Home | Frigidaire | FAC107P1A Thru-Wall/Window Air Conditioner | Rudd Achiever A/C flo...
Frigidaire FAC107P1A Thru-Wall/Window Air Conditioner
Problem for Frigidaire FAC107P1A Thru-Wall/Window Air Conditioner
Rudd Achiever A/C float switch is clogged.
By lmarino_kox on May 11, 2009
I have a Rudd Achiever Series A/C heat pump. The float switch is possibly broken or clogged and causing water to fill the drain pan and over flow onto the ceiling of my garage. Can anyone tell me where the switch is located or how can I unclogg the drain pipe. Please advise, I would be very grateful.
Best Solution
posted on May 11, 2009
Helpful)
TheMobilian
Rank: Guru  Frigidaire Expert
Rating: 89%, 704 votes
If the pump was bad the switch is supposed to shut down the ac so the water damage won't occur. You most likely have a bad drain.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Frigidaire FAC107P1A
Questions and Unsolved Problems for Frigidaire FAC107P1A
Do you recommend Frigidaire FAC107P1A Thru-Wall/Window Air Conditioner?
Answer
Answer
my model faa086pta frigidaire air conditioner will not power on. the reset button is working on... (More)
Answer
Hi, my air conditioner, i changed the setting from cool to fan(outside air blowing in)- the unit... (More)
Answer
we bought ours from lowes and it was the display item it came with no instructions, can you tell us... (More)
Answer
My Frigidaire fac107p1a a/c will not power on. I tried resetting the plug but still no power. I... (More)
Answer
where does the white and black wire from the power cord hook to under the panel? I know where the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Frigidaire FAC107P1A...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
