Question about Exercise & Fitness
On a Proform 760 EKG treadmill, this machine will stop as your walking on it. Jump off and it will begin to run again. What should I do?
  • Anonymous May 22, 2009
    WILL STOP AS YOU WALKING ON IT JUMP OFF IT WILL BEGIN TO RUN.
  • Dan williams Sep 13, 2012
    On my Proform 760 EKG after running on it for approximately 10-12 minutes the fuse pops and you have to wait until the unit cools down before you can run or walk on the unit. Any ideas?
Hi; I purchase this Proform 760 EKG treadmill from a friend. The machine turns on the board lid up with all the works but when I push the start button it will not run. I took everything apart on top were the board is at and everything look good. I also took apart the bottom off and the same thing even the motor does not smell like burnt. So please can some one help?
Posted on Jul 02, 2013
Sounds like the speed sensor needs adjusting
Posted on Feb 03, 2010
My Treadmill PROFORM 760 EKG will just stop as I am walking on it.
see the video and proceed according. Lube the rollers front and rear, test the drive belt motor and replace.
God bless you
Jun 16, 2013 | Treadmill Doctor PROFORM 770 EKG TREADMILL...
My Proform 770 EKG treadmill's motor is overheating. What is the voltage that should be pulled during use? Should the walking belt be replaced if we replace the motor?
see the video and lube correctly. 2) go to my personal TIPS for motor help.3) however you must see the voltage in the plate of motor. the tolerance will be +- 10% of voltage. can be voltage continuosly or alternating voltage.God bless you6527db9f-a9f8-47a6-9208-af2b680ea3a0.jpg
Apr 01, 2013 | Treadmill Doctor PROFORM 770 EKG TREADMILL...
How do I turn on my Pro form 760 ekg .
Dear Sir.
Please turn on the power switch that goes down in the machine is Red switch, most of time there some light of Neon that illuminated when you push to ON. Otherwise reset the button to the side to the power button.
If everything is o.k go inside of the machine and see if the breaker of fuse is tripped or blow, or corrored ( clean but disconnect the power cord): and try again. If not work. You must see if you have power from the outlet wall in your house and reset your breaker.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Mar 06, 2012 | Proform Treadmill with iFit Live
Is there a weight limit on the Pro-Form 760 EKG treadmill? While I am walking the belt skips and I feel like I am going to fall.
not sure if there is a weight limit but did you check the belt tension.
front or rear roller should have an adjustment screw on both sides to tighten the belt. this could be the solution to your problem
Aug 24, 2011 | Proform 760 CrossTrainer Treadmill
Describe your proform 765 ekg sticking Problem When I am running on the treadmill, the belt sticks/stops and I about fall off. It happens just for a second, but it causes me to lose my balance. Someone...
The problem you have is one of two things. 1 you have a loose walk belt, or 2 you have a spun front drive pully.
You need to remove the front cover to be able to observe the drive belt as it is turning on the drive pully( on the LH side of the front roller) try to stop the walk belt while traveling at speed setting 3. Hang on to the side handles, if the drive belt runs as normal, watch the front roller it will be slipping. If this happens you will need to replace the front roller.
Nov 05, 2010 | Proform 760 CrossTrainer Treadmill
I have a Proform 770 EKG Treadmill jerks and squeaks
The drive belt was loose. I tightened up the motor just a smidge using a crow bar. That solved the problem.
Dec 29, 2009 | Exercise & Fitness
Need owner's manual for ifit.com treadmill
1. When walking on the treadmill the belt abruptly stops.
2. As the speed increases so does the noise. Is this associated with the belt tension? Tightening the belt causes the belt not to move at all. What might be the solution to 1 & 2?
Dec 12, 2008 | Exercise & Fitness
Exercise & Fitness Logo
3,103 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
