Question about Garden
Older Sears craftsman 15 hp 6 speed. Let clutch out and
Older Craftsman 15 hp 6 speed. Let clutch out and petal vibtates, jumps around. Knocked belt off. replaced belt. Runs fine, but clutch still vibtates and jumps around. Any ideas and is it safe to drive? Thank You.
  • ndr1945 May 12, 2009
    Model number 917.252521.Spring apears to be good and strong. Could it be the engine pulley? I also suspected a spring. I only see the one large one.
    Thank You....
  • Anonymous Mar 25, 2014
    engine runs fine but knocking noise when clutch is engaged
  • 246 Answers
Hello:
From your Description it Sounds like a Bad/Weak Clutch/Brake Tension Spring.
I have Just Joined this Site as an Expert and can Assist you Better if you Send me the Model Numbers Off the Unit.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger
Posted on May 11, 2009
  • John C Bridgers Sr May 12, 2009
    Hello Again ndr1945:
    A Bent Engine Pulley and a Bent Transaxle Pulley will Cause the Problem you Described.
    A Worn Bellcrank Assy #48 will Also cause this Problem.
    Hope this Helps. Let me Know What Happens, Please. As Always, May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
    Good Luck
    Respectfully
    jbridger (John)
Craftsman Garden Tractor 26 HP 6 speed transaxle First mow of the season. mowed 15 ft. pressed in clutch to look behind at how it was mowing let clutch out to go no forward movement. belt seams good.
Make sure the transaxle disengagement lever is not in the neutral position. On most lawn tractors, this lever is a stiff wire -- sometimes with a loop on the end -- that sticks out of a slot above and to the right of the trailer hitch bracket on the rear panel, below the seat. Most tractors move under their own power when the wire is all the way in, and can be rolled around without the engine running when the wire is pulled out.
Apr 10, 2018 | Craftsman Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
My craftsman tractor wont pull itself up a hill. Runs fine but just comes to a stop when trying to go up a hill. Maby the ground drive belt is slipping????
Sounds like your drive belt is slipping alright. Need to tighten your clutch rod. One end of rod adjust. Have someone help you, move the clutch petal and your helper watch and see rod moves.
Nov 14, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman riding mower won't move.
yes it is a bad belt unless it is a hydro-stat(no clutch) you need to look under the mower and see if the belt is on correctly
Sep 30, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Tractor won't go forward or reverse
Check the drive belt. It has probably broken or has come loose.
Sep 01, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Clutch vibration and jerking at slow speeds.
Check the drive belt. It probably has chunks missing or at least has flat spots (narrow spots) that cause the belt to jump every time it goes around a pulley. That will set up a heck of a vibration. Also check the pulleys for free movement. The drive belt is above the blade drive belt....
Jul 27, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Craftsman 26hp Garden Tractor PTO not working
If you changed the belt make sure it did not interfere with the wire that runs from the pto clutch, sometimes that belt can rub on the wire and wear through it,also if you had the clutch off make sure you aligned the steel retainer bolt that sets in the alignment hole on the pto clutch,this keeps the clutch from spring when disengaged if you don't get that pin through the hole in clutch it can push on the clutch and bind it.Also it may be possible to plug that pto switch in backwards.Also if you jumped the fuse out it may now have burnt the switch or wiring somewhere.
Jul 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Jun 01, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Engine cuts out when letting clutch out
Deck belt and drive belt are seperate. Look under back make sure it not jamed.
May 28, 2009 | Garden
Garden Logo
175 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
