Question about Dell Dimension 2400 PC Desktop
The uninstallation of Cyberhawk left several files on my XP system. CHService.exe takes from 92% to 97% of the CPU time according to Windows Task Manager. With a wireless keyboard attached is there any way to remove it and the other leftover Novatix files?
  • 433 Answers
Sometimes the software that came with original program has three ques in the beginning if it detects that this program was already install,
the first install, second repair, third remove...it is does it will do a better job than add and remove programs.
Also download Ccleaner, it's free and clean up the registry fast and easily.
http://www.ccleaner.com/ccleaner-20
I have used it for a year and a half...works great
good luck, please leave rating...thank you
Posted on May 11, 2009
I have a computer [AMD athlon(tm)]xp 1800+ 1.50 GHz]. My problem is when I switch on the system,the OS will open and i don't open any application then if i see in 'Task Manager - performance' there the...
Type "msconfig" on search bar there will be bar "startup apps" click that and click on disable all and restart your system...hope it works... Regards: imran
Sep 19, 2014 | Computers & Internet
How remove micrisoft genuine
  1. Log on to the computer by using an account that has administrative permissions.
  2. Make sure that the WGA Notifications version that exists on the computer is a pilot version In this case, you can uninstall versions 527-532 only (Note: the steps should disable other version of WGA Notifications too). To find the WGA Notifications version, follow these steps:
    1. Click Start, and then click Control Panel.
    2. Double-click Add or uninstall Programs, locate and then click Windows Genuine Advantage Notifications, and then click Click here for support information.
    3. In the Support Info dialog box, verify the version number, and then click Close.
  3. Rename the following files by changing the extension to .old: Rename %Windir%\system32\WgaLogon.dll to %Windir%\system32\WgaLogon.old
    Rename %Windir%\system32\WgaTray.exe to %Windir%\system32\WgaTray.old
  4. Restart the computer.
Then,
  1. Lauch Windows Task Manager.
  2. End wgatray.exe process in Task Manager.
  3. Restart Windows XP in Safe Mode.
  4. Delete WgaTray.exe from c:\Windows\System32.
  5. Delete WgaTray.exe from c:\Windows\System32\dllcache.
  6. Lauch RegEdit.
  7. Browse to the following location:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\
    Windows NT\CurrentVersion\Winlogon\Notify
  8. Delete the folder ‘WgaLogon’ and all its contents
  9. Reboot Windows XP.
This should resolve the issue... Lemme know what happened...
May 04, 2010 | Microsoft Windows XP Professional for PC
Xp pro sp3-after running macfee quick clean. on boot-explorer.exe "the application failed to initialize properly 0xc0150002"
Issue may be a corrupt explorer.exe (The file that actually launches the desktop). There is a lot of discussion on how an AV an bork explorer.exe here and several solutions.
http://www.annoyances.org/exec/forum/winxp/t1061853506
The one I recommend you try 1st is: Fire up the task manager (CTRL+SHIFT+ESC), File, new task, cmd and then c:\windows\system32\restore\rstrui.exe from the command prompt (edit the command if you didn't install windows in c:\windows). See if system restore can rescue explorer for you.
If that doesn't work, there are several other flavors of repair possibilities, last of which is reinstalling Windows
Mar 05, 2010 | Dell Precision M90 Notebook
Exceed hangs with high CPU usage
Hello Djelliott19, It's executive file with some instruction. "exceed.exe" is a method of delivery for virus/malware infection. so please beware. You should perform these basic steps.
1. Clean history
2. fix registry
3. uninstalled every unknown programs
if you still stuck, recommend to call me at +1-800-620-8060 (toll-free) number.
Thanks
John
May 08, 2017 | Hummingbird Computers & Internet
Unknown file
In software Svchost.exe is a generic host process name for services that run from dynamic-link libraries (DLLs) within the Microsoft Windows operating system.
At startup, Svchost.exe checks the services part of the registry to construct a list of services that it must load. Multiple instances of Svchost.exe can run at the same time. Each Svchost.exe session can contain a grouping of services. Therefore, separate services can run, depending on how and where Svchost.exe is started. This grouping of services permits better control and easier debugging, but it also causes some difficulty for end users wishing to see the memory usage or vendor legitimacy of individual services and processes. End users in Windows XP Professional (and derivatives, such as Windows Server 2003 and Windows XP Media Center Edition) can run the following command at the system prompt to get a breakdown:
tasklist /svc /fi "imagename eq svchost.exe" (NB: This command does not work in Windows XP Home.)
Due to being widespread among running processes, svchost.exe has long been a common disguise used by malware to hide its presence from the user. (One of the common trojan horses deceptively uses scvhost.exe). Users may then run tasklist with no arguments and match the reported PIDs with the previously shown Svchost instances. If memory usage appears abnormal, the user can look up the service names shown by their command on the internet to see if it is a known service or malware.
The Svchost.exe file is located in the %SystemRoot%\System32 folder. The main registry key involved at bootup is HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SvcHost (values in this key will show the user at least a partial list of the actual processes behind instances of svchost).
The 30 April, 2007 release of WSUS 3.0 led to reports of svchost.exe issues, including 100% CPU usage, memory hogging, and excessive laptop fan/power usage.[1]
[edit] See also
Oct 29, 2008 | Microsoft Windows Server Standard 2003 for...
Erro message
hi it is some problem .exe file. you setup regd recovery
download it download.com
or setup c drive xp boot cd to recovery .exe file.
go to run command type sfc then enter. setup
Feb 17, 2008 | Microsoft Windows XP Professional With...
Svchost.exe
Go to start>all programmes>accesories>system tools>system restore and restore the pc to a date before you deleted the file
Nov 01, 2007 | Microsoft Windows XP Professional for PC
Dell Dimension 2400 PC Desktop Logo
19 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
