a copy the image will come out in pretty solid black print but in the background running vertical there is grey ghosting, as if the white paper was actually greyish.
    There is no grainess. Looks almost like charcol
    Almost like the old time copies in the background.
    Does this help?
    Thanks
  • billgates1 May 24, 2009
    i have a xerox copier. When I turn the machine on, it warms up for a very long time but never is ready to copy anything. what could be the problem, anyone. I would appreciate the help.
  • Rick Kasper May 11, 2010
    For whatever reason, I am not able to read your entire message. Other than you are getting gray images?
    There are several things I can tell you, but Can you be more specific ?
    Is there an over all gray background? It is limited to one area? Is there any grainess to it, like a sandy feel on the paper? Is there reprint, like a ghosting?
    If we can narrow the description we can narrow down the resolution.
    That is a very good , very solidly built machine, I would love to help you fix it. You wont buy anything that well built now days.
  • 4 Answers
You may need to have the devoloper changed. Other possible issues; the corona wire is not discharging the photo receptor belt properly, toner spill in the machine from previous change out. Try using an eraser on the gray area if it comes off easily you may have multiple issues that will require a technician to visit machine.
Posted on May 11, 2009
Dark streak on copies
Drum, wiper, or fuse rolls. Pull out toner unit see if you can see those lines.on the drum.
Jan 16, 2014 | Xerox XC830 Copy Machine Refurbished
Tip
Xerox XD or XC Series Copier Drum Light Drum Unit Reset Procedure
To reset the drum light on just about any Xerox XC or XD series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
You can usually reset this counter at least once to get twice the life out of your drum unit.
This works on nearly all Xerox XD and XC Series copiers.
on Mar 20, 2010 | Office Equipment & Supplies
My xerox 5201 copier is making black copies. I
Xerox Copy Drum Cartridge 13R83 / 6R737 (20000 Page Yield)
Xerox brand - works in Xerox XC 355 XC 356 5201 5203 5205 5210 5220 5222 5305 5306 PRice is 135.00.. Post response if you want link to site. This will cure your grounding problem. You Cannot fix it, It is a consumable item and has no serviceable parts
Apr 03, 2009 | Xerox Office Equipment & Supplies
Xerox M15 Prints dark only on copies
If your on maintenance tell them you want a replacement. If you have a maintenance agreement you are entitled to an identical replacement. Write a letter, with the serial number, peoblem and tellt them you want to exercise your TSG agreement. Total Satisfaction Agreement.
Not fixing it is rediculas.
Jan 23, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
White vertical streaks on copies
i'm salaheddinedz@yahoo.fr, i'm an it engineer in a japanese company based in algeria, i have a long experience with the xerox machines, i think your problem may be caused by many things, first it might be coz of the belt scratches or the belst cleaner, in addition it might be coz of the fuser, so it depends on you and the state of your machine, so first try to check if the fuser is ok with another machine. then check if the belt cleaner is already replaced, if all is ok, it might be becoz of bad toner quality.
try also to check the developper test copies. hope u'll find it userfuL.
Oct 27, 2008 | Xerox WorkCentre M-24 Color Copier
Xerox XC 1020 copier code H4
With "H4" flashing press:
1.Clear button
2.Auto button then again
3.Clear button
4.Auto button
It should be done quickly. If it's done quickly enough all lights on display should go off.
5.Enter number 14 (as if you are making 14 copies).
6. Press START/COPY button.
The machine goes back to normal. If not, thermistor on the fuser (heater) should be replaced.
Sep 02, 2008 | Office Equipment & Supplies
Xerox xc 830
pls check ur machine ros assembly unit. i think the ros assay geting dust or its geting failed.
Jul 23, 2008 | Xerox Office Equipment & Supplies
Xerox B/W Copier XC 1044
Here you go. If you have no underlying problems this should work. If it comes right back, you have a fuser problem.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Jun 09, 2008 | Office Equipment & Supplies
295 people viewed this question
k24674
jasbo
jasbo
