Question about Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM
Casting cracked between motor and pump and trying to find parts and or parts list for flotec model s48d02a03
  • Anonymous May 13, 2009
    I have the same problem. I cracked mine buy overtightening the nipple in the inlet.
    Problem Solver:
  • 10 Answers
Try fixing the crack with JB weld or Tech-Steel before replacing parts.
Posted on Oct 24, 2009
I have a Flotec 1/2 hp jet pump. Is it posible to get just the pump housing. Mine froze cracked the housing?
Use Google and put in Flotec parts.
I did that and several parts dealers came up.
Pick one and put in your model number.
I'm sure you can find a housing, the pump that I looked at had one available.
Gary
Jan 29, 2011 | Flotec 1/2hp Cyclone Pump
I have a flotec pump model FP4122-08, motor #C48J2EC11C3, and a recent freeze broke the motor flange where it bolts onto the pump body. I need to replace the motor base flange but My parts list does not...
I believe the part you actually want is the motor endbell that houses the front motor bearing and it in turn allows the motor to be connected to the pump housing. The number you give is the motor model number...I will also need the motor serial number to ensure we quote you the correct version of the endbell you need as there are design changes from time-to-time. Please email than information to me via the contact us part of our website at www.arrowmotor.net. You should be able to purchase the endbell assuming AOSmith still makes it.
John
Jan 03, 2011 | Garden
My dog chewed the power cord off my FPOS1800A-08 submersible pump, From whom do I order a new cord.
After searching, a clear answer was found ... if the cord replacement exists, it costs a lot.
Flotec has a contact-us form that requires your personal information
http://www.flotecpump.com/
That being said, flotec FPOS thermoplastic sump pumps have pdf parts list.
Parts list shows cord as replacement part.
However, I don't see the FPOS1800 listed
http://www.flotecpump.com/pdf/FP0S6000A_08ReplacementParts.pdf
Flotec sell sheet shows FPOS1800 but does not show parts
http://www.flotecpump.com/pdf/Pg_6_2006.pdf
Website below sells flotec parts
http://www.pumpagents.com/FlotecPumps/flotec-pump-part-list.html
Random cordset price-check shows $46 for a cord
Another cord was $80
Another cord was unknown
Nov 14, 2010 | Flotec FP0S2400A-03 1/3 HP 2,500 GPH...
Flotec Float switch did not automatically shut off,enginburn out
Hi Lamont .. I would first check test the float switch and make sure that it is faulty, set it up in a tub of water and manually move the float switch. see if it cycles on and off. sometimes the float will get hung up on its support or on the edges of the sump pit. If the float switch is faulty then YES it can be replaced,. try a building supply store like home depot or the pl;ace where you got the switch originally.
Please Vote !!
Jun 01, 2010 | Flotec 13 Hp Automatic Submersible Sump...
I have a broken sump pump, Flotec model # FPOF360AC
Same pump, same problem. H/D sells the pumps, but no parts. Here's a link to a vendor of Flotec parts. http://www.pumpvendor.com/Flotec_Parts_List.html
Apr 01, 2010 | Flotec Simer/Flotec/Omni 2105 Swimming...
I need a motor for flotec shallow well pump unit #FP7100-08.The motor #S48D02AO3.WHERE CAN I FIND ONE AND HOW MUCH.Thank you Greg
Save yourself time and effort, replace the entire unit. I speak as a guy who has lived with a well for more than 35 years.
If you put a new motor on a old pump what do you have? A new $300.00 motor on a $worthless old pump. Spend the $350.00 and replace it.
Oct 27, 2009 | Flotec Corrosion Resistant Shallow Well...
Flotec pump takes long time to pressure up. Has worked fine for ~15 years + but noticed the last month or so it runs and runs even after water use is shut off. It's like it's half the pump it use to be. We...
This could be a problem it the pump caused by freezing, check your drain plugs first to see if their cracked or loosened. They will quite often be made if a softer nylon that will crack first and drain pump in the fation of many fail safes. A place to try on-line for parts that may help is "Optimus Home" But I would check the plugs first.
Jul 19, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
The plastic part that houses the impeller cracked on my flotec fp4012-001. Is there a replacement part?
you would have to contact flotec----there should be a part for it,, depending on the age of it, they change the covers all the time to get people to have to replace the whole unit
Jun 21, 2009 | Flotec Corrosion Resistant Shallow Well...
Schematic for wiring in a Flotec Pump
Remove end casing of Flotec motor housing they have a 115v/220v switch, turn to 220v, see website flowtec water. Flotec parts 1-800-365-6832
Jan 31, 2009 | Flotec Corrosion Resistant Shallow Well...
Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM Logo
315 people viewed this question
Top Flotec Plumbing Experts
john h
Andrew Bugbee
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
