Question about Brother MFC 420CN All-In-One InkJet Printer
Printer still wont work...
I recently contacted you online and told you about my "unable to clean"
error.. was told to clean out the ink waste tank and we did that along
with manually cleaning the print head.  Machine is back together and
still says unable to clean.... we did the "reset"
 code and it cleared it but we are still unable to clean... AUUGH.
I am about to throw this in the trash and NEVER buy another brother printer!
HELP!!!!!!!!
  • 832 Answers
You've printed a lot, havent you?
It seems that you have to reset the flush counter, too. The flushing box is the 2nd reason for an error unable to clean. This is the small softbox on the left hand side where the printhead runs acorss for before it starts printing. You dont have to change the flushing box. Its OK to do a reset only:
Call up maintanance modus. press 8 then 0 then several times start mono until FLUSH XXXXXXXXXX (where X are No.) appears. Press the reset code again. After leaving the maintanance mode your mfc should work without a problem.
BTW: What exactly did you do with the waistinktank? I hope you have replaced it by a new one!
In case you have cleaned with water and reinstalled it,  the tank wont take up ink anymore! The ink will flow into the machine and the sensor will give you the error code again (That could be another reason why you still have the error code!)
Please be careful and buy a new one as a sparepart from a service partner who can be found on the brother homepage of your country!
Posted on Oct 12, 2007
What are printer error messages 4F and 48 on Bother MFC-J430W wireless printer
Error 4F and Error 48.
Actual Message will be:
Unable To Init 4F
Unable To Clean 48
These messages indicate the Waste Ink Tank is full.
This is the space in your machine that will store all the ink that is used in cleaning the printhead. Once this is full the only way to continue printing is reset the Purge Counter and clean out the Waste Ink Station. If you do the reset and not he cleaning of the waste ink station you will eventually end up with the waste ink tank overflowing and leaving a huge mess to clean up. If you clean out the tank but not reset the purge counter it won't work till then.
Unless you are satisfied with your ability to dismantle and reassemble your printer you may want to just replace it as it can take some time and causes alot of mess.
May 01, 2016 | Brother MFC-J430w Inkjet All-in-One
Canon BJC- 1000 LPT 1 printer. STATUS: the used ink tank is full. printer not performing.
HI,
Your printer has a built-in waste ink tank for the ink used during print head cleaning. As time goes by, the waste ink tank gradually fills. When the waste ink tank is nearly full, you should receive a "Waste ink warning" error when you print. Press the RESUME button on the printer to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, have the waste ink tank replaced.
Jul 08, 2008 | Canon Office Equipment & Supplies
When I power up the BJC-85, the printer cycles through the start up process and then beeps three times and places the carriage in the replace cartridge position. I have changed cartridges and ink tanks...
The 3 beep error is a prompt that no print head is installed. The error is occurring because the printer no longer recognizes that a print head is installed. Normally , this is due to a defective print head. If you have replaced the print head with ONE YOU ARE CERTAIN IS GOOD, then the problem is in the printer. Try taking a cue tip soaked in isoprophyl ( rubbing) alcohol and cleaning the contact strip where the print head installs. The part in the printer. The area will feel flexible but you can clean it safely. Let the alcohol dry and try the print head again. If you still have the error, the only solution is a full service that involves replacing a major part of the print mechanism.
Sep 20, 2010 | Canon BJC 85 InkJet Printer
I have a Canonmp390 printer & a message keeps
Error "Waste Ink Near Full"
Cause : The waste ink tank (which holds the ink used for print head cleaning) is nearly full.
Action : Contact the Canon Customer Care - Center.
Have a good day.
Dec 03, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Blinng orange light
Answer Part 1 of 2
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take appropriate action.
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Ink tank is not installed properly
Open the Print Head Cover and check whether an ink tank is installed. If an ink tank is installed, push the button of the ink tank, and reinstall the ink tank properly.
Five flashes: No Print Head installed, or Print Head failure
Install a Print Head.
When the error continues, contact a Canon service representative.
Eight flashes: Waste ink absorber almost full
Ink used for cleaning is absorbed in a waste ink absorber placed in the printer. Eight flashes indicate that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so that you can continue printing.
Important
If this error occurs, replacement of the waste ink absorber and maintenance of the printer are required. Canon recommends to contact a Canon service representative as soon as possible. Once the waste ink absorber becomes completely full, it cannot be printed until the Waste ink tank is exchanged.
Nine flashes: A specified period of time has lapsed without receiving a response from a digital camera or digital video camcorder / The digital camera or digital video camcorder connected is not compatible with this printer
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
Printer que " unable to clean see troubleshooting in manual"
Unable to clean usually means the waste ink tank is full, the only repair is to replace the tank, aprox. $10.00 and reset the counter to clear the error. If you clear the error without a new tank you risk ink overflow inside the machine and on your table...
Aug 19, 2009 | Brother MFC 420CN All-In-One InkJet...
My Canon I550 quit printing.
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action.
bullet.gif Two flashes: Out of paper or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
bullet.gif Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
bullet.gif Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. However, when printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it will be a cause of trouble.
See Replacing an Ink Tank
bullet.gif Six flashes: No print head installed
Install a print head.
bullet.gif Seven flashes: Defective print head
Contact a Canon service representative.
bullet.gif Eight flashes: Waste ink tank almost full
i_note_us.gif Note
Canon recommends to call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
bullet.gif POWER lamp flashes alternate green and orange:
An error that requires contacting a Canon service representative may have occurred.
Turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on.
If the problem remains, contact a Canon service representative.
Apr 14, 2009 | Canon BubbleJet i550 InkJet Printer
When i turn my printer on the light flashes green once and then orange 5 times. cannot get past this stage - any ideas?
Here are all the flashing explanations:
See Paper Jams
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. After printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it may cause damage to your printer.
Refer to your Quick Start Guide for instructions on how to replace an ink tank.
Five flashes: No print head installed/Defective print head
Install the print head. Also, ensure that the protective tape has been removed.
If reinstalling the print head does not solve the problem, replace it with a new one. Contact the Customer Care Center.
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact the Customer Care Center.
Mar 08, 2009 | Canon BubbleJet i560 InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
226 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
