Question about Samsung 931BF 17" LCD Monitor
Samsung syncmaster 931bf check signal cable
I have the signal cable in and I get this floating message...
   "check signal cable"
  *red*  *green*   *blue*
            analog
*colour* is just a square of that colour... HELP ME!!!!!!
  • klihe Nov 17, 2007
    floating message, "check signal cable". otherwise screen stays dark. have samsung syncMaster 940bw
valsys
  • 3 Answers
SOURCE: NO GREEN COLOUR
i think you should checkthe signal cable for continuity in particular the green signal wire
Posted on Feb 05, 2008
vcmichael
  • 115 Answers
SOURCE: Samsung Syncmaster 20 inch no signal
It is a fault with your CPU's Ram module(90%). Rest goes to motherboard/Graphics card.
Posted on Dec 17, 2008
SOURCE: Samsung 2233 stuck in analog
in your mon there will be small left arror image in box called enter button,,,,if u press that button its shows analog and digital in that have to choose digital.....
Posted on Apr 25, 2009
rubydu
  • 102 Answers
SOURCE: Samsung SyncMaster 226BW - floating box "Check Signal Cable"
it shwos a compability issue with ur pc and monitor .somehow your sync signals are drop and not going to monitor at proper level...so u could replace your video data cable with new one.
or use a short length cable.it may solve your problem.
Posted on Jul 25, 2009
  • 11 Answers
SOURCE: error message on Syncmaster- check signal cable
sounds like it might be a graphics card. if u have an old graphics or vidio card, open the case and remove your card then install the old one. if it works now youll know your card is bad. If u have an old video card and an open pci slot install it and move the monitor cable to the old video card plugin. if it works now same thing your graphics card is bad. to know which card to remove just remember which one the monitor is plugged into.
Posted on Jul 29, 2009
Why do I have no signal on the Samsung syncmaster 940 mw tv
Check your cable connection on both ends. Try to change the cable.
Oct 06, 2014 | Samsung SyncMaster 940MW 19" LCD Monitor
VGA Will not connect
Have you checked if the SyncMaster is compatible with a Mac? I do not use Macs, so I do not know. In the old times you had to buy everything Apple. You could try looking for an adapter to convert VGA or Digital to Mac Video.
Nov 27, 2013 | Samsung SyncMaster 2253LW Monitor
I can't get my Samsung SyncMaster 931BF to come of of sleep mode?
I already post solution for this problem, click here to see the solution.
Dec 21, 2009 | Samsung SyncMaster 931BF LCD Monitor
VGA connector wiring detail
Pink - red input - pin 1 green - green input - pin 2 blue - blue input - pin 3 ground shield wire - pin 6,7,8 and 10 black - ddc 5v - pin 9 violet - screen raster - pin 11 white - data or sda - pin 12 orange - clock or scl - pin 15 yellow - vertical signal - pin 14 clear - horizontal signal - pin 13
Sep 11, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
had the same issue, called up customer care of samsung and they suggested me to change the cable to D-15 10 series. I was getting the comp o/p on TV but with the "Check Signal Cable" messg with the old VGA cable where some pin is not grounded used for computer to monitor connectivity.
Abhi..
Jul 25, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
A green hue from my samsung syncmaster 720n
Check the video cable connection at both ends. If it is secure, then move the cable in circles at both ends.
If the cable breaks a single wire, it will still be close enough to make contact under this test.
The red is almost always the one that will break first and cause the green and blue signals to be the only ones to be active resulting in a blue/green tint.
If you have another cable just try that instead.
Apr 28, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
New Monitor Installation
Does your computer have more than one video adapter installed. If so, try plugging into the other one.
Jan 13, 2008 | Samsung SyncMaster 216BW Monitor
Samsung 931BF 17" LCD Monitor Logo
210 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
