Water does not come out on Maytag washer.
The washer appears to be running fine but without water.
    President:
  • 1,136 Answers
Hi, If the wahser is agitating without water, then you will need to check the water level switch. With a model# I could give you more instruction on how to get to the switch. Have tried moving the level switch to high and low levels to see if it resets?
Posted on May 11, 2009
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Maytag washer runs and runs water, no stop.
The soleniod valve is bad.... here is a tip that will help...the problem you have is with the same part but the opposite problem...
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
heatman101
Posted on Apr 28, 2010
heatman101
  • 43501 Answers
SOURCE: my washer just quit letting water run into it it
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Posted on Oct 20, 2010
Maytag washer has LF code appearing and its not filling with water?
There has to be a sensor or some circuit that monitors how much water enters into the machine. What you could do is go to appliancepartspros.com and check out the parts for your machine.
You can also on that site tell them your problem and they will tell you the part responsible for the anomaly. U ca buy it from them or, now that you know the part number, check it out on ebay or other sources for a better price.
Jul 05, 2015 | Maytag Washing Machines
Maytag top loader not working
check water supplys okay and lid closed properly to activate lid switch....
Jul 01, 2012 | Washing Machines
heatman101
Apr 28, 2010 | Maytag PAV3240A Top Load Washer
I have a Maytag front load Mod. # MFW9600SQ1. When
This is actually a fill error, it appears when the tub should be filling and is not being sensed. Make sure that both hot and cold water is turned on. Since you do see water coming into the tub this is an issue related to your pressure switch. It sounds odd but this can also be caused by a siphoning drain so check to make sure your washers drain hose has only a little over a foot into the drain otherwise this may cause it to siphon and throw up the same error. If the water is on and the drain hose checks fine then I would guess your gonna have to replace the pressure switch but right now my money is on the drain hose being shoved to far down in the drain pipe. Hope this helps.
Jan 30, 2010 | Maytag EPIC MFW9600S
Maytag Neptune MAH6700AWW water won't drain into drum
Power off the wall. Drain water & check your pump for blockage. Filter as well.
Mar 26, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
dudett, uplug the washer and turn the water valves on. If the washer is filling with the washer unplugged the valve is bad. Part number 22001196. Not a hard job. If you need help installing, just e-mail the cat here at catriver1@gmail.com Catriver..post back.
Feb 19, 2007 | Maytag Performa PAV2200
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
