Back to:
Tags:
Whirlpool Duet GHW9150P Front Load Washer
Old whirlpool washing machine won't run. (by 19 users)
posted by yoyogal on Oct 12, 2007
Machine worked fine last night, now won't do anything.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
18 Other Users Have The Same Problem
Comment by Guest, posted on Jul 28, 2008
control panel locked will not start
Comment by islandcasino, posted on Jul 23, 2008
Washer is a Duet at GWHW 9200 Fron Loader.
the control lock in on, and the machine will not work.
says "Control Locked" on LED? Is there anything I can do?
Comment by Guest, posted on Jul 23, 2008
contol lock on, and wont work turned off power still nothing. sayes "control locked"?
Comment by Guest, posted on Jul 05, 2008
it was doing fine now it wont start , this happened last wash and i just plugged it out and in again and it worked, I tried this now but it didnt work
Comment by Guest, posted on Jun 30, 2008
the on light is on but the machine wont start
Best Solution
posted on May 09, 2008
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Press and hold the end of cycle signal button for about 5 seconds and it will reset
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Old whirlpool washing machine won't run.:
I don't want to Accept this solution
Solution #2
posted on May 10, 2008
FixYa! (100)
Guest
Rating: 0%, 0 votes
It worked. TY
Thank You!
Solution #3
posted on Dec 04, 2007
FixYa! (100)
Master_Tech
Rank:Guru Guru
Rating: 88%, 642 votes
Need the Model # from the unit open the lid if it is a top load look at rear where lid closes to on the rim
Thank You!
Can you Help with these Washing Machines problems?
What can be done about the F30 error code?
I bought a brand new washing machine and have the machine...
Can you please tell me the year of manufacture for my...
put my load in the machine press start does click sound...
Not only does it have the error codes, it won't unlock....
18 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jun 15, 2008
Control lock on - can't turn on
Comment by Guest, posted on May 11, 2008
did a load of laundry and can't get the washer to reset!
Comment by Guest, posted on May 10, 2008
Machine worked well in the last half an hour, now control ligh is on & nothing works, tried cancelling and unplugging the unit..nada
Comment by Guest, posted on Apr 15, 2008
light on door not coming on when we shut door bought new sensor lock but still not working actul machine light on is a zanussi 1032l
Comment by Dolfanz, posted on Mar 22, 2008
Same issue, 'Control Locked' light is on Whirlpool Duet frontload. Can not use any of the controls, can not override the issue.
Comment by karolina272, posted on Mar 18, 2008
I have the same problem. Control locked red light is on and the machine won't run. Nothing works.
Comment by Guest, posted on Mar 17, 2008
same as above
Comment by Guest, posted on Mar 16, 2008
control locked indicator is on and machine wont run. tried pressing cancel but nothing. tried unplugging but light is on again when I plug back in
Comment by Guest, posted on Feb 14, 2008
control lock is activated on front load duet
Comment by Guest, posted on Feb 12, 2008
control locked light is on & nothing works
Comment by Guest, posted on Dec 13, 2007
whirpool duet the red light next to the control lock is lit and the machine won't work
Comment by Guest, posted on Dec 02, 2007
the control locked button is on and i cannot turn the washer on
loaded the washer and tryed to start washer code f-1 came up . i unpluged and tryed again nothing,
Loading problems.
Repair Service
Find Washing Machine Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
