Question about Epson Stylus R380 InkJet Photo Printer
EPSON R300 PRINTER NOT FEEDING PAPER INTO MACHINE.
PLEASE CAN YOU HELP MY EPSON R300 PRINTER WILL NOT FEED THE PAPER INTO THE MACHINE IT WAS MAKING SOME GRINDING NOISES, NOW THERES A GENERAL ERROR MESSAGE ON THE SMALL SCEEN.
ANY HELP WOULD MAKE MY DAY.
My paper only feeds on the left side, please help me fix this problem
  • 469 Answers
Take all the paper out,Make sure non of the paper is folded under on the stack. check the paper-feed area for debris,(papreclips, staples post it notes etc).
Check the tray and its guides are secure and it the correct positions.
Open the machine check the paper path for debris, bits of paper or anything the looks out of place.
Once you have checked and cleared everything, close uo the machine and try again.
If you are inclined, you can clean the paper rollers with alcohol.
Hope this is of some help
Ed
Posted on May 11, 2009
2 Suggested Answers
SOURCE: EPSON R300 PRINTER NOT FEEDING PAPER INTO MACHINE.
my epson r300 makes all the right noises when feeding paper but will not draw the paper through can you help
adrian
Posted on Apr 30, 2009
Paper feed not working on Epson r300
If the paperfeed works when you "help" it a little, most likely the feed rollers simply need cleaning. We often suggest taking a little alcohol and spraying it onto some paper, and running it through several times, then running clean/dry paper through to finish. If the printer isn't even trying to load paper, possibly the paper sensor is blocked with dust, and blowing the insides of the printer may help.
Jan 14, 2015 | Epson Stylus Photo R300 InkJet Printer
The feed rollers keep jamming and feeding in at an
phyical inspection of the rollers for a jam or a roller out of its socket would be my first look.
then inspect the plastic gears at the side of the rollers as these will crack and are hard to spot untill they break completely.
Always check your printer properties first and make sure it is set for the correct type of paper.
Unfortunately if has broken gears it will be less expensive to replace than repair.. Regards
Jun 21, 2010 | Epson Stylus Photo R300 InkJet Printer
Epson Photo Stylus R300 paper error
Please replace holder shaft & Roller ******
Sk. Abdus Sabur
Jan 01, 2010 | Epson Stylus Photo R300 InkJet Printer
Epson R300
First of all turn the printer off & disconnect all of the cables. Turn it over and give it a shake, you'll be amazed at what gets inside the feed hopper. Next try a stiff piece of A4 card (the backing from an A4 notepad for instance), feed the card into the paper feed and push it through quite hard to overcome the spring resistence. Once it has started to go through open the lid and check if it has pushed anything through the rollers. Feed the card all the way through the mech and pull out of the front. Hopefully the card will have cleared the paper path of any objects and reseated the sensors.
Good luck.
Mar 12, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson R300 Constant Paper Jam
Take it apart,as fas as you can.clean out all of the paper and chips. The print 5 pages only, twice as the Epson manual says to do , in order to clean itself out.
Dec 23, 2008 | Epson Stylus Photo R300 InkJet Printer
adrian
Nov 26, 2008 | Epson Stylus Photo R300 InkJet Printer
Will not pull paper into printer...half the time
What sort of paper are you using? What sort of volume has the machine done? Have you ever had a jam and pulled the paper back out through the auto sheet feeder instead of feeding it through the exit rollers?
Nov 12, 2008 | Epson Stylus Photo R300 InkJet Printer
Paper jam
i would Isolate the printer to know if the printer is getting
the error stand alone. Disconnect printer from pc and turn the printer off. take out any remaining paper. Check for small pieces of paper and look for obstruction inside the printer and the paper feeding area. Then try and do a stand alone nozzle check by holding the paper button down and turning the printer on keeping finger on the paper button for arounf 5 sec. now if that still doesnt feed the paper there could be something worng with the machine. hopefully your still under warranty.
May 06, 2008 | Epson Stylus Photo R220 InkJet Printer
My printer, makes a grinding noise, when the paper is feeding through when printinig?
Look to make sure that there isn't a small bit of paper caught in the wheels that push the paper through. Over time, even a small bit in the corner can destroy your printer.
Mar 22, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus R380 InkJet Photo Printer Logo
462 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
