Question about Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Calypso Washer is leaving dark brown stains on clothes
For some reason, my washer is now starting to leave stains on my clothes. Not all clothes are impacted. It seems to be the ones the ones that are at the bottom of the tub when it goes into the final spin. I have wiped brown film from the bottom of the tub with a clean cloth & rubbing alcohol after a few washes so far. I have no idea why this problem is occuring. It is not from a previous really dirty load of laundry. Has anyone else had this problem?
  • 1 more comment
  • chintwins May 12, 2009
    No, the spin cycle is running fine and not too noisy.
  • ctharpers May 16, 2009
    It happens in almost every load. Some are small, some are so bad the clothes have to be thrown away. Just started in the past 6 months or so.
  • Anonymous May 20, 2009
    Yes, I have had the same problem. Sometimes I need to spray the stain or dirt after an item has been washed and then re-wash it. I've had more issues with this machine than any other I've owned.
    Problem Solver:
  • 4 Answers
Hi is the machine noisy on spin cycle if so ur bearings have gone
Posted on May 11, 2009
Why is my washer leaving black stains on my clothes
It sounds like it might be leaving mold deposits. Try running a cycle with no clothes in it, hot, with a cup of bleach. If the stains are more brown than black, though, that would be rust in the pipes.
Oct 16, 2010 | Kenmore 44102 Front Load Washer
Kenmore Super Capacity 3.5 Front Load Washer leaves dark lines on light-coloured items and light lines on dark-coloured items! I've cleaned the rubber gasket (? where the door fits into the drum) and there...
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 13, 2010 | Kenmore 3.5 cu. ft. Front Load Electric...
Starting to leave brown oily like stain on clothes
The first place that I'd check would be the small metal screens inside the openings on the water inlet valve. They can get really rusted, epecially in areas with hard water, so I would recommend removing the water supply hoses and take a gander at the screens. They can sometimes release the iron oxide into the wash water and cause brown stains or blotches on clothing. Hope this helped and best wishes.
Sep 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My Kenmore heavy duty tumble washer is leaving a light brown stain on white or light clothes. It is likely staining dark clothes but of course they are too dark to see a light stain. It is definitely...
Jun 06, 2009 | Kenmore 44102 Front Load Washer
Washer whining when washing and spinning leaving brown stains on clothes
Turn water off. Remove hoses and clean the rust out of the strainers at hose end. If they are clogged they will sound funny when water goes through them.
May 04, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
My Whirlpool Calypso top loading washer (purchased in June of 2002) is starting to leave brown or dirt colored marks on clothing and sheets (I think they are permanent!) - I don't see any obvious place...
Run the washer empty with vinegar on the hottest, longest cycle. Usually this is caused from fabric softener and liquid detergent build up. Use powder detergent only and don't use cold water to wash in all the time. Only use cold water for your bright, finer cloths. Cold water use causes detergent build up.
Apr 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite calypso 21086 leaves dirt streaks on clothes
Run the hottest & fullest cycle possible - without a load - and add a grease remover - like goo-gone. Fatty tissues build up inside the tub - and can be released on hot cycles if HOT wasn't used very often.
It is recommended to run a HOT load every 2 weeks or so to avoid these buildups and staining of clothes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 20, 2009 | Kenmore Elite 21086
Front loading washer leaves stains
This often is called "lint" but is really a "whiting" left by un-dissolved soap and can be seen at it's worst on dark colored clothes. This is made worse in a colder climate where the cold water entering the washer is much colder than normal. Things that can effect the quality of the finished washed products.
Too much soap: ( we have a test for this further down the page ) If you follow the manufactures instructions on the box, then chances are you ARE using too much soap. They like to sell you their product, I find cutting usage in 1/2 of what the box says will still wash good and also cut your chances of getting "whiting" on your clothes.
Nov 03, 2008 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
965 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
