Question about Boating
Antenna not rotating
I have a raymarine 18 inch radar on my boat. It has worked fine, until today. Message says antenna not rotating. I have already replaced the motor. It spins fast then slows down like something is binding, but antenna moves without any binding and motor is brand new. Voltage problem?
    Scholar:
  • 76 Answers
It sounds like voltage loss could be your issue. You need to find the "Y" cable under the dashboard and measure the voltage at the point where it connects to the main 12V supply. Keep the meter on and then spin up the radar. If there is a fuse (there should be) make sure you are measuring on the radar side of the fuse. If the voltage drops off as the radar slows, you have found your problem. If the voltage stays constant and the connections are sound at the terminations in the radar pedestal, I would recommend you send the pedestal in to Raymarine.
Posted on Sep 03, 2009
My Raymarine C 120 GPS intermittently stops working.
I had to replace a GPS antenna unit with cable. Sometimes, during bad weather or strong sun, I lost FIX on satellites. Cleaning the top of antenna did not help. Unit from Ebay was also a junk. Get a new one after testing display on a friend boat.
Jul 28, 2010 | Raymarine C120 GPS Receiver
Furuno radar
Your antenna seems to be mis alighned. Its ZERO point must be readjusted.
Aug 30, 2008 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Even after double checks on settings Iam still getting weak echos on Raymarine E120 radar. On higher ranges picture is non existant. Where could my problem be?
How old is the radar antenna? When the echos are weak that is a sign of a failing or weak magnetron. Have you gone into the system diagnostics page to read what the signal strength of the radar is?
Jun 11, 2010 | Raymarine C120 System Pack C120 Raystar...
I got a raytheon sl70 pathfinder gps that wont get a fixed signal the antenna is wired right but there dosent seen to be power comeing out of the cord that leads to the antenna. what should i do ????? i...
If you're using a raystar 125 antenna, you will have to power the red wire + and the shield wire - separately. Sl70's don't provide power over seatalk. Also make sure your green and brown wires are properly connected. If it's a 120 just power the red and sheild(black) and leave off the all except the yellow that's your data. If you still have nothing may probably have a problem in the antenna itself.
Jan 20, 2010 | Raymarine RL70CRC GPS Receiver
Cut antenna wire raymarine 300waas gps
That unit uses a TNC connector. Just have someone install a new one on the end of the cable. IT's a little more difficult than a F connector for a TV but not rocket science. You can also send it in to Mid-Shore Electronics. Just google them and get their number. They have alot of experience with the older stuff.
Oct 27, 2009 | Raymarine Raynav 300 GPS Receiver
Furuno radar antenna not rotating
yes, this is a common failure after hours and hours of use
Apr 06, 2009 | Furuno 2.2kw 18" Radome
Problems talking to autopilot
I think you use the NMEA output to the autopilot .
The plotter shows you only when you have a seatalkconection with a Raymarine autopilot on you Plotter
Apr 06, 2009 | Raymarine E120 Multifunction GPS Receiver
Raytheon rl70
I've had the same problem. before replacing the antenna, try to reset the antenna by removing power to the Raystar 120. Disconnect power by either turning off all batteries or disconnecting the red wire from the antenna at the point where it enters the junction box for the chartplotter. This action effectively removes all memory from the antenna and resets it to factory settings. There is a lithianium battery in GPS antenna that holds memory data in the antenna. Disconnecting the power to the antenna for a few seconds clears the memory.
This is exactly what I did and when I turned the chartplotter back on, my Raystar 120 immediately began working again.
May 05, 2008 | Raymarine RL70CRC GPS Receiver
Boating Logo
370 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
